Squall Leonhart Posted November 21, 2010 Posted November 21, 2010 The black screen is a very rare occurence, but the fan pwn polarity reversing tends to occur without much playing with, I once forgot i had gpu-z running and my GPU Fan' reversed pwm polarity while playing HL2 and the fan jumped up to 100% because the temp hit 100c, as the fan was running at 0 RPM. I was running Orbu2k's GPU Observer earlier and my fan reversed, last thing i saw before black screen was 100% @ 100RPM on LCD display and i got a black screen while doing some light gpu usage in a Flash video. I'm thinking the multiple sensors are causing the driver to crash without recovery. from what i've observed this issue is only likely to occur if both apps can monitor the gpu fan, since i used to run speedfan alongside Everest just fine for fan speed controlling, and speedfan can display GPU temps (in builds of speedfan that don't display gpu fan speed, 4.41) Other users have experienced this with Precision/Rivatuner vs Hardware Monitor/Everest (and now AIDA64) My configuration is a i7 920, Asus Rampage II Gene, EVGA GTX 275, Auzen Prelude 7.1, with 6GB of ram. that said, its perfectly fine when Aida or the other apps are run by themselves, but since people tend to like setting up fan configurations in afterburner and monitoring fps with precision/afterburner, etc its a bit of a problem when the gpu fan glitches out. Basically what im asking is if the access to the fan controller can be made a little bit more safer.... actually i was messing with nvidia system tools device rule awhile back to set up a custom fan scale and that would glitch up as well while everest was running (haven't tried in aida64) From what i've gathered the problem can occur when run along side GPU-Z Nvidia Inspector (or Orbu2k's GPU Observer Gadget which afaik just connects to the Ntune component in system tools) Afterburner, Precision or Rivatuner HW Monitor Nvidia System Tools Quote
Squall Leonhart Posted November 24, 2010 Author Posted November 24, 2010 according to unwinder, Precision, Afterburner and RT access via NVAPI, GPU-Z does now as well. Orbu2k also access's via NVAPI. Absolutely NOT TRUE. That's not a question of using Precision with anything else. It is a question of mixing ANY tool working with graphics card via official NVIDIA NVAPI (which includes all official vendor specific tools like Precision' date=' Afterburner, NVIDIA's own system tools, ASUS SmartDoctor, even a few games containing thermal protections via NVAPI) with ANY tool accessing graphics card I2C bus directly and bypassing NVAPI (e.g. all CPUID engine based tools including E-LEET). And NVIDIA warned all developers about it even before GTX 400 series graphics cards announce, e.g. GPU-Z was ported to NVAPI almost immediately after that. [/quote']accessing directly instead of via nvapi appears to be the problem. if i enable access via nvidia driver, it no longer shows the GPU fan RPM and displays 0% Quote
Fiery Posted November 28, 2010 Posted November 28, 2010 As you found it, AIDA64 already has an option (main menu / File / Preferences / Stability / nVIDIA GPU SMBus access through nVIDIA ForceWare) to switch to NVAPI usage instead of direct nVIDIA I/O. If it's possible, please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic. Using the data in that dump we could check what's going on with the fan in NVAPI mode. It would be an additional help if you could perform the same dump with direct nVIDIA I/O setting (nVIDIA GPU SMBus access through nVIDIA ForceWare = disabled/unchecked). Before issuing those dumps, make sure to close other hardware monitoring software, to avoid any collisions. Thanks, Fiery Quote
Squall Leonhart Posted November 28, 2010 Author Posted November 28, 2010 it no longer shows the GPU fan RPM and displays 0% GPU fan RPM's missing GPU speed percentage appears as 0 and GPUVCC is missing heres the dumps Direct IO ------[ AIDA64 v1.20.1158 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7600 (64-bit) ]------ ------[ Video Adapters ]------ EVGA e-GeForce GTX 275 [10DE-05E6 / 3842-1171] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B01-D26 ]------ 0000 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 ................ 0010 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 ............... 0020 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 !"#$%&'()*+,-./0 0030 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 123456789:;<=>?@ 0040 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 ABCDEFGHIJKLMNOP 0050 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 QRSTUVWXYZ[\]^_` 0060 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 abcdefghijklmnop 0070 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F 80 qrstuvwxyz{|}~. 0080 81 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90 ................ 0090 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 ................ 00A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 ................ 00B0 B1 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 ................ 00C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0 ................ 00D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF E0 ................ 00E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0 ................ 00F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D50 ]------ 0000 00 FF FF FF FF FF FF 00 06 09 01 00 BB 06 00 00 ................ 0010 23 0B 01 02 0C 1F 17 C3 EA 9F DE A2 55 48 9A 26 #...........UH.& 0020 11 47 4F AF CE 00 45 59 61 59 81 80 01 01 01 01 .GO...EYaY...... 0030 01 01 01 01 01 01 EA 24 00 60 41 00 28 30 30 60 .......$.`A.(00` 0040 13 00 36 E6 10 00 00 00 00 00 00 FC 00 41 63 65 ..6..........Ace 0050 72 20 56 37 37 31 0A 20 20 20 00 00 00 FF 00 30 r V771. .....0 0060 31 37 32 33 0A 20 20 20 20 20 20 20 00 00 00 FD 1723. .... 0070 00 32 78 1E 48 0B 00 0A 20 20 20 20 20 20 00 7E .2x.H... .~ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B02-D04 ]------ 0000 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0010 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0020 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0030 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0040 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0050 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0060 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0070 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0080 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0090 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00A0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00B0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00C0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00D0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00E0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00F0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ------[ nVIDIA SMBus Device GPU #1 / B02-D37 ]------ 0000 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0010 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0020 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0030 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0040 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0050 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0060 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0070 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0080 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0090 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00A0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00B0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00C0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00D0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00E0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00F0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy ------[ nVIDIA SMBus Device GPU #1 / B02-D3A ]------ 0000 09 0E BE 4D 9B 00 00 00 00 00 00 00 00 00 00 00 ...M............ 0010 7B FF DF FA 6B 00 00 00 5B AA 7F 76 5E 2A FB FC {...k...[.v^*.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D4A ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 94 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 00 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D4B ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 95 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 00 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D50 ]------ 0000 00 FF FF FF FF FF FF 00 09 D1 0A 78 45 54 00 00 ...........xET.. 0010 2E 12 01 03 80 34 20 78 2E C5 C4 A3 57 4A 9C 23 .....4 x....WJ.# 0020 12 4F 52 A5 6B 80 71 00 81 00 95 00 81 80 B3 00 .OR.k.q......... 0030 A9 40 D1 00 01 01 28 3C 80 A0 70 B0 23 40 30 20 .@....(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4C 42 38 6..D!........LB8 0050 30 34 39 36 37 53 4C 30 0A 20 00 00 00 FD 00 32 04967SL0. .....2 0060 55 1F 5E 11 00 0A 20 20 20 20 20 20 00 00 00 FC U.^... .... 0070 00 42 65 6E 51 20 47 32 34 30 30 57 0A 20 00 C6 .BenQ G2400W. .. 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D51 ]------ 0000 00 FF FF FF FF FF FF 00 10 AC 17 A0 53 44 4E 31 ............SDN1 0010 15 10 01 03 80 34 21 78 EE EE 91 A3 54 4C 99 26 .....4!x....TL.& 0020 0F 50 54 A5 4B 00 81 80 A9 40 71 4F B3 00 01 01 .PT.K....@qO.... 0030 01 01 01 01 01 01 28 3C 80 A0 70 B0 23 40 30 20 ......(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4D 57 37 6..D!........MW7 0050 39 36 36 35 4E 31 4E 44 53 20 00 00 00 FD 00 38 9665N1NDS .....8 0060 4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC L.S... .... 0070 00 44 45 4C 4C 20 32 34 30 37 57 46 50 0A 00 77 .DELL 2407WFP..w 0080 02 03 1A 72 47 85 02 03 04 01 06 07 23 09 07 07 ...rG.......#... 0090 83 01 00 00 65 03 0C 00 10 00 01 1D 00 72 51 D0 ....e........rQ. 00A0 1E 20 6E 28 55 00 B4 86 21 00 00 1E D6 09 80 A0 . n(U...!....... 00B0 20 E0 2D 10 10 60 A2 00 08 86 21 00 00 18 8C 0A .-..`....!..... 00C0 D0 8A 20 E0 2D 10 10 3E 96 00 B4 86 21 00 00 18 .. .-..>....!... 00D0 8C 0A A0 14 51 F0 16 00 26 7C 43 00 08 86 21 00 ....Q...&|C...!. 00E0 00 98 8C 0A A0 14 51 F0 16 00 26 7C 43 00 B4 86 ......Q...&|C... 00F0 21 00 00 98 00 00 00 00 00 00 00 00 00 00 00 18 !............... ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B03-D0C ]------ 0000 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0010 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0020 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0030 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0040 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0050 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0060 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0070 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0080 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0090 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00A0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00B0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00C0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00D0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00E0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00F0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] ------[ nVIDIA SMBus Device GPU #1 / B03-D2E ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 FF C1 00 00 70 6E 70 79 06 FF FF FF FF FF FF .....pnpy....... 0030 E8 00 00 94 62 A4 00 00 FF FF FF 00 00 73 41 69 ....b........sAi 0040 45 D0 10 1F 00 FF 00 FF 00 FF 00 FF 00 FF 8A 9E E............... 0050 54 7C 90 A9 FF FF FF FF 00 80 FF FF E2 80 80 D8 T|.............. 0060 CC CC 20 00 8C 80 80 81 64 9A A1 A4 AB 01 00 00 .. .....d....... 0070 00 00 00 00 CF FF 2C 00 1E 00 00 55 30 01 00 00 ......,....U0... 0080 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Via Nvidia SMBus ------[ AIDA64 v1.20.1158 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7600 (64-bit) ]------ ------[ Video Adapters ]------ EVGA e-GeForce GTX 275 [10DE-05E6 / 3842-1171] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B00-D26 ]------ 0000 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 ................ 0010 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 .............. ! 0020 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 "#$%&'()*+,-./01 0030 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 23456789:;<=>?@A 0040 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 BCDEFGHIJKLMNOPQ 0050 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 RSTUVWXYZ[\]^_`a 0060 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 bcdefghijklmnopq 0070 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F 80 81 rstuvwxyz{|}~.. 0080 82 83 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90 91 ................ 0090 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 ................ 00A0 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 B1 ................ 00B0 B2 B3 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 ................ 00C0 C2 C3 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 ................ 00D0 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF E0 E1 ................ 00E0 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0 F1 ................ 00F0 F2 F3 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF 00 01 ................ ------[ nVIDIA SMBus Device GPU #1 / B00-D50 ]------ 0000 00 FF FF FF FF FF FF 00 06 09 01 00 BB 06 00 00 ................ 0010 23 0B 01 02 0C 1F 17 C3 EA 9F DE A2 55 48 9A 26 #...........UH.& 0020 11 47 4F AF CE 00 45 59 61 59 81 80 01 01 01 01 .GO...EYaY...... 0030 01 01 01 01 01 01 EA 24 00 60 41 00 28 30 30 60 .......$.`A.(00` 0040 13 00 36 E6 10 00 00 00 00 00 00 FC 00 41 63 65 ..6..........Ace 0050 72 20 56 37 37 31 0A 20 20 20 00 00 00 FF 00 30 r V771. .....0 0060 31 37 32 33 0A 20 20 20 20 20 20 20 00 00 00 FD 1723. .... 0070 00 32 78 1E 48 0B 00 0A 20 20 20 20 20 20 00 7E .2x.H... .~ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B01-D04 ]------ 0000 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0010 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0020 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0030 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0040 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0050 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0060 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0070 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0080 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0090 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00A0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00B0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00C0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00D0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00E0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00F0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ------[ nVIDIA SMBus Device GPU #1 / B01-D37 ]------ 0000 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0010 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0020 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0030 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0040 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0050 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0060 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0070 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0080 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0090 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00A0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00B0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00C0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00D0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00E0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00F0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy ------[ nVIDIA SMBus Device GPU #1 / B01-D3A ]------ 0000 09 0E BE 4D 9B 00 00 00 00 00 00 00 00 00 00 00 ...M............ 0010 7B FF DF FA 6B 00 00 00 5B AA 7F 76 5E 2A FB FC {...k...[.v^*.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D4A ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 94 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 00 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D4B ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 95 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 FC 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D50 ]------ 0000 00 FF FF FF FF FF FF 00 09 D1 0A 78 45 54 00 00 ...........xET.. 0010 2E 12 01 03 80 34 20 78 2E C5 C4 A3 57 4A 9C 23 .....4 x....WJ.# 0020 12 4F 52 A5 6B 80 71 00 81 00 95 00 81 80 B3 00 .OR.k.q......... 0030 A9 40 D1 00 01 01 28 3C 80 A0 70 B0 23 40 30 20 .@....(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4C 42 38 6..D!........LB8 0050 30 34 39 36 37 53 4C 30 0A 20 00 00 00 FD 00 32 04967SL0. .....2 0060 55 1F 5E 11 00 0A 20 20 20 20 20 20 00 00 00 FC U.^... .... 0070 00 42 65 6E 51 20 47 32 34 30 30 57 0A 20 00 C6 .BenQ G2400W. .. 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D51 ]------ 0000 00 FF FF FF FF FF FF 00 10 AC 17 A0 53 44 4E 31 ............SDN1 0010 15 10 01 03 80 34 21 78 EE EE 91 A3 54 4C 99 26 .....4!x....TL.& 0020 0F 50 54 A5 4B 00 81 80 A9 40 71 4F B3 00 01 01 .PT.K....@qO.... 0030 01 01 01 01 01 01 28 3C 80 A0 70 B0 23 40 30 20 ......(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4D 57 37 6..D!........MW7 0050 39 36 36 35 4E 31 4E 44 53 20 00 00 00 FD 00 38 9665N1NDS .....8 0060 4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC L.S... .... 0070 00 44 45 4C 4C 20 32 34 30 37 57 46 50 0A 00 77 .DELL 2407WFP..w 0080 02 03 1A 72 47 85 02 03 04 01 06 07 23 09 07 07 ...rG.......#... 0090 83 01 00 00 65 03 0C 00 10 00 01 1D 00 72 51 D0 ....e........rQ. 00A0 1E 20 6E 28 55 00 B4 86 21 00 00 1E D6 09 80 A0 . n(U...!....... 00B0 20 E0 2D 10 10 60 A2 00 08 86 21 00 00 18 8C 0A .-..`....!..... 00C0 D0 8A 20 E0 2D 10 10 3E 96 00 B4 86 21 00 00 18 .. .-..>....!... 00D0 8C 0A A0 14 51 F0 16 00 26 7C 43 00 08 86 21 00 ....Q...&|C...!. 00E0 00 98 8C 0A A0 14 51 F0 16 00 26 7C 43 00 B4 86 ......Q...&|C... 00F0 21 00 00 98 00 00 00 00 00 00 00 00 00 00 00 18 !............... ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ Quote
Fiery Posted November 28, 2010 Posted November 28, 2010 Thank you. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1165vs6mnwy3qxzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it's possible, please post the dumps above again, with this version. Also, using any setting for nVIDIA GPU SMBus access, please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic. Thanks, Fiery Quote
Squall Leonhart Posted November 28, 2010 Author Posted November 28, 2010 Direct IO ------[ AIDA64 v1.20.1165 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7600 (64-bit) ]------ ------[ Video Adapters ]------ EVGA e-GeForce GTX 275 [10DE-05E6 / 3842-1171] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B01-D26 ]------ 0000 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 ................ 0010 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 ............ !"# 0020 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 $%&'()*+,-./0123 0030 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 456789:;<=>?@ABC 0040 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 DEFGHIJKLMNOPQRS 0050 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 TUVWXYZ[\]^_`abc 0060 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 defghijklmnopqrs 0070 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F 80 81 82 83 tuvwxyz{|}~.... 0080 84 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90 91 92 93 ................ 0090 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 ................ 00A0 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 B1 B2 B3 ................ 00B0 B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 C2 C3 ................ 00C0 C4 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 ................ 00D0 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF E0 E1 E2 E3 ................ 00E0 E4 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0 F1 F2 F3 ................ 00F0 F4 F5 F6 F7 F8 F9 FA FB FC FD FE FF 00 01 02 03 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D26 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B01-D50 ]------ 0000 00 FF FF FF FF FF FF 00 06 09 01 00 BB 06 00 00 ................ 0010 23 0B 01 02 0C 1F 17 C3 EA 9F DE A2 55 48 9A 26 #...........UH.& 0020 11 47 4F AF CE 00 45 59 61 59 81 80 01 01 01 01 .GO...EYaY...... 0030 01 01 01 01 01 01 EA 24 00 60 41 00 28 30 30 60 .......$.`A.(00` 0040 13 00 36 E6 10 00 00 00 00 00 00 FC 00 41 63 65 ..6..........Ace 0050 72 20 56 37 37 31 0A 20 20 20 00 00 00 FF 00 30 r V771. .....0 0060 31 37 32 33 0A 20 20 20 20 20 20 20 00 00 00 FD 1723. .... 0070 00 32 78 1E 48 0B 00 0A 20 20 20 20 20 20 00 7E .2x.H... .~ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D50 ]------ 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 0900 D109 0AD1 780A 4578 5445 0054 0000 2E00 0010 122E 0112 0301 8003 3480 2034 7820 2E78 C52E C4C5 A3C4 57A3 4A57 9C4A 239C 1223 0020 4F12 524F A552 6BA5 806B 7180 0071 8100 0081 9500 0095 8100 8081 B380 00B3 A900 0030 40A9 D140 00D1 0100 0101 2801 3C28 803C A080 70A0 B070 23B0 4023 3040 2030 3620 0040 0036 0700 4407 2144 0021 0000 1A00 001A 0000 0000 FF00 00FF 4C00 424C 3842 3038 0050 3430 3934 3639 3736 5337 4C53 304C 0A30 200A 0020 0000 0000 FD00 00FD 3200 5532 0060 1F55 5E1F 115E 0011 0A00 200A 2020 2020 2020 2020 2020 0020 0000 0000 FC00 00FC 0070 4200 6542 6E65 516E 2051 4720 3247 3432 3034 3030 5730 0A57 200A 0020 C600 FFC6 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00FF ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B02-D04 ]------ 0000 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0010 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0020 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0030 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0040 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0050 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0060 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0070 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0080 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0090 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00A0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00B0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00C0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00D0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00E0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00F0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ------[ nVIDIA SMBus Device GPU #1 / B02-D04 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B02-D37 ]------ 0000 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0010 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0020 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0030 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0040 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0050 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0060 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0070 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0080 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0090 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00A0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00B0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00C0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00D0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00E0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00F0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy ------[ nVIDIA SMBus Device GPU #1 / B02-D37 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B02-D3A ]------ 0000 09 0E BE 4D 9B 00 00 00 00 00 00 00 00 00 00 00 ...M............ 0010 7B FF DF FA 6B 00 00 00 5B AA 7F 76 5E 2A FB FC {...k...[.v^*.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D3A ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B02-D4A ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 94 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 00 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D4A ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B02-D4B ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 95 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 00 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D4B ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B02-D50 ]------ 0000 00 FF FF FF FF FF FF 00 09 D1 0A 78 45 54 00 00 ...........xET.. 0010 2E 12 01 03 80 34 20 78 2E C5 C4 A3 57 4A 9C 23 .....4 x....WJ.# 0020 12 4F 52 A5 6B 80 71 00 81 00 95 00 81 80 B3 00 .OR.k.q......... 0030 A9 40 D1 00 01 01 28 3C 80 A0 70 B0 23 40 30 20 .@....(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4C 42 38 6..D!........LB8 0050 30 34 39 36 37 53 4C 30 0A 20 00 00 00 FD 00 32 04967SL0. .....2 0060 55 1F 5E 11 00 0A 20 20 20 20 20 20 00 00 00 FC U.^... .... 0070 00 42 65 6E 51 20 47 32 34 30 30 57 0A 20 00 C6 .BenQ G2400W. .. 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA SMBus Device GPU #1 / B02-D50 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B02-D51 ]------ 0000 00 FF FF FF FF FF FF 00 10 AC 17 A0 53 44 4E 31 ............SDN1 0010 15 10 01 03 80 34 21 78 EE EE 91 A3 54 4C 99 26 .....4!x....TL.& 0020 0F 50 54 A5 4B 00 81 80 A9 40 71 4F B3 00 01 01 .PT.K....@qO.... 0030 01 01 01 01 01 01 28 3C 80 A0 70 B0 23 40 30 20 ......(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4D 57 37 6..D!........MW7 0050 39 36 36 35 4E 31 4E 44 53 20 00 00 00 FD 00 38 9665N1NDS .....8 0060 4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC L.S... .... 0070 00 44 45 4C 4C 20 32 34 30 37 57 46 50 0A 00 77 .DELL 2407WFP..w 0080 02 03 1A 72 47 85 02 03 04 01 06 07 23 09 07 07 ...rG.......#... 0090 83 01 00 00 65 03 0C 00 10 00 01 1D 00 72 51 D0 ....e........rQ. 00A0 1E 20 6E 28 55 00 B4 86 21 00 00 1E D6 09 80 A0 . n(U...!....... 00B0 20 E0 2D 10 10 60 A2 00 08 86 21 00 00 18 8C 0A .-..`....!..... 00C0 D0 8A 20 E0 2D 10 10 3E 96 00 B4 86 21 00 00 18 .. .-..>....!... 00D0 8C 0A A0 14 51 F0 16 00 26 7C 43 00 08 86 21 00 ....Q...&|C...!. 00E0 00 98 8C 0A A0 14 51 F0 16 00 26 7C 43 00 B4 86 ......Q...&|C... 00F0 21 00 00 98 00 00 00 00 00 00 00 00 00 00 00 18 !............... ------[ nVIDIA SMBus Device GPU #1 / B02-D51 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B03-D0C ]------ 0000 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0010 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0020 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0030 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0040 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0050 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0060 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0070 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0080 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 0090 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00A0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00B0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00C0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00D0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00E0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] 00F0 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D 5D ]]]]]]]]]]]]]]]] ------[ nVIDIA SMBus Device GPU #1 / B03-D0C ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA SMBus Device GPU #1 / B03-D2E ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 FF C1 00 00 6F 6D 6F 7C 06 FF FF FF FF FF FF .....omo|....... 0030 E8 00 00 94 62 A4 00 00 FF FF FF 00 00 73 41 69 ....b........sAi 0040 45 D0 10 1F 00 FF 00 FF 00 FF 00 FF 00 FF 8A 9E E............... 0050 54 7C 90 A9 FF FF FF FF 00 80 FF FF E2 80 80 D8 T|.............. 0060 CC CC 20 00 8C 80 80 81 64 9A A1 A4 AB 01 00 00 .. .....d....... 0070 00 00 00 00 CF FF 2C F8 1E 00 00 55 30 01 00 00 ......,....U0... 0080 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B03-D2E ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Via Driver/NVAPI ------[ AIDA64 v1.20.1165 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7600 (64-bit) ]------ ------[ Video Adapters ]------ EVGA e-GeForce GTX 275 [10DE-05E6 / 3842-1171] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B00-D26 ]------ 0000 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 ................ 0010 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 ........... !"#$ 0020 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 %&'()*+,-./01234 0030 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 56789:;<=>?@ABCD 0040 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 EFGHIJKLMNOPQRST 0050 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 UVWXYZ[\]^_`abcd 0060 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 efghijklmnopqrst 0070 75 76 77 78 79 7A 7B 7C 7D 7E 7F 80 81 82 83 84 uvwxyz{|}~..... 0080 85 86 87 88 89 8A 8B 8C 8D 8E 8F 90 91 92 93 94 ................ 0090 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 A4 ................ 00A0 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 B1 B2 B3 B4 ................ 00B0 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 C2 C3 C4 ................ 00C0 C5 C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 D4 ................ 00D0 D5 D6 D7 D8 D9 DA DB DC DD DE DF E0 E1 E2 E3 E4 ................ 00E0 E5 E6 E7 E8 E9 EA EB EC ED EE EF F0 F1 F2 F3 F4 ................ 00F0 F5 F6 F7 F8 F9 FA FB FC FD FE FF 00 01 02 03 04 ................ ------[ nVIDIA SMBus Device GPU #1 / B00-D26 ]------ 0000 0605 0807 0A09 0C0B 0E0D 100F 1211 1413 1615 1817 1A19 1C1B 1E1D 201F 2221 2423 0010 2625 2827 2A29 2C2B 2E2D 302F 3231 3433 3635 3837 3A39 3C3B 3E3D 403F 4241 4443 0020 4645 4847 4A49 4C4B 4E4D 504F 5251 5453 5655 5857 5A59 5C5B 5E5D 605F 6261 6463 0030 6665 6867 6A69 6C6B 6E6D 706F 7271 7473 7675 7877 7A79 7C7B 7E7D 807F 8281 8483 0040 8685 8887 8A89 8C8B 8E8D 908F 9291 9493 9695 9897 9A99 9C9B 9E9D A09F A2A1 A4A3 0050 A6A5 A8A7 AAA9 ACAB AEAD B0AF B2B1 B4B3 B6B5 B8B7 BAB9 BCBB BEBD C0BF C2C1 C4C3 0060 C6C5 C8C7 CAC9 CCCB CECD D0CF D2D1 D4D3 D6D5 D8D7 DAD9 DCDB DEDD E0DF E2E1 E4E3 0070 E6E5 E8E7 EAE9 ECEB EEED F0EF F2F1 F4F3 F6F5 F8F7 FAF9 FCFB FEFD 00FF 0201 0403 0080 0605 0807 0A09 0C0B 0E0D 100F 1211 1413 1615 1817 1A19 1C1B 1E1D 201F 2221 2423 0090 2625 2827 2A29 2C2B 2E2D 302F 3231 3433 3635 3837 3A39 3C3B 3E3D 403F 4241 4443 00A0 4645 4847 4A49 4C4B 4E4D 504F 5251 5453 5655 5857 5A59 5C5B 5E5D 605F 6261 6463 00B0 6665 6867 6A69 6C6B 6E6D 706F 7271 7473 7675 7877 7A79 7C7B 7E7D 807F 8281 8483 00C0 8685 8887 8A89 8C8B 8E8D 908F 9291 9493 9695 9897 9A99 9C9B 9E9D A09F A2A1 A4A3 00D0 A6A5 A8A7 AAA9 ACAB AEAD B0AF B2B1 B4B3 B6B5 B8B7 BAB9 BCBB BEBD C0BF C2C1 C4C3 00E0 C6C5 C8C7 CAC9 CCCB CECD D0CF D2D1 D4D3 D6D5 D8D7 DAD9 DCDB DEDD E0DF E2E1 E4E3 00F0 E6E5 E8E7 EAE9 ECEB EEED F0EF F2F1 F4F3 F6F5 F8F7 FAF9 FCFB FEFD 00FF 0201 0403 ------[ nVIDIA SMBus Device GPU #1 / B00-D50 ]------ 0000 00 FF FF FF FF FF FF 00 06 09 01 00 BB 06 00 00 ................ 0010 23 0B 01 02 0C 1F 17 C3 EA 9F DE A2 55 48 9A 26 #...........UH.& 0020 11 47 4F AF CE 00 45 59 61 59 81 80 01 01 01 01 .GO...EYaY...... 0030 01 01 01 01 01 01 EA 24 00 60 41 00 28 30 30 60 .......$.`A.(00` 0040 13 00 36 E6 10 00 00 00 00 00 00 FC 00 41 63 65 ..6..........Ace 0050 72 20 56 37 37 31 0A 20 20 20 00 00 00 FF 00 30 r V771. .....0 0060 31 37 32 33 0A 20 20 20 20 20 20 20 00 00 00 FD 1723. .... 0070 00 32 78 1E 48 0B 00 0A 20 20 20 20 20 20 00 7E .2x.H... .~ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA SMBus Device GPU #1 / B00-D50 ]------ 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 0600 0906 0109 0001 BB00 06BB 0006 0000 2300 0010 0B23 010B 0201 0C02 1F0C 171F C317 EAC3 9FEA DE9F A2DE 55A2 4855 9A48 269A 1126 0020 4711 4F47 AF4F CEAF 00CE 4500 5945 6159 5961 8159 8081 0180 0101 0101 0101 0101 0030 0101 0101 0101 0101 0101 EA01 24EA 0024 6000 4160 0041 2800 3028 3030 6030 1360 0040 0013 3600 E636 10E6 0010 0000 0000 0000 0000 0000 FC00 00FC 4100 6341 6563 7265 0050 2072 5620 3756 3737 3137 0A31 200A 2020 2020 0020 0000 0000 FF00 00FF 3000 3130 0060 3731 3237 3332 0A33 200A 2020 2020 2020 2020 2020 2020 0020 0000 0000 FD00 00FD 0070 3200 7832 1E78 481E 0B48 000B 0A00 200A 2020 2020 2020 2020 2020 0020 7E00 4B7E 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA SMBus Device GPU #1 / B01-D04 ]------ 0000 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0010 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0020 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0030 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0040 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0050 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0060 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0070 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0080 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 0090 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00A0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00B0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00C0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00D0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00E0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 00F0 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F ------[ nVIDIA SMBus Device GPU #1 / B01-D04 ]------ 0000 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0010 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0020 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0030 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0040 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0050 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0060 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0070 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0080 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 0090 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 00A0 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 00B0 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 00C0 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 00D0 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 00E0 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 00F0 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F 7F7F ------[ nVIDIA SMBus Device GPU #1 / B01-D37 ]------ 0000 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0010 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0020 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0030 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0040 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0050 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0060 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0070 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0080 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 0090 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00A0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00B0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00C0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00D0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00E0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy 00F0 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 79 yyyyyyyyyyyyyyyy ------[ nVIDIA SMBus Device GPU #1 / B01-D37 ]------ 0000 7979 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0010 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0020 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0030 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0040 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0050 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0060 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0070 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0080 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 0090 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 00A0 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 00B0 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 00C0 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 00D0 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 00E0 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 00F0 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 7969 ------[ nVIDIA SMBus Device GPU #1 / B01-D3A ]------ 0000 09 0E BE 4D 9B 00 00 00 00 00 00 00 00 00 00 00 ...M............ 0010 7B FF DF FA 6B 00 00 00 5B AA 7F 76 5E 2A FB FC {...k...[.v^*.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 91 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D3A ]------ 0000 0E09 BE0E 4DBE 9B4D 009B 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 7B00 0010 FF7B DFFF FADF 6BFA 006B 0000 0000 5B00 AA5B 7FAA 767F 5E76 2A5E FB2A FCFB 00FC 0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 9100 0040 0091 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0900 ------[ nVIDIA SMBus Device GPU #1 / B01-D4A ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 94 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 59 34 00 00 00 00 00 00 00 00 00 00 00 00 ..Y4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D4A ]------ 0000 4000 4141 1F1F 3F3F 7070 C0C0 0000 0000 0000 0202 C0C0 0000 C0C0 FCFC FCFC FCFC 0010 C1C1 0202 1010 0C0C 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0020 0202 0000 0000 0202 0000 0000 0000 6F6F FFFF 0000 0000 0000 0D0D 0000 0000 0000 0030 8080 0000 0000 0000 0000 2424 0000 9494 8080 0000 0000 0000 0000 0000 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0101 0000 0000 0101 0000 0000 0101 0000 0101 0101 0101 0101 0101 0101 0000 0101 0060 0101 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 5959 3434 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 B2B2 7D7D 4040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 9999 AAAA 8989 2626 5555 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0202 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ------[ nVIDIA SMBus Device GPU #1 / B01-D4B ]------ 0000 40 41 1F 3F 70 C0 00 00 00 02 C0 00 C0 FC FC FC @A.?p........... 0010 C1 02 10 0C 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 02 00 00 02 00 00 00 6F FF 00 00 00 0D 00 00 00 .......o........ 0030 80 00 00 00 00 24 00 95 80 00 00 00 00 00 00 00 .....$.......... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 01 00 00 01 00 00 01 00 01 01 01 01 01 01 00 01 ................ 0060 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 34 00 00 00 00 00 00 00 00 00 00 00 00 ...4............ 00A0 B2 7D 40 00 00 00 00 00 00 00 00 00 00 00 00 00 .}@............. 00B0 99 AA 89 26 55 00 00 00 00 00 00 00 00 00 00 00 ...&U........... 00C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D4B ]------ 0000 4140 1F41 3F1F 703F C070 00C0 0000 0000 0200 C002 00C0 C000 FCC0 FCFC FCFC C1FC 0010 02C1 1002 0C10 000C 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0200 0020 0002 0000 0200 0002 0000 0000 6F00 FF6F 00FF 0000 0000 0D00 000D 0000 0000 8000 0030 0080 0000 0000 0000 2400 0024 9500 8095 0080 0000 0000 0000 0000 0000 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0100 0050 0001 0000 0100 0001 0000 0100 0001 0100 0101 0101 0101 0101 0101 0001 0100 0101 0060 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 5900 3459 0034 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 B200 00A0 7DB2 407D 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 9900 00B0 AA99 89AA 2689 5526 0055 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0200 00C0 0002 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 4000 ------[ nVIDIA SMBus Device GPU #1 / B01-D50 ]------ 0000 00 FF FF FF FF FF FF 00 09 D1 0A 78 45 54 00 00 ...........xET.. 0010 2E 12 01 03 80 34 20 78 2E C5 C4 A3 57 4A 9C 23 .....4 x....WJ.# 0020 12 4F 52 A5 6B 80 71 00 81 00 95 00 81 80 B3 00 .OR.k.q......... 0030 A9 40 D1 00 01 01 28 3C 80 A0 70 B0 23 40 30 20 .@....(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4C 42 38 6..D!........LB8 0050 30 34 39 36 37 53 4C 30 0A 20 00 00 00 FD 00 32 04967SL0. .....2 0060 55 1F 5E 11 00 0A 20 20 20 20 20 20 00 00 00 FC U.^... .... 0070 00 42 65 6E 51 20 47 32 34 30 30 57 0A 20 00 C6 .BenQ G2400W. .. 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA SMBus Device GPU #1 / B01-D50 ]------ 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 0900 D109 0AD1 780A 4578 5445 0054 0000 2E00 0010 122E 0112 0301 8003 3480 2034 7820 2E78 C52E C4C5 A3C4 57A3 4A57 9C4A 239C 1223 0020 4F12 524F A552 6BA5 806B 7180 0071 8100 0081 9500 0095 8100 8081 B380 00B3 A900 0030 40A9 D140 00D1 0100 0101 2801 3C28 803C A080 70A0 B070 23B0 4023 3040 2030 3620 0040 0036 0700 4407 2144 0021 0000 1A00 001A 0000 0000 FF00 00FF 4C00 424C 3842 3038 0050 3430 3934 3639 3736 5337 4C53 304C 0A30 200A 0020 0000 0000 FD00 00FD 3200 5532 0060 1F55 5E1F 115E 0011 0A00 200A 2020 2020 2020 2020 2020 0020 0000 0000 FC00 00FC 0070 4200 6542 6E65 516E 2051 4720 3247 3432 3034 3030 5730 0A57 200A 0020 C600 FFC6 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00FF ------[ nVIDIA SMBus Device GPU #1 / B01-D51 ]------ 0000 00 FF FF FF FF FF FF 00 10 AC 17 A0 53 44 4E 31 ............SDN1 0010 15 10 01 03 80 34 21 78 EE EE 91 A3 54 4C 99 26 .....4!x....TL.& 0020 0F 50 54 A5 4B 00 81 80 A9 40 71 4F B3 00 01 01 .PT.K....@qO.... 0030 01 01 01 01 01 01 28 3C 80 A0 70 B0 23 40 30 20 ......(<..p.#@0 0040 36 00 07 44 21 00 00 1A 00 00 00 FF 00 4D 57 37 6..D!........MW7 0050 39 36 36 35 4E 31 4E 44 53 20 00 00 00 FD 00 38 9665N1NDS .....8 0060 4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC L.S... .... 0070 00 44 45 4C 4C 20 32 34 30 37 57 46 50 0A 00 77 .DELL 2407WFP..w 0080 02 03 1A 72 47 85 02 03 04 01 06 07 23 09 07 07 ...rG.......#... 0090 83 01 00 00 65 03 0C 00 10 00 01 1D 00 72 51 D0 ....e........rQ. 00A0 1E 20 6E 28 55 00 B4 86 21 00 00 1E D6 09 80 A0 . n(U...!....... 00B0 20 E0 2D 10 10 60 A2 00 08 86 21 00 00 18 8C 0A .-..`....!..... 00C0 D0 8A 20 E0 2D 10 10 3E 96 00 B4 86 21 00 00 18 .. .-..>....!... 00D0 8C 0A A0 14 51 F0 16 00 26 7C 43 00 08 86 21 00 ....Q...&|C...!. 00E0 00 98 8C 0A A0 14 51 F0 16 00 26 7C 43 00 B4 86 ......Q...&|C... 00F0 21 00 00 98 00 00 00 00 00 00 00 00 00 00 00 18 !............... ------[ nVIDIA SMBus Device GPU #1 / B01-D51 ]------ 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 1000 AC10 17AC A017 53A0 4453 4E44 314E 1531 0010 1015 0110 0301 8003 3480 2134 7821 EE78 EEEE 91EE A391 54A3 4C54 994C 2699 0F26 0020 500F 5450 A554 4BA5 004B 8100 8081 A980 40A9 7140 4F71 B34F 00B3 0100 0101 0101 0030 0101 0101 0101 0101 0101 2801 3C28 803C A080 70A0 B070 23B0 4023 3040 2030 3620 0040 0036 0700 4407 2144 0021 0000 1A00 001A 0000 0000 FF00 00FF 4D00 574D 3757 3937 0050 3639 3636 3536 4E35 314E 4E31 444E 5344 2053 0020 0000 0000 FD00 00FD 3800 4C38 0060 1E4C 531E 1153 0011 0A00 200A 2020 2020 2020 2020 2020 0020 0000 0000 FC00 00FC 0070 4400 4544 4C45 4C4C 204C 3220 3432 3034 3730 5737 4657 5046 0A50 000A 7700 0277 0080 0302 1A03 721A 4772 8547 0285 0302 0403 0104 0601 0706 2307 0923 0709 0707 8307 0090 0183 0001 0000 6500 0365 0C03 000C 1000 0010 0100 1D01 001D 7200 5172 D051 1ED0 00A0 201E 6E20 286E 5528 0055 B400 86B4 2186 0021 0000 1E00 D61E 09D6 8009 A080 20A0 00B0 E020 2DE0 102D 1010 6010 A260 00A2 0800 8608 2186 0021 0000 1800 8C18 0A8C D00A 00C0 8AD0 208A E020 2DE0 102D 1010 3E10 963E 0096 B400 86B4 2186 0021 0000 1800 8C18 00D0 0A8C A00A 14A0 5114 F051 16F0 0016 2600 7C26 437C 0043 0800 8608 2186 0021 0000 00E0 9800 8C98 0A8C A00A 14A0 5114 F051 16F0 0016 2600 7C26 437C 0043 B400 86B4 2186 00F0 0021 0000 9800 0098 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1800 0018 ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ GPU Register Dump ------[ AIDA64 v1.20.1165 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7600 (64-bit) ]------ ------[ Video Adapters ]------ EVGA e-GeForce GTX 275 [10DE-05E6 / 3842-1171] ------[ Video Driver ]------ nvapi.dll: 8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 nvd3dumx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvwgf2umx||8.17.12.6306|||nvd3dum||8.17.12.6306 - nVIDIA ForceWare 263.06|||nvwgf2um||8.17.12.6306|||nvwgf2um||8.17.12.6306 ------[ nVIDIA GPU #1 @ mem F2000000 ]------ GPU Clocks = 400 / 799 / 0 MHz Memory Clock = 297 MHz GPU Base Clock = 27000 kHz Shader Base Clock = 27000 kHz Memory Base Clock = 27000 kHz nvidia-000000 = 0A0300B1 nvidia-0010F0 = 00000000 nvidia-001218 = 00000000 nvidia-001540 = F77F03FF nvidia-0015F4 = 00000000 nvidia-0015F8 = 00000000 nvidia-0015FC = 00000000 nvidia-001600 = 00000000 nvidia-001850 = 00000000 nvidia-004000 = 80000000 nvidia-004004 = 00002008 nvidia-004008 = 90826400 nvidia-00400C = 00001602 nvidia-004018 = 00001200 nvidia-00401C = 00001C03 nvidia-004020 = 00000000 nvidia-004024 = 00002903 nvidia-004028 = 80090000 nvidia-00402C = 00002505 nvidia-00C040 = 2200DBA3 nvidia-00E114 = 00000001 nvidia-00E118 = 00000000 nvidia-00E11C = 00000200 nvidia-00E120 = 00000000 nvidia-020008 = C00800C0 nvidia-020014 = FE0202EE nvidia-020400 = 00000000 nvidia-100000 = 0000C042 nvidia-100200 = 00001800 nvidia-10020C = 38000000 nvidia-100214 = 22222222 nvidia-100474 = 00000000 nvidia-100714 = 00033222 nvidia-100914 = 0F0F0F0F nvidia-101000 = 8F4098AE nvidia-300000 = EB80AA55 nvidia-310000 = EB80AA55 nvidia-700000 = 00000000 nvidia-7E0000 = EB7EAA55 ------[ nVIDIA GPU #1 / ForceWare Properties ]------ Memory Type = 5 (GDDR3) Memory Bank Count = 1 Memory Bus Width = 448-bit GPU / MC / VE Load = 4 / 2 / 0 VPE Count = 0 Shader Pipe Count = 10 Shader SubPipe Count = 3 Total SP Count = 240 Total TPC Count = 10 Total SM Count = 30 Core Count = 240 Partition Count = 7 Fan RPM = <unknown> Core Voltage = 1050 mV Current Pstate = 8 Ventura State = 0 (unsupported) Physical Frame Buffer Size = 917504 KB Virtual Frame Buffer Size = 3801088 KB Total / Free Video Memory = 917504 KB / 553168 KB ------[ nVIDIA GPU #1 / ForceWare Clocks ]------ Perf. Levels = 3 Active Profile = 1 curr-core/shader/mem-0 = 300 MHz / 600 MHz / 100 MHz curr-core/shader/mem-1 = 400 MHz / 800 MHz / 300 MHz [Active] curr-core/shader/mem-2 = 684 MHz / 1476 MHz / 1188 MHz orig-core/shader/mem-0 = 300 MHz / 600 MHz / 100 MHz orig-core/shader/mem-1 = 400 MHz / 800 MHz / 300 MHz [Active] orig-core/shader/mem-2 = 684 MHz / 1476 MHz / 1188 MHz ------[ nVIDIA GPU #1 / BIOS Info ]------ BIOS Version = 62.00.60.00.70 Signon Message = NVIDIA GeForce GTX 275 Bootup Core Clock = 2147485 MHz Bootup Shader Clock = 3 MHz Bootup Mem Clock = 3758097 MHz Ref. Clock 4000 = 0 kHz = 0 MHz *4 Ref. Clock 4008 = 0 kHz = 0 MHz *4 [Memory] Ref. Clock 4010 = 0 kHz = 0 MHz *4 Ref. Clock 4018 = 0 kHz = 0 MHz *4 Ref. Clock 4020 = 0 kHz = 0 MHz *4 [shader] Ref. Clock 4028 = 0 kHz = 0 MHz *4 [GPU] Ref. Clock 4030 = 0 kHz = 0 MHz *4 Ref. Clock 4038 = 0 kHz = 0 MHz *4 Core Clock = 300 MHz Shader Clock = 600 MHz Mem Clock = 100 MHz Geom. Delta = 44 MHz Core Voltage = 0.00 V Fan Speed = 100 % Core Clock = 0 MHz Shader Clock = 0 MHz Mem Clock = 0 MHz Geom. Delta = 0 MHz Core Voltage = 0.00 V Fan Speed = 100 % Core Clock = 400 MHz Shader Clock = 800 MHz Mem Clock = 300 MHz Geom. Delta = 144 MHz Core Voltage = 0.00 V Fan Speed = 100 % Core Clock = 684 MHz Shader Clock = 1476 MHz Mem Clock = 1188 MHz Geom. Delta = 172 MHz Core Voltage = 0.00 V Fan Speed = 100 % Diode Gain Mul = 0 Diode Gain Div = 0 Diode Offset Mul = 0 Diode Offset Div = 0 Diode Offset Bin Mul = 0 Diode Offset Bin Div = 1 Temp Compensation Mul = 8 Temp Compensation Div = 1 Max Div = 0 Measured Temp Threshold (Raw) = 0 Measured Temp Threshold (Int) = 0 Celsius Measured Temp Threshold (Float) = 0 Celsius BIOS Temp Threshold = 105 Celsius Measured Diode Temp (Raw) = 0 Measured Diode Temp (Int) = 0 Celsius Measured Diode Temp (Float) = 0 Celsius Diode Temp by ForceWare = 55 Celsius ------[ NVAPI GPU Handles ]------ GPU Count = 1 GPU #1 = BB000200 ------[ nVIDIA GPU #1 / Thermal Settings ]------ Sensor Count = 2 Sensor #0 / Controller = VBIOSEVT Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 55 Celsius Sensor #1 / Controller = VBIOSEVT Sensor #1 / Target = GPU Board Ambient Sensor #1 / Current Temp = 45 Celsius Quote
Squall Leonhart Posted December 10, 2010 Author Posted December 10, 2010 hmm, i don't think this is a driver issue since other apps that use nvapi can see the gpu speed and voltage fine. Quote
Fiery Posted December 13, 2010 Posted December 13, 2010 Apparently this issue is due to the usage of synchronization mutexes across those monitoring software. An initiative started to re-standardize the mutexes, using Global namespace: http://www.techpowerup.com/wiki/doku.php/systool/mutexes_to_avoid_collisions Most monitoring software has already been adjusted accordingly, but Rivatuner, MSI Afterburner and EVGA Precision are still behind. We've already contacted the author of those software, and been promised their next release will move to using Global namespace. Until that happens, please try to avoid running those software and AIDA64 simultaneously, if possible. Regards, Fiery Quote
