Recently I've purchased Vengeance RGB Pro memory modules (CMW16GX4M2K4000C19) and just found out iCUE SW from Corsair displays modules temperatures:
Seems like AIDA64 doesn't see those temps or did I miss something?
AIDA64 I'm using is v. 6.32.5600
DIMM thermal sensor support is enabled in Stability preferences
Thank you.
Thank you.
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
On 1/15/2021 at 5:54 PM, Elderdeekey said:
Thanks Fiery, attached.
We've checked, and it should work as long as DIMM thermal sensor support is enabled in AIDA64 / main menu / File / Preferences / Stability.  Are you sure it is enabled there?
How do you enumerate thermal sensors?
I have 11 sensors in total:
T_Sensor from ASUS MB
Ext_1 and Ext_2 from ASUS Fan Extension Card (3rd port isn't in use)
4 temperature sensors from 2 Aqua computer MPS flow meters (2 internals and 2 externals)
4 temperature sensors from Aqua computer OCTO fan controller (all externals)
All Aqua computer sensors enumerated as Temperature #1 - #8.
Thank you.
