dnovosel Posted January 13, 2021 Posted January 13, 2021 Is it possible to change the NIC rates displayed on external LCDs? Right now the NIC rates are in KB/s, but I would really prefer MB/s given I'm frequently working at the 100+Mbps range, and with KB/s it's not particularly useful. Note, I'm not concerned with dynamically changing the unit. Just statically selecting the one I want to display when I create the layout. Quote
Fiery Posted January 13, 2021 Posted January 13, 2021 On 1/13/2021 at 1:55 PM, dnovosel said: Is it possible to change the NIC rates displayed on external LCDs? Right now the NIC rates are in KB/s, but I would really prefer MB/s given I'm frequently working at the 100+Mbps range, and with KB/s it's not particularly useful. Note, I'm not concerned with dynamically changing the unit. Just statically selecting the one I want to display when I create the layout. Expand Enter MB/s or Mbps or GB/s or Gbps into the unit field to make it automatically convert the readings. Quote
dnovosel Posted January 13, 2021 Author Posted January 13, 2021 On 1/13/2021 at 2:03 PM, Fiery said: Enter MB/s or Mbps or GB/s or Gbps into the unit field to make it automatically convert the readings. Expand Sweet, thanks! Quote
driskell2000 Posted December 7, 2023 Posted December 7, 2023 Could you please add the ability to adjust the decimal places on the Upload / Download Rates (NIC). On the Preferences > Hardware Monitoring. "Decimal digits for transfer rate:" Quote
