Incorrect sensor display problems since about 2 versions ago (CPU and RAM MHz)
Hi
I just recently discovered this problem with Aida64 Extreme on my PC, MSI X99A SLI Krait Edition mobo with a Intel 5820K CPU, do not remember the make of the RAM, do not have the details here.
The bug/problem:
Last few weeks, or so, I am not sure for how long, I just noticed it a few days ago, I have had a problem with Aida64 reporting wrong CPU MHz, and RAM memory speeds. The CPU is OCed to 4,2 GHz but show in my 'webdisplay' on my other PC that uses the http web display, about 41XX MHz or so. RAM is OCed to 2666, but shows about 25XX MHz. But if I use Afterburner + Statistics, using the AIda64 dll as source, Afterburner shows the correct MHZ, both for CPU and RAM.
The problem is still there in the new version I installed yesterday; v6.32.
Anyone have any ideas why this suddenly started to happen a few weeks ago, or so (I simply do not know when it started, as I just noticed it as few days ago). Has been like this for at least a couple versions, and I have no idea why it started.
5 hours ago, JarleH said:
Hi
The bug/problem:
Such issues may occur when the BCLK is measured too low due to virtualization or other trick that affects the CPU running mode and puts AIDA64 into a virtual environment or sandbox.  Do you think that could be the case for your system?
My point here is that it has worked just fine for months, then for some reason, most likely a couple weeks back, or maybe a bit more, it started to show too low MHz. During this time I have not made changes to the hardware, only changes has been Windows updates.
It MAY have become like this due to updating Aida64 one version prior to version v6.32, I do not know which versions it was, but I do remember updating AIda64 a few weeks back. So it MAY have started then, but I do not know for sure. I just started to notice this in the version before v6.32.
I am having the exact same issue with BCLK frequency showing as 24MHz rather than 100MHz, which results in 9900k frequency showing as 1176MHz rather than 4900MHz.  I have no virtualization running on my windows 10 home system, so not sure what is causing the issue.
Did you also just realize this, or have you had it for a while? I noticed the problem a few weeks back.
We suspect this is due to a Windows 10 update that prevents AIDA64 from measuring BCLK properly.  We're still investigating this...
Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Thank you! Sorry for missing this, I will try to follow up later today.
A bit late, but here it is:
------[ Versions ]------
Program Version : AIDA64 Extreme v6.32.5600
BenchDLL Version: 4.5.841.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19042.746 (64-bit)
GetProductInfo  : 0x00000030
------[ CPU Info ]------
CPU Type          : HexaCore Intel Core i7-5820K, 4133 MHz (42 x 98)
CPU Alias         : Haswell-E
CPU Platform      : LGA2011-v3
CPU Stepping      : R2
Instruction Set   : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2, FMA, AES
CPUID Manufacturer: GenuineIntel
CPUID CPU Name    : Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
CPUID Revision    : 000306F2h
IA Brand ID       : 00h  (Unknown)
Platform ID       : 57h  (LGA2011-v3)
HTT / CMP Units   : 2 / 6
Max. NUMA Node    : 0
Tjmax Temperature          : 100 Celsius
HTC Temperature Limit      : 0 Celsius
CPU TDP                    : 140 W
DRAM TDP                   : 24.5 W
CPU TDC                    : Unlimited
CPU Max Power Limit        : Unlimited Power / Unlimited Time
CPU Power Limit 1 (Long)   : 4095 W / 16.00 sec  (Unlocked)
CPU Power Limit 2 (Short)  : 4095 W / 7.81 ms  (Unlocked)
Max Turbo Boost Multipliers: 1C: 42x, 2C: 42x, 3C: 42x, 4C: 42x, 5C: 42x, 6C: 42x
Motherboard ID      : 63-0100-000001-00101111-091015-Chipset$0AAAA000_BIOS DATE: 06/15/18 08:28:41 VER: VN.90
Motherboard Model   : MSI X99A SLI Krait Edition (MS-7885)
Motherboard Chipset : Intel Wellsburg X99, Intel Haswell-E
DMI MB Manufacturer : MSI
DMI MB Product      : X99A SLI Krait Edition (MS-7885)
DMI MB Version      : 4.0
DMI MB Serial       : Default string
DMI SYS Manufacturer: MSI
DMI SYS Product     : MS-7885
DMI SYS Version     : 4.0
DMI SYS Serial      : Default string
DMI BIOS Version    : N.90
------[ CPUID Registers / Logical CPU #0 ]------
allcpu: Package 0 / Core 0 / Thread 0: Valid
CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel]
CPUID 00000001: 000306F2-00100800-FEDAF383-BFCBFBFF
CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000
CPUID 00000003: 00000000-00000000-00000000-00000000
CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [SL 00] [L1D: 32 KB]
CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [SL 01] [L1I: 32 KB]
CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [SL 02] [L2U: 256 KB]
CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000002 [SL 03] [L3U: 15 MB]
CPUID 00000005: 00000000-00000000-00000000-00000000
CPUID 00000006: 00000073-00000002-00000001-00000000
CPUID 00000007: 00000000-000037AB-00000000-BC000400 [SL 00]
CPUID 00000008: 00000000-00000000-00000000-00000000
CPUID 00000009: 00000000-00000000-00000000-00000000
CPUID 0000000A: 07300403-00000000-00000000-00000603
CPUID 0000000B: 00000001-00000002-00000100-00000000 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000000 [SL 01]
CPUID 0000000C: 00000000-00000000-00000000-00000000
CPUID 0000000D: 00000007-00000340-00000340-00000000 [SL 00] [x87]
CPUID 0000000D: 00000001-00000000-00000000-00000000 [SL 01] [SSE]
CPUID 0000000D: 00000100-00000240-00000000-00000000 [SL 02] [AVX]
CPUID 0000000E: 00000000-00000000-00000000-00000000
CPUID 0000000F: 00000000-00000000-00000000-00000000 [SL 00]
CPUID 0000000F: 00000000-00000000-00000000-00000000 [SL 01]
CPUID 40000000: 4000000B-7263694D-666F736F-76482074 [Microsoft Hv]
CPUID 40000001: 31237648-00000000-00000000-00000000 [Hv#1]
CPUID 40000002: 00004A61-000A0000-00000000-000002EA
CPUID 40000003: 00003FFF-002BB9FF-00000002-35FFFBF6
CPUID 40000004: 00062D1C-00000000-0000002E-00000000
CPUID 40000005: 00000400-00000400-0000096C-00000000
CPUID 40000006: 003A00AF-00000000-00000000-00000000
CPUID 40000007: 80000007-00000003-00000000-00000000
CPUID 40000008: 00000000-00000000-00000000-00000000
CPUID 40000009: 00000000-00000000-00000000-00000000
CPUID 4000000A: 00000000-00000000-00000000-00000000
CPUID 4000000B: 00000000-00000000-00000000-00000000
CPUID 80000000: 80000008-00000000-00000000-00000000
CPUID 80000001: 00000000-00000000-00000021-2C100800
CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [Intel(R) Core(TM]
CPUID 80000003: 37692029-3238352D-43204B30-40205550 [) i7-5820K CPU @]
CPUID 80000004: 332E3320-7A484730-00000000-00000000 [ 3.30GHz]
CPUID 80000005: 00000000-00000000-00000000-00000000 [L1D: 0 KB / L1I: 0 KB]
CPUID 80000006: 00000000-00000000-01006040-00000000 [L2: 256 KB] / L3: 0 KB]
CPUID 80000007: 00000000-00000000-00000000-00000100
CPUID 80000008: 0000302E-00000000-00000000-00000000
L1    Data Cache:    32 KB,  8-way Associative, 64-byte Line
L1  Instr. Cache:    32 KB,  8-way Associative, 64-byte Line
L2 Unified Cache:   256 KB,  8-way Associative, 64-byte Line
L3 Unified Cache:    15 MB, 20-way Associative, 64-byte Line
------[ CPUID Registers / Logical CPU #1 ]------
allcpu: Package 0 / Core 0 / Thread 1: Valid, Virtual
CPUID 00000001: 000306F2-01100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000001 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000001 [SL 01]
------[ CPUID Registers / Logical CPU #2 ]------
allcpu: Package 0 / Core 1 / Thread 0: Valid
CPUID 00000001: 000306F2-02100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000002 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000002 [SL 01]
------[ CPUID Registers / Logical CPU #3 ]------
allcpu: Package 0 / Core 1 / Thread 1: Valid, Virtual
CPUID 00000001: 000306F2-03100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000003 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000003 [SL 01]
------[ CPUID Registers / Logical CPU #4 ]------
allcpu: Package 0 / Core 2 / Thread 0: Valid
CPUID 00000001: 000306F2-04100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000004 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000004 [SL 01]
------[ CPUID Registers / Logical CPU #5 ]------
allcpu: Package 0 / Core 2 / Thread 1: Valid, Virtual
CPUID 00000001: 000306F2-05100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000005 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000005 [SL 01]
------[ CPUID Registers / Logical CPU #6 ]------
allcpu: Package 0 / Core 3 / Thread 0: Valid
CPUID 00000001: 000306F2-06100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000006 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000006 [SL 01]
------[ CPUID Registers / Logical CPU #7 ]------
allcpu: Package 0 / Core 3 / Thread 1: Valid, Virtual
CPUID 00000001: 000306F2-07100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000007 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000007 [SL 01]
------[ CPUID Registers / Logical CPU #8 ]------
allcpu: Package 0 / Core 4 / Thread 0: Valid
CPUID 00000001: 000306F2-08100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000008 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000008 [SL 01]
------[ CPUID Registers / Logical CPU #9 ]------
allcpu: Package 0 / Core 4 / Thread 1: Valid, Virtual
CPUID 00000001: 000306F2-09100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000009 [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-00000009 [SL 01]
------[ CPUID Registers / Logical CPU #10 ]------
allcpu: Package 0 / Core 5 / Thread 0: Valid
CPUID 00000001: 000306F2-0A100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-0000000A [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-0000000A [SL 01]
------[ CPUID Registers / Logical CPU #11 ]------
allcpu: Package 0 / Core 5 / Thread 1: Valid, Virtual
CPUID 00000001: 000306F2-0B100800-FEDAF383-BFCBFBFF
CPUID 0000000B: 00000001-00000002-00000100-0000000B [SL 00]
CPUID 0000000B: 00000004-0000000C-00000201-0000000B [SL 01]
------[ All CPUs ]------
CPU   0: APICID    0 / Package 0 / Core   0 / Thread 0: Valid
CPU   1: APICID    1 / Package 0 / Core   0 / Thread 1: Valid, Virtual
CPU   2: APICID    2 / Package 0 / Core   1 / Thread 0: Valid
CPU   3: APICID    3 / Package 0 / Core   1 / Thread 1: Valid, Virtual
CPU   4: APICID    4 / Package 0 / Core   2 / Thread 0: Valid
CPU   5: APICID    5 / Package 0 / Core   2 / Thread 1: Valid, Virtual
CPU   6: APICID    6 / Package 0 / Core   3 / Thread 0: Valid
CPU   7: APICID    7 / Package 0 / Core   3 / Thread 1: Valid, Virtual
CPU   8: APICID    8 / Package 0 / Core   4 / Thread 0: Valid
CPU   9: APICID    9 / Package 0 / Core   4 / Thread 1: Valid, Virtual
CPU  10: APICID   10 / Package 0 / Core   5 / Thread 0: Valid
CPU  11: APICID   11 / Package 0 / Core   5 / Thread 1: Valid, Virtual
------[ MSR Registers / Logical CPU #0 ]------
MSR 00000017: 0008-0000-0000-0000 [PlatID = 2]
MSR 0000001B: 0000-0000-FEE0-0900
MSR 00000035: 0000-0000-0006-000C
MSR 00000048: 0000-0000-0000-0000
MSR 00000049: < FAILED >
MSR 0000008B: 0000-0043-0000-0000
MSR 000000CE: 2008-0C3B-F381-2100 [eD = 0]
MSR 000000E7: 0000-0043-BAB6-D085 [S200]
MSR 000000E7: 0000-0043-C36E-DAE4 [S200]
MSR 000000E7: 0000-0043-CFA2-B155
MSR 000000E8: 0000-004E-D301-2F0A [S200]
MSR 000000E8: 0000-004E-E0B4-2728 [S200]
MSR 000000E8: 0000-004E-ED64-9E5C
MSR 0000010A: 0000-0000-0000-0000
MSR 0000010B: < FAILED >
MSR 00000194: 0000-0000-000E-0000
MSR 00000198: 0000-2899-0000-2A00 [S200]
MSR 00000199: 0000-0000-0000-FF00
MSR 0000019A: 0000-0000-0000-0000
MSR 0000019B: 0000-0000-0000-0000
MSR 0000019C: 0000-0000-8839-0000 [S200]
MSR 0000019C: 0000-0000-8838-0000 [S200]
MSR 0000019D: 0000-0000-0000-0000
MSR 000001A0: 0000-0000-0085-1889
MSR 000001A2: 0000-0000-0064-0A00
MSR 000001A4: 0000-0000-0000-0000
MSR 000001AA: 0000-0000-0040-0000
MSR 000001AC: < FAILED >
MSR 000001AD: 2222-2A2A-2A2A-2A2A
MSR 000001AE: 2222-2222-2222-2222
MSR 000001AF: 0000-0000-0000-2222
MSR 000001B0: < FAILED >
MSR 000001B1: 0000-0000-8832-0000
MSR 000001B2: 0000-0000-0000-0000
MSR 000001FC: 0000-0000-2900-0059
MSR 00000300: 0000-0000-8000-FF00
MSR 0000030A: 0000-061B-A860-A326 [S200]
MSR 0000030A: 0000-061B-B42F-9773 [S200]
MSR 0000030A: 0000-061B-C7FA-0CCD
MSR 0000030B: 0000-05A9-C8FF-A204 [S200]
MSR 0000030B: 0000-05A9-DED9-3032 [S200]
MSR 0000030B: 0000-05A9-ED8F-0B7D
MSR 00000601: 0010-1414-0000-1FFF
MSR 00000602: < FAILED >
MSR 00000603: 0016-0000-001C-1C1C
MSR 00000604: < FAILED >
MSR 00000606: 0000-0000-000A-0E03
MSR 0000060A: 0000-0000-0000-0000
MSR 0000060B: 0000-0000-0000-0000
MSR 0000060C: 0000-0000-0000-0000
MSR 0000060D: 0000-0000-0000-0000
MSR 00000610: 0007-FFF8-001D-FFF8
MSR 00000611: 0000-0000-0EA0-2009 [S200]
MSR 00000611: 0000-0000-0EA3-A0CA [S200]
MSR 00000611: 0000-0000-0EA7-3B10
MSR 00000613: 0000-0000-0000-0001
MSR 00000614: 0000-0000-0128-0460
MSR 00000618: 0000-0000-0000-0000
MSR 00000619: 0000-0000-0000-0000 [S200]
MSR 0000061B: 0000-0000-0000-0000
MSR 0000061C: 002F-0160-002E-00C4
MSR 0000061E: 0000-0000-0000-0000
MSR 00000620: 0000-0000-0000-121E
MSR 00000621: 0000-0000-0000-001E
MSR 00000638: 0000-0000-0000-0000
MSR 00000639: 0000-0000-0000-0000 [S200]
MSR 0000063A: < FAILED >
MSR 0000063B: < FAILED >
MSR 00000640: < FAILED >
MSR 00000641: < FAILED >
MSR 00000642: < FAILED >
MSR 00000648: 0000-0000-0000-0021
MSR 00000649: 0094-0000-001E-0460
MSR 0000064A: 0094-0000-0000-0000
MSR 0000064B: 0000-0000-0000-0000
MSR 0000064C: 0000-0000-0000-0000
MSR 00000690: 0000-0000-E100-0000
MSR 000006B0: < FAILED >
MSR 000006B1: 0000-0000-0000-0000
------[ MSR Registers / Logical CPU #1 ]------
MSR 0000001B: 0000-0000-FEE0-0800
MSR 000000E7: 0000-002C-6C33-BF58
MSR 000000E8: 0000-0037-40F3-FB74
MSR 0000019C: 0000-0000-8835-0000
MSR 000001B1: 0000-0000-8835-0000
MSR 0000030A: 0000-02D7-E431-F620
MSR 0000030B: 0000-0271-E165-2F16
MSR 00000611: 0000-0000-0EB5-37A6
------[ MSR Registers / Logical CPU #2 ]------
MSR 000000E7: 0000-0058-BF63-87C9
MSR 000000E8: 0000-006F-0FB8-40B3
MSR 00000198: 0000-288E-0000-2A00
MSR 0000019C: 0000-0000-883B-0000
MSR 0000030A: 0000-09F3-F69C-1EBC
MSR 0000030B: 0000-08B6-94DC-19F2
MSR 00000611: 0000-0000-0EB5-3C78
------[ MSR Registers / Logical CPU #3 ]------
MSR 000000E7: 0000-001A-0F7A-38D9
MSR 000000E8: 0000-001F-6718-AB85
MSR 000001B1: 0000-0000-8836-0000
MSR 0000030A: 0000-02BA-A49F-3AED
MSR 0000030B: 0000-0278-EF5E-0805
MSR 00000611: 0000-0000-0EB5-40EA
------[ MSR Registers / Logical CPU #4 ]------
MSR 000000E7: 0000-0034-6A1C-097F
MSR 000000E8: 0000-0040-FC82-C981
MSR 00000198: 0000-2884-0000-2A00
MSR 0000030A: 0000-05F3-1792-ECD3
MSR 0000030B: 0000-054F-5159-BBBD
MSR 00000611: 0000-0000-0EB5-45D5
------[ MSR Registers / Logical CPU #5 ]------
MSR 000000E7: 0000-001A-A4D4-25A8
MSR 000000E8: 0000-0020-5B79-AC30
MSR 0000030A: 0000-01CE-63F9-6DF3
MSR 0000030B: 0000-01D4-C30C-DFB6
------[ MSR Registers / Logical CPU #6 ]------
MSR 000000E7: 0000-0030-BC56-9ED3
MSR 000000E8: 0000-003C-3E9B-6389
MSR 00000198: 0000-2885-0000-2A00
MSR 0000019C: 0000-0000-8840-0000
MSR 000001B1: 0000-0000-8837-0000
MSR 0000030A: 0000-047B-6284-D343
MSR 0000030B: 0000-044D-6CFC-14D0
MSR 00000611: 0000-0000-0EB5-4A88
------[ MSR Registers / Logical CPU #7 ]------
MSR 000000E7: 0000-001C-02B4-1526
MSR 000000E8: 0000-0022-07B4-EB1E
MSR 0000030A: 0000-01FB-8256-EFD7
MSR 0000030B: 0000-01D3-AD03-6548
------[ MSR Registers / Logical CPU #8 ]------
MSR 000000E7: 0000-003D-AF98-DE49
MSR 000000E8: 0000-004C-C648-B579
MSR 00000198: 0000-2881-0000-2A00
MSR 0000019C: 0000-0000-883A-0000
MSR 0000030A: 0000-052A-AEB2-5BA2
MSR 0000030B: 0000-04CB-997B-4AD6
MSR 00000611: 0000-0000-0EB5-4F4B
------[ MSR Registers / Logical CPU #9 ]------
MSR 000000E7: 0000-0019-69BE-211A
MSR 000000E8: 0000-001E-B68F-106A
MSR 0000030A: 0000-01FB-4483-F7F4
MSR 0000030B: 0000-01E1-53D4-D0BD
MSR 00000611: 0000-0000-0EB5-537B
------[ MSR Registers / Logical CPU #10 ]------
MSR 000000E7: 0000-0029-51F4-AC4D
MSR 000000E8: 0000-0032-F0D8-D1F9
MSR 0000030A: 0000-033A-4BD5-CDAA
MSR 0000030B: 0000-0325-50A1-A3C3
------[ MSR Registers / Logical CPU #11 ]------
MSR 000000E7: 0000-0030-3C31-A1F7
MSR 000000E8: 0000-003B-BC7B-F3A9
MSR 0000030A: 0000-0365-5283-2153
MSR 0000030B: 0000-0316-CD0D-CF5D
MSR 00000611: 0000-0000-0EB5-57F0
PerformanceFrequency = 10000000
CPU Clock M.Method = 8  (APIC SNB)
PM Timer Address   = 1032  (0408h)
APIC Clock =  98.34 MHz  (AT = 51551 / TT = 15011 / try = 1 / SKL = 0.00 MHz)
CPU Clock = 4130.42 MHz / TSC Clock = 3245.33 MHz / CPU Mul = 42.00x
CPU Clock Max = 4130.42 MHz / TSC Clock = 3245.33 MHz / CPU Mul = 42.00x
INTPERFCTR2 = 4191.73 MHz / INTPERFCTR1 (TSC) = 3293.50 MHz
INTPERFCTR2 = 4195.33 MHz / INTPERFCTR1 (TSC) = 3296.33 MHz
INTPERFCTR2 = 4194.63 MHz / INTPERFCTR1 (TSC) = 3295.79 MHz
INTPERFCTR2 = 4192.57 MHz / INTPERFCTR1 (TSC) = 3294.17 MHz
INTPERFCTR2 = 4193.28 MHz / INTPERFCTR1 (TSC) = 3294.73 MHz
------[ OC MailBox ]------
C 01 / P1 00 / P2 00: 00000750
C 01 / P1 01 / P2 00: 00000000
C 01 / P1 02 / P2 00: 00000750
C 01 / P1 03 / P2 00: 00000400
C 01 / P1 04 / P2 00: 00000000
C 02 / P1 00 / P2 00: 50505050
C 02 / P1 00 / P2 01: < FAILED >
C 02 / P1 00 / P2 02: < FAILED >
C 02 / P1 00 / P2 03: < FAILED >
C 02 / P1 01 / P2 00: 50505050
C 02 / P1 01 / P2 01: < FAILED >
C 02 / P1 01 / P2 02: < FAILED >
C 02 / P1 01 / P2 03: < FAILED >
C 02 / P1 02 / P2 00: 50505050
C 02 / P1 02 / P2 01: < FAILED >
C 02 / P1 02 / P2 02: < FAILED >
C 02 / P1 02 / P2 03: < FAILED >
C 02 / P1 03 / P2 00: 50505050
C 02 / P1 03 / P2 01: < FAILED >
C 02 / P1 03 / P2 02: < FAILED >
C 02 / P1 03 / P2 03: < FAILED >
C 02 / P1 04 / P2 00: 50505050
C 02 / P1 04 / P2 01: < FAILED >
C 02 / P1 04 / P2 02: < FAILED >
C 02 / P1 04 / P2 03: < FAILED >
C 02 / P1 05 / P2 00: 00000000
C 02 / P1 05 / P2 01: < FAILED >
C 02 / P1 05 / P2 02: < FAILED >
C 02 / P1 05 / P2 03: < FAILED >
C 02 / P1 06 / P2 00: 00000000
C 02 / P1 06 / P2 01: < FAILED >
C 02 / P1 06 / P2 02: < FAILED >
C 02 / P1 06 / P2 03: < FAILED >
C 02 / P1 07 / P2 00: 00000000
C 02 / P1 07 / P2 01: < FAILED >
C 02 / P1 07 / P2 02: < FAILED >
C 02 / P1 07 / P2 03: < FAILED >
C 10 / P1 00 / P2 00: 00050A2A
C 10 / P1 01 / P2 00: 00000000
C 10 / P1 02 / P2 00: 00000000
C 10 / P1 03 / P2 00: 2CC00000
C 10 / P1 04 / P2 00: 00000000
C 12 / P1 00 / P2 00: 00000799
C 12 / P1 01 / P2 00: 00000799
C 12 / P1 02 / P2 00: 00000799
C 14 / P1 00 / P2 00: 00000003
C 16 / P1 00 / P2 00: 00000000
C 18 / P1 00 / P2 00: 00000000
C 1A / P1 00 / P2 00: 00000000
C 1C / P1 00 / P2 00: 00000000  [CPU0]
C 1C / P1 00 / P2 00: 00000000  [CPU1]
C 1C / P1 00 / P2 00: 00000000  [CPU2]
C 1C / P1 00 / P2 00: 00000000  [CPU3]
C 1C / P1 00 / P2 00: 00000000  [CPU4]
C 1C / P1 00 / P2 00: 00000000  [CPU5]
C 1C / P1 00 / P2 00: 00000000  [CPU6]
C 1C / P1 00 / P2 00: 00000000  [CPU7]
C 1C / P1 00 / P2 00: 00000000  [CPU8]
C 1C / P1 00 / P2 00: 00000000  [CPU9]
C 1C / P1 00 / P2 00: 00000000  [CPU10]
C 1C / P1 00 / P2 00: 00000000  [CPU11]
Thank you!  Everything looks fine there, but for some reason your motherboard reports the APIC clock (which equals the BCLK clock) as 98.34MHz.  I suppose that causes your issues about the measured clocks being cca. 1.7% lower than what you anticipate seeing.  I'm not sure what could cause that.  Can you see similarly low BCLK reported by CPU-Z as well?
Yeah, CPU-Z says the same thing; low 98.xx buss speed. No idea why, it is set to 100 i bios. Also reloaded the bios settings, same result.
Maybe CMOS problem, need reset? Any other advice?
In many cases it's because of the influence of some sort of virtualization.  If you can, try to deactivate Hyper-V on your system or completely disable CPU virtualization (from the BIOS Setup).
That did it! I do not know why this suddenly became an issue, maybe a Windows update? Or maybe I changed it due to loading a bios setup without knowing about it/remember. But I am pretty sure I have had it enabled for a long time.... Any way, now it was fixed, at least the first boot so far. Disabled Intel VT-D + 1 more Virtualization setting, both at the same place.
Maybe Hyper-V wasn't enabled before, but a certain (most likely major) Windows update may have activated it without your interference or choice.
