Athanasios Chonias Posted January 5, 2021 Posted January 5, 2021 Hi everyone, i have an issue with all sensorpanels i try. They look like the attachment and when i import them the size in preferences reverts to 1000x600. DPI scaling is set 100%. This is happening with all panels that i try. My lcd is also 800x480. Any Ideas? Quote
Fiery Posted January 6, 2021 Posted January 6, 2021 13 hours ago, Athanasios Chonias said: Hi everyone, i have an issue with all sensorpanels i try. They look like the attachment and when i import them the size in preferences reverts to 1000x600. DPI scaling is set 100%. This is happening with all panels that i try. My lcd is also 800x480. Any Ideas? You can adjust the SensorPanel resolution in AIDA64 / main menu / File / Preferences / Hardware Monitoring / SensorPanel. Please note that SensorPanel layouts are designed for a specific resolution, and when you import it and want to use a different resolution, you need to adjust the layout accordingly. Quote
