MrNoSpareTime Posted January 11, 2021 Posted January 11, 2021 I have been running the sensor panel for a few weeks and I noticed that the from time to time a fan will show the RPMs drop to 0. I can see the fans and it is spinning, and I can use gigabytes SIV smart fan 5 to adjust the fan speed and I hear the fan ramp to the desired set point. Is this a gigabyte issue or is anyone else seeing this also. Gigabyte x570 arous master - Bios F30 - with 3900x CPU. Thank You Quote
Fiery Posted January 12, 2021 Posted January 12, 2021 13 hours ago, MrNoSpareTime said: I have been running the sensor panel for a few weeks and I noticed that the from time to time a fan will show the RPMs drop to 0. I can see the fans and it is spinning, and I can use gigabytes SIV smart fan 5 to adjust the fan speed and I hear the fan ramp to the desired set point. Is this a gigabyte issue or is anyone else seeing this also. Gigabyte x570 arous master - Bios F30 - with 3900x CPU. Thank You Make sure to check if the fans are really stopped when AIDA64 stops reporting them (or reports them at zero RPM). Quote
MrNoSpareTime Posted March 24, 2021 Author Posted March 24, 2021 It seems like the sensor panel just goes nuts. Fans report 0 and the temps the MB will drop to 0deg or a neg. It never recovers from this state once here the only thing I can do is close the program. Quote
