There is a problem with the system UI since the December 15th update.
10 minutes ago, rockybearking said:
1. Numbers are not displayed correctly in the remaining memory OSD item.
2. The actual computer fan speed and the OSD value output from the program do not match.
We will fix this issue in the next AIDA64 beta update.  Till then, try to restart AIDA64 to get the values back to normal.  When you have the OSD Panel in justify alignment mode and you turn items on/off, the bug may occur.  In which case it gets back to normal when you restart AIDA64 or when you turn the OSD Panel on/off.
