On 1/16/2021 at 10:56 PM, FuglyOtherMucker said:
As the title says...
Have attached the Sensor Debug Info File. Hope that helps!
thx & cheers
Thank you for the data!  I'm afraid we cannot find any sensor readings among those registers.  This sadly is the case with most laptops, so it's not just yours but most of them out there.  Only Clevo (the original manufacturer of your laptop) would know what registers can be used for fan monitoring, but usually those companies wouldn't reveal such technical details with anyone.
