Mark Valerio Posted December 30, 2020 Report Share Posted December 30, 2020 I'm running the latest stable version of AIDA64 and in the sensor panel the GPU Frequency blinks on and off, mostly off. When it is there the reading is wrong. Is there something I'm missing? My Radeon VII and RX 5700 XT were displayed just fine. Here are some screen grabs showing sensor panel with and without also add new with GPU Clock and then after it disappears Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 30, 2020 Report Share Posted December 30, 2020 10 hours ago, Mark Valerio said: I'm running the latest stable version of AIDA64 and in the sensor panel the GPU Frequency blinks on and off, mostly off. When it is there the reading is wrong. Is there something I'm missing? My Radeon VII and RX 5700 XT were displayed just fine. Here are some screen grabs showing sensor panel with and without also add new with GPU Clock and then after it disappears Can you please check what your GPU clock is measured by GPU-Z when your video card is idle? I assume that state (idle) is when the GPU clock (as reported by the video driver) falls to zero or some other weird value that AIDA64 cannot interpret as a proper GPU frequency value. Quote Link to comment Share on other sites More sharing options...
Mark Valerio Posted December 31, 2020 Author Report Share Posted December 31, 2020 Here is a screen shot of GPUZ and the sensor panel while gaming. What I'm wondering is why it flashes ion and off the screen. I want to edit the sensor but I have to wait for to decide to show up. Hard to right click if it's not on the screen and I'm not going to edit it while gaming. This was never an issue with my Radeon VII. It was always on the screen Quote Link to comment Share on other sites More sharing options...
Mark Valerio Posted January 4, 2021 Author Report Share Posted January 4, 2021 On 12/30/2020 at 5:41 AM, Fiery said: Can you please check what your GPU clock is measured by GPU-Z when your video card is idle? I assume that state (idle) is when the GPU clock (as reported by the video driver) falls to zero or some other weird value that AIDA64 cannot interpret as a proper GPU frequency value. See above post Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 13, 2021 Report Share Posted January 13, 2021 On 1/4/2021 at 3:28 AM, Mark Valerio said: See above post Thank you! Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. If not, then please right-click on the bottom status bar of AIDA64 main window --> VideoDebug --> ATI GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 12, 2021 Report Share Posted March 12, 2021 On 1/4/2021 at 3:28 AM, Mark Valerio said: See above post We've fixed the flickering GPU clock issue on Radeon RX 6800/6900 video cards in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works for you. Quote Link to comment Share on other sites More sharing options...
apollo4aida Posted March 15, 2021 Report Share Posted March 15, 2021 On 3/12/2021 at 4:38 PM, Fiery said: We've fixed the flickering GPU clock issue on Radeon RX 6800/6900 video cards in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works for you. I still can't see GPU and/or Mem. Clock and Usage of my 6900XT. But i have to admit I'm using 2 GPU's in my system: (3060Ti is displayed as GPU1 and 6900XT as GPU2). atigpureg.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 27, 2021 Report Share Posted March 27, 2021 On 3/15/2021 at 11:20 AM, apollo4aida said: I still can't see GPU and/or Mem. Clock and Usage of my 6900XT. But i have to admit I'm using 2 GPU's in my system: (3060Ti is displayed as GPU1 and 6900XT as GPU2). By default, on ATI/AMD GPUs monitoring the secondary GPU is disabled due to potential major issues about ULPS. You need to disable ULPS and then you can enable Multi-GPU monitoring in AIDA64 / main menu / File / Preferences / Stability. Quote Link to comment Share on other sites More sharing options...
