Maxwell Posted December 16, 2020 Posted December 16, 2020 My Ryzen 5800x is showing base clock as 3600 instead of 3800. Seems to show boost to 4850 ok though. Also is sleep state not supported? Using ipad with Logitech G-hub and arx Quote
Fiery Posted December 16, 2020 Posted December 16, 2020 6 hours ago, Maxwell said: My Ryzen 5800x is showing base clock as 3600 instead of 3800. Seems to show boost to 4850 ok though. Also is sleep state not supported? Using ipad with Logitech G-hub and arx Please show us a screenshot where the incorrect information is displayed. E.g. the Computer / Overclock page or the main menu / Tools / AIDA64 CPUID panel. As for "sleep state not supported?", what do you mean exactly? Can you see an error about that in AIDA64? Also, what motherboard do you have? Are you using the latest AIDA64 version of 6.32? Quote
Maxwell Posted December 17, 2020 Author Posted December 17, 2020 (edited) Its the latest version but did it before update as well. What I meant was core clock never drops to below 3600 and go to sleep like in Ryzen master. Not really concerned about that though more interested why its 3600 base. Have attached pic 20201217_082522653_iOS.heic Edited December 17, 2020 by Maxwell more info Quote
Maxwell Posted December 29, 2020 Author Posted December 29, 2020 The motherboard make and bios is in the file I attached if thats why you havent answered Quote
Fiery Posted January 6, 2021 Posted January 6, 2021 On 12/17/2020 at 9:30 AM, Maxwell said: Its the latest version but did it before update as well. What I meant was core clock never drops to below 3600 and go to sleep like in Ryzen master. Not really concerned about that though more interested why its 3600 base. Have attached pic Thank you. Does the CPU core clock go below 3600 MHz or being indicated as a different value at idle in CPU-Z? Quote
