Hello,
I want to display download and upload rate, however it is stuck to 0 MB/s.
I tried with all NIC available (1 to 4).
It only worked the very first time I added it on my screen, but since, it is stuck at 0 MB/s.
Any ideas ?
4 hours ago, Kakthus said:
Hello,
Any ideas ?
Can you see network activity on any of the NIC's listed on the Network / Windows Network page of AIDA64.
Yes. Screenshot (it is the first one on the list) :
35 minutes ago, Fiery said:
Maybe it's too low in MB/s?
I thought about it but the problem is not there
Here is a screenshot with all settings and result. I'm superposing all NIC so if one is different than 0 I should see it.
On 1/29/2021 at 11:24 PM, Kakthus said:
When I use wifi it works (it changes values for NIC2 download / upload rate). But it doesn't with ethernet.
Maybe the network activity is performed on a different NIC, not NIC1?
  • 2 years later...
I have the same problem. Sometimes after reboot of system I got NIC 1-4, sometimes 1-5, and only 1 of them shows the speed rate. Id be grateful if anyone got a solid solution for this, so you dont have to fiddle with AIDA64 every time after a system restart
  • 1 year later...
