Aida64 missing Die voltages on Ryzen CPU - CCD and the package
So, started using Aida64 lately because of the LCD functionality and the ability to display the info on my smartphone via USB.
The problem is that Aida64 does not have the temperature reading for Ryzen CPUs, which are the ones Ryzen Master takes - the average temp of the CCDs or the whole die. I know the whole thing with the offset for fan control and stuff, but it will be better to be able to monitor all properly.
Is it possible to add this?
Thanks!
  • 3 weeks later...
Thanks!
What CPU do you have?
  • 2 months later...
similar issue
I have the 5800x.
None of the 3 cpu temp sensors (cpu, package, or diode) match what ryzen master reports.
since that is the temp that throttles the cpu at 90 degrees, its the one we need to monitor.
