AIDA64 Extreme sensor Destroying warzone (Asus Maximus X Hero + Aorus RTX 3080)
Yaniv Kaduri
hello i have ADIA64 Extreme 6.32.5600
all work great But! i use sensors on my little LCD screen
and when i use this "sensorpanel" i have fps drops and little frezzing on Warzone call of duty!
when i cancel the sensor all work fine! i dont need exit aida64 only the sensor...
what is the problem!?! i want use sensor in background but i cant beacus i cant play like this.. so i just cancel it ...
What motherboard and video card(s) do you have?
45 minutes ago, Yaniv Kaduri said:
hello first thank you for helping
i have aorus extreme 3080
and maximus x hero
cpu i7-8700k
... i cant play warzone with the sensor is stuck my game... So i play without the sensors you can fix it?
Try to disable (uncheck) the following two options on the page AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes.
Embedded Controller (EC) support
Embedded Controller (EC) bank switching
Let me know if it helps to get rid of the FPS drops while AIDA64 monitoring sensors.
wow your my king i did only 1 game and is was fix i ill try it more for 100%
Embedded Controller (EC) support (i uncheck)
Embedded Controller (EC) bank switching (this was uncheck)
why Embedded Controller (EC) support make that on warzone and other games?
again i did only 1 game but is was fix the problem
and i never play one time with the sensor and now i can
lets hope i ill can keep play with the sensor thank you i ill give my answer more 1 day after i play 3-4 hours
Certain Asus motherboards have latency issues when 3rd party applications (like AIDA64) try accessing EC (Embedded Controller) registers.  In those cases disabling EC support usually solves the issues.  The only downside is that by disabling EC support you lose a few sensor readings that can only be measured using EC registers.
Ok i play 2-3 all works good so that all? Or i need disabling more items?
  • 1 year later...
  • 2 years later...
I am also having stutter issues while sensor panel is open.  Any advice? Motherboard is Gigabyte B550 UD AC.  I have paid version is Aida Extreme
