Pained Posted February 27, 2021 Posted February 27, 2021 I have a Corsair H150i RGB Pro XT so far I'm using the beta version of Aida 64 (6.32.5640) I have checked under preferences to show corsair devices and I can only seem to get 2 of my 3 fans for my AIO to show up, is there any way to solve this ? Not sure what logs to include to help solve the issue so please just let me know and ill upload them. Quote
Fiery Posted March 1, 2021 Posted March 1, 2021 On 2/27/2021 at 7:25 PM, Pained said: I have a Corsair H150i RGB Pro XT so far I'm using the beta version of Aida 64 (6.32.5640) I have checked under preferences to show corsair devices and I can only seem to get 2 of my 3 fans for my AIO to show up, is there any way to solve this ? Not sure what logs to include to help solve the issue so please just let me know and ill upload them. Expand Please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Corsair Link Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Pained Posted March 1, 2021 Author Posted March 1, 2021 Here you go, thanks for the response usbdump.txtFetching info... corsairlinkdump.txtFetching info... Quote
Fiery Posted March 12, 2021 Posted March 12, 2021 On 3/1/2021 at 6:38 PM, Pained said: Here you go, thanks for the response Expand Thank you, that looks correct so far. Is there a software like Corsair's own iCUE that can report all 3 fans individually for your AIO device? Quote
Pained Posted March 12, 2021 Author Posted March 12, 2021 On 3/12/2021 at 12:52 PM, Fiery said: Thank you, that looks correct so far. Is there a software like Corsair's own iCUE that can report all 3 fans individually for your AIO device? Expand Yes, I can see each individual fan with icue, I'm even able to control each one individually. I believe hwinfo reports each fans as well but I'd have to double check when I'm near my PC. After checking HWinfo can also read all 3 fans individually. Quote
DayKk_ Posted March 6, 2022 Posted March 6, 2022 Any update here? having the same issue. Will have the coolant temp, the pump speed and only 2 fans. ICUE shows everything. And my commander pro doesn't show up either. I tried running only aida with icue close and the commander doesn't prompt, even after restart. corsairlinkdump.txtFetching info... usbdump.txtFetching info... Quote
Suha Akin Akalan Posted April 17, 2022 Posted April 17, 2022 Having same issue, I have Corsair h150i RGB pro xt version installed in my case. AIDA64 is only showing 2 fans. I can see and configure all the 3 fans from iCUE software individually. @Fiery can you help with this. Quote
JuanH Posted August 16, 2022 Posted August 16, 2022 I'm having the same issue. Corsair h150i RGB pro xt only shows 2 of 3 fans. iCue is able to report on all three, so seems there is a missing value in Aida64. @FieryI'm happy to assit with any info or troubleshooting, if you are able to look into this. Quote
