Hi, I have all fans connected to the Lian Li fan controller, and the latter connected to the mobo via USB connector (no fan header used) but for the life of me I can't find a sensor that would give me the RMP reading that I DO get with the L-Connect software (800RPM). I tried using the fan header just to see if that was it but still I couldn't find the sensor for it. Am I missing something?
Thank you!
Thank you!
It's not supported by AIDA64 yet.  In order to let us have a better understanding on the USB layer of it, please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Thanks so much for the reply. Here's the results:
------[ Versions ]------
Program Version : AIDA64 Extreme v6.32.5600
BenchDLL Version: 4.5.841.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19042.867 (64-bit)
GetProductInfo  : 0x00000030
Motherboard ID      : 63-0100-000001-00101111-122418-Chipset$8AMTS002_BIOS DATE: 01/22/21 15:42:52 VER: 05.00011
Motherboard Model   : Gigabyte X570 Aorus Master
Motherboard Chipset : AMD Bixby X570, AMD K17.7 FCH, AMD K17.7 IMC
DMI MB Manufacturer : Gigabyte Technology Co., Ltd.
DMI MB Product      : X570 AORUS MASTER
DMI MB Version      : Default string
DMI MB Serial       : Default string
DMI SYS Manufacturer: Gigabyte Technology Co., Ltd.
DMI SYS Product     : X570 AORUS MASTER
DMI SYS Version     : -CF
DMI SYS Serial      : Default string
DMI BIOS Version    : F33a
------[ USB Devices ]------
AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
- [Port 1] < No Device Connected >
- [Port 2] Amanero Technologies USB Driver 1.0.67 (Combo384 Amanero)
- - Digital Output (Amanero Technologies USB Driver 1.0.67)
- [Port 3] Xbox Wireless Adapter for Windows (XBOX ACC)
- [Port 4] < No Device Connected >
- [Port 5] < No Device Connected >
- [Port 6] < No Device Connected >
- [Port 7] < No Device Connected >
- [Port 8] < No Device Connected >
- [Port 1] USB Input Device
- - HID-compliant vendor-defined device
- [Port 2] < No Device Connected >
- [Port 3] USB Composite Device (Barcode Reader)
- - USB Input Device
- - - HID Keyboard Device
- - - HID-compliant consumer control device
- - - HID-compliant system controller
- - - HID-compliant mouse
- [Port 6] Generic USB Hub (USB2.0 Hub)
- - [Port 1] USB Input Device (MPI5001)
- - - HID-compliant touch screen
- - [Port 2] < No Device Connected >
- - [Port 3] USB Composite Device (LianLi)
- - - USB Input Device
- - - - HID-compliant vendor-defined device
- - - LianLi
- - [Port 4] < No Device Connected >
- [Port 9] < No Device Connected >
- [Port 10] < No Device Connected >
- [Port 3] eLicenser (eLicenser)
- [Port 5] Intel(R) Wireless Bluetooth(R)
- - Bluetooth Device (RFCOMM Protocol TDI)
- - Microsoft Bluetooth Enumerator
- - Microsoft Bluetooth LE Enumerator
- - Bluetooth Device (Personal Area Network)
- - IBtUsb_Filter_00
- - [Port 1] Komplete Audio 6 UAC (Komplete Audio 6)
- - - Komplete Audio 6 WDM Audio
- - - - Komplete Audio 6 Input 1/2 (Komplete Audio 6 WDM Audio)
- - - - Komplete Audio 6 Input 3/4 (Komplete Audio 6 WDM Audio)
- - - - Komplete Audio 6 Main Output (Komplete Audio 6 WDM Audio)
- - - - Komplete Audio 6 Output 3/4 (Komplete Audio 6 WDM Audio)
- - - - Komplete Audio 6 S/PDIF Output (Komplete Audio 6 WDM Audio)
- - [Port 3] USB Composite Device (SteelSeries QCK Prism)
- - - - HID-compliant consumer control device
- - [Port 4] USB Composite Device (Razer Mamba Tournament Edition)
- - - Razer Mamba Tournament Edition
- - - - Razer Mamba Tournament Edition
- - - - - Razer Control Device
- - - - HID-compliant device
- - - - HID-compliant system controller
- - - - HID Keyboard Device
------[ Amanero Technologies USB Driver 1.0.67]------
Device Description   : Amanero Technologies USB Driver 1.0.67
Device ID            : 16D0-071A
Device Class         : EF / 02 (Interface Association Descriptor)
Device Protocol      : 01
Revision             : 0196h
Manufacturer         : Amanero Technologies
Product              : Combo384 Amanero
Serial Number        : 413-001
Supported USB Version: 2.00
Current Speed        : High  (USB 2.0)
------[ Xbox Wireless Adapter for Windows]------
Device Description   : Xbox Wireless Adapter for Windows
Device ID            : 045E-02E6
Device Class         : FF / FF
Device Protocol      : FF
Revision             : 0100h
Manufacturer         : Microsoft Inc.
Product              : XBOX ACC
Serial Number        : 023863
Supported USB Version: 2.01
------[ USB Input Device]------
Device Description   : USB Input Device
Device ID            : 048D-8297
Device Class         : 03 / 01 (Human Interface Device)
Revision             : 0003h
Current Speed        : Full  (USB 1.1)
------[ USB Composite Device]------
Device Description   : USB Composite Device
Device ID            : 13BA-0018
Revision             : 0001h
Product              : Barcode Reader
Supported USB Version: 1.10
Current Speed        : Low  (USB 1.1)
------[ Generic USB Hub]------
Device Description   : Generic USB Hub
Device ID            : 05E3-0608
Device Class         : 09 / 00 (Hi-Speed Hub with single TT)
Revision             : 8536h
Product              : USB2.0 Hub
Device ID            : 0483-5750
Device Class         : 03 / 00 (Human Interface Device)
Device Protocol      : 00
Revision             : 0200h
Manufacturer         : QDtech
Product              : MPI5001
Supported USB Version: 0.01
Device ID            : 0CF2-7750
Revision             : 0100h
Manufacturer         : ENE
Product              : LianLi
Serial Number        : 6243168001
------[ eLicenser]------
Device Description   : eLicenser
Device ID            : 0819-0101
Device Class         : FF / 00
Revision             : 0101h
Manufacturer         : Syncrosoft
Product              : eLicenser
Supported USB Version: 1.00
------[ Intel(R) Wireless Bluetooth(R)]------
Device Description   : Intel(R) Wireless Bluetooth(R)
Device ID            : 8087-0029
Device Class         : E0 / 01 (Bluetooth)
Revision             : 0001h
Revision             : 8536h
------[ Komplete Audio 6 UAC]------
Device Description   : Komplete Audio 6 UAC
Device ID            : 17CC-1001
Revision             : 0032h
Manufacturer         : Native Instruments
Product              : Komplete Audio 6
Serial Number        : 52BAE5A8
Device ID            : 1038-1507
Revision             : 0027h
Manufacturer         : SteelSeries
Product              : SteelSeries QCK Prism
Device ID            : 1532-0046
Device Protocol      : 02
Revision             : 0200h
Manufacturer         : Razer
Product              : Razer Mamba Tournament Edition
------[ DevClass / USB Hubs ]------
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#7&18eea21b&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\7&18EEA21B&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#8&29c54ea8&0&6#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_05E3&PID_0608\8&29C54EA8&0&6</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000006</ADDR><REV>8536</REV>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&23f8e3f5&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\5&23F8E3F5&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#7&124f193f&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\7&124F193F&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#8&2efe0359&0&6#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_05E3&PID_0608\8&2EFE0359&0&6</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000006</ADDR><REV>8536</REV>
------[ DevClass / USB Devices ]------
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1038&pid_1507#9&b9def5f&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1038&PID_1507\9&B9DEF5F&0&3</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0027</REV>
<DESC>Intel(R) Wireless Bluetooth(R)</DESC><DEVPATH>\\?\usb#vid_8087&pid_0029#8&29c54ea8&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_8087&PID_0029\8&29C54EA8&0&5</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>0001</REV>
<DESC>Xbox Wireless Adapter for Windows</DESC><DEVPATH>\\?\usb#vid_045e&pid_02e6#023863#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_045E&PID_02E6\023863</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>Amanero Technologies USB Driver 1.0.67</DESC><DEVPATH>\\?\usb#vid_16d0&pid_071a#413-001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_16D0&PID_071A\413-001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0196</REV>
<DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_0483&pid_5750#9&1fba9631&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0483&PID_5750\9&1FBA9631&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_048d&pid_8297#8&2efe0359&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_048D&PID_8297\8&2EFE0359&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0003</REV>
<DESC>Komplete Audio 6 UAC</DESC><DEVPATH>\\?\usb#vid_17cc&pid_1001#52bae5a8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_17CC&PID_1001\52BAE5A8</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0032</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0cf2&pid_7750#6243168001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0CF2&PID_7750\6243168001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_13ba&pid_0018#8&2efe0359&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_13BA&PID_0018\8&2EFE0359&0&3</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0001</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_0046#9&b9def5f&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1532&PID_0046\9&B9DEF5F&0&4</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV>
<DESC>eLicenser</DESC><DEVPATH>\\?\usb#vid_0819&pid_0101#8&29c54ea8&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0819&PID_0101\8&29C54EA8&0&3</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0101</REV>
------[ DevClass / Human Interface Devices ]------
<DESC>Razer Mamba Tournament Edition</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_00#b&1d3f0f53&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_00\B&1D3F0F53&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>Razer Mamba Tournament Edition</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_01&col01#b&57b830e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_01&COL01\B&57B830E&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_13ba&pid_0018&mi_00#a&2a57a981&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_13BA&PID_0018&MI_00\A&2A57A981&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000001</ADDR><REV>0001</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_01&col02#b&57b830e&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_01&COL02\B&57B830E&0&0001</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000002</ADDR><REV>0200</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_048d&pid_8297&col01#9&3868a9be&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_048D&PID_8297&COL01\9&3868A9BE&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0003</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_048d&pid_8297&col02#9&3868a9be&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_048D&PID_8297&COL02\9&3868A9BE&0&0001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0003</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_13ba&pid_0018&mi_01&col01#a&3a9b84af&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_13BA&PID_0018&MI_01&COL01\A&3A9B84AF&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000001</ADDR><REV>0001</REV>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_01&col03#b&57b830e&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_01&COL03\B&57B830E&0&0002</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_13ba&pid_0018&mi_01&col02#a&3a9b84af&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_13BA&PID_0018&MI_01&COL02\A&3A9B84AF&0&0001</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000002</ADDR><REV>0001</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_13ba&pid_0018&mi_01&col03#a&3a9b84af&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_13BA&PID_0018&MI_01&COL03\A&3A9B84AF&0&0002</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000003</ADDR><REV>0001</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1038&pid_1507&mi_01#b&a31fdba&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1038&PID_1507&MI_01\B&A31FDBA&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000001</ADDR><REV>0027</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_01&col04#b&57b830e&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_01&COL04\B&57B830E&0&0003</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_1038&pid_1507&mi_00#b&21f589ff&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1038&PID_1507&MI_00\B&21F589FF&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR><REV>0027</REV>
<DESC>HID-compliant touch screen</DESC><DEVPATH>\\?\hid#vid_0483&pid_5750#a&2be8fb15&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0483&PID_5750\A&2BE8FB15&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_01&col05#b&57b830e&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_01&COL05\B&57B830E&0&0004</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0046&mi_02#b&23dce11b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_0046&MI_02\B&23DCE11B&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0cf2&pid_7750&mi_01#b&10adb3fc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0CF2&PID_7750&MI_01\B&10ADB3FC&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
------[ HID Device Info / HID-compliant consumer control device ]------
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0046&MI_01&COL02\B&57B830E&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 16
Output Report Byte Length : 0
Feature Report Byte Length: 0
------[ HID Device Info / HID-compliant vendor-defined device ]------
Manufacturer              : ITE Tech. Inc.
Product                   : ITE Device(8595)
Revision                  : 0003h
Device Instance           : HID\VID_048D&PID_8297&COL01\9&3868A9BE&0&0000
Usage                     : 0010h
Usage Page                : FF89h
Input Report Byte Length  : 0
Feature Report Byte Length: 17
Revision                  : 0003h
Device Instance           : HID\VID_048D&PID_8297&COL02\9&3868A9BE&0&0001
Usage                     : 00CCh
Usage Page                : FF89h
Feature Report Byte Length: 64
------[ HID Device Info / HID-compliant system controller ]------
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0046&MI_01&COL03\B&57B830E&0&0002
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0001h
Device Instance           : HID\VID_13BA&PID_0018&MI_01&COL02\A&3A9B84AF&0&0001
Usage                     : 0080h
Usage Page                : 0001h
Input Report Byte Length  : 2
Revision                  : 0001h
Device Instance           : HID\VID_13BA&PID_0018&MI_01&COL03\A&3A9B84AF&0&0002
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 3
Revision                  : 0027h
Device Instance           : HID\VID_1038&PID_1507&MI_01\B&A31FDBA&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 5
------[ HID Device Info / HID-compliant device ]------
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0046&MI_01&COL04\B&57B830E&0&0003
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0027h
Device Instance           : HID\VID_1038&PID_1507&MI_00\B&21F589FF&0&0000
Usage                     : 0001h
Usage Page                : FFC0h
Input Report Byte Length  : 65
Output Report Byte Length : 65
Feature Report Byte Length: 525
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0046&MI_01&COL05\B&57B830E&0&0004
Usage                     : 0000h
Usage Page                : 0001h
Manufacturer              : ENE
Product                   : LianLi
Revision                  : 0100h
Device Instance           : HID\VID_0CF2&PID_7750&MI_01\B&10ADB3FC&0&0000
Usage                     : 00A1h
Usage Page                : FF72h
------[ DevClass / COM Ports ]------
< No COM Port Found >
------[ DevClass / LPT Ports ]------
< No LPT Port Found >
------[ DevClass / Modems ]------
< No Modem Found >
------[ DevClass / SideShow Devices ]------
< No SideShow Device Found >
------[ DevClass / GX3 Devices ]------
< No GX3 Device Found >
------[ DevClass / USBXpress Devices ]------
< No USBXpress Device Found >
------[ DevClass / WinUSB Devices ]------
< No WinUSB Device Found >
------[ LibUsb0 Devices ]------
< No LibUsb0 Device Found >
------[ CH341 Devices ]------
< No CH341 Device Found >
------[ FTD2xx Devices ]------
< No FTD2xx Device Found >
------[ LibMPSSE Devices ]------
< No LibMPSSE Device Found >
------[ SiUSBXp Devices ]------
SiUSBXp.dll Path =
< No SiUSBXp Device Found >
------[ T-Balancer Devices ]------
< No T-Balancer Device Found >
------[ Koolance TMS-200 Devices ]------
< No T-Koolance TMS-200 Device Found >
------[ GRID+ V3 Devices ]------
< No GRID+ V3 Device Found >
------[ Kraken X-2/X-3 Devices ]------
< No Kraken X-2/X-3 Device Found >
Same concern here
Motherboard ID      : <DMI>
Motherboard Model   : Asus TUF Gaming B460-Pro (Wi-Fi)
Motherboard Chipset : Intel Comet Point-H B460, Intel Comet Lake-S
DMI MB Product      : TUF GAMING B460-PRO (WI-FI)
DMI MB Version      : Rev 1.xx
DMI MB Serial       : 200670305200975
DMI SYS Manufacturer: ASUS
DMI SYS Product     : System Product Name
DMI SYS Version     : System Version
DMI SYS Serial      : System Serial Number
DMI BIOS Version    : 1602
Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
- [Port 3] USB Composite Device (Razer Firefly V2)
- - Razer Firefly V2
- - - Razer Firefly V2
- [Port 5] Generic USB Hub (USB2.0 Hub)
- - [Port 1] USB Composite Device (HEXXA)
- - - HEXXA
- - - - Microphone Array (HEXXA)
- - - - Speakers (HEXXA)
- - [Port 2] Xbox 360 Controller for Windows (Controller)
- - - - HID-compliant game controller
- - [Port 3] USB Composite Device (USB  Live camera)
- - - USB Live camera
- - - USB Live camera audio
- - - - Microphone (USB Live camera audio)
- [Port 6] USB Composite Device (Razer DeathAdder V2 Pro)
- - Razer DeathAdder V2 Pro
- - - Razer DeathAdder V2 Pro
- [Port 7] Intel(R) Wireless Bluetooth(R)
- [Port 8] USB Composite Device (AURA LED Controller)
- - AURA LED Controller
- [Port 11] < No Device Connected >
- [Port 12] < No Device Connected >
- [Port 13] Unknown Device
- [Port 14] Unknown Device
- [Port 15] Unknown Device
- [Port 16] Unknown Device
- [Port 17] < No Device Connected >
- [Port 18] < No Device Connected >
- [Port 19] < No Device Connected >
- [Port 20] < No Device Connected >
- [Port 21] < No Device Connected >
- [Port 22] < No Device Connected >
- [Port 23] < No Device Connected >
- [Port 24] < No Device Connected >
ASMedia USB 3.1 eXtensible Host Controller - 1.10 (Microsoft)
- [Port 3] USB Composite Device (Razer DeathAdder V2 Pro)
- [Port 4] USB Composite Device (Razer BlackWidow Ultimate)
- - Razer BlackWidow Ultimate
- - - Razer BlackWidow Ultimate
Device ID            : 1532-0C04
Revision             : 0200h
Manufacturer         : RAZER
Product              : Razer Firefly V2
Device ID            : 05E3-0610
Device Class         : 09 / 00 (Hi-Speed Hub with multiple TTs)
Revision             : 0402h
Manufacturer         : GenesysLogic
Supported USB Version: 2.10
Device ID            : 0C76-2038
Device Class         : 01 / 01 (Audio Control)
Revision             : 0100h
Manufacturer         : Solid State System Co.,Ltd.
Product              : HEXXA
Serial Number        : 000000000000
------[ Xbox 360 Controller for Windows]------
Device Description   : Xbox 360 Controller for Windows
Device ID            : 045E-028E
Revision             : 0110h
Product              : Controller
Serial Number        : 1187A89
Device ID            : 0C46-64AB
Revision             : 0100h
Manufacturer         : Sonix Technology Co., Ltd.
Product              : USB  Live camera
Serial Number        : SN0001
Device ID            : 1532-007C
Revision             : 0100h
Product              : Razer DeathAdder V2 Pro
Revision             : 0001h
Device ID            : 0B05-1939
Revision             : 0100h
Manufacturer         : AsusTek Computer Inc.
Product              : AURA LED Controller
Serial Number        : 9876543210
------[ Unknown Device]------
Device Description   : Unknown Device
Device ID            : 0000-0000
Device Class         : 00 / 00
Revision             : 0000h
Supported USB Version: 0.00
Revision             : 0000h
Revision             : 0000h
Revision             : 0000h
Device ID            : 1532-007D
Revision             : 0100h
Device ID            : 1532-011A
Revision             : 0200h
Product              : Razer BlackWidow Ultimate
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#4&2dd5b14d&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\4&2DD5B14D&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&22322a41&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\5&22322A41&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0610#5&1f03ab54&0&5#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_05E3&PID_0610\5&1F03AB54&0&5</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>0402</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0b05&pid_1939#9876543210#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0B05&PID_1939\9876543210</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0c46&pid_64ab#sn0001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0C46&PID_64AB\SN0001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0c76&pid_2038#000000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0C76&PID_2038\000000000000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_0c04#5&1f03ab54&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1532&PID_0C04\5&1F03AB54&0&3</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_007d#000000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1532&PID_007D\000000000000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_011a#6&35bde04c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1532&PID_011A\6&35BDE04C&0&4</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV>
<DESC>Xbox 360 Controller for Windows</DESC><DEVPATH>\\?\usb#vid_045e&pid_028e#1187a89#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_045E&PID_028E\1187A89</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0110</REV>
<DESC>Intel(R) Wireless Bluetooth(R)</DESC><DEVPATH>\\?\usb#vid_8087&pid_0029#5&1f03ab54&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_8087&PID_0029\5&1F03AB54&0&7</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000007</ADDR><REV>0001</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_007c#000000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1532&PID_007C\000000000000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000006</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_03&col01#8&386c56d6&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_03&COL01\8&386C56D6&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_00#8&34dd36f2&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_00\8&34DD36F2&0&0000</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_03&col02#8&386c56d6&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_03&COL02\8&386C56D6&0&0001</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000002</ADDR><REV>0100</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col02#8&2c58a559&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL02\8&2C58A559&0&0001</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000002</ADDR><REV>0100</REV>
<DESC>Razer DeathAdder V2 Pro</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_00#8&8816797&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_00\8&8816797&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col03#8&2c58a559&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL03\8&2C58A559&0&0002</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_1532&pid_0306&mi_00&col00#2&38176d1f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0306&MI_00&COL00\2&38176D1F&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col02#8&1d19aaad&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL02\8&1D19AAAD&0&0001</INSTANCE><BUSNUM>0000000D</BUSNUM><ADDR>00000002</ADDR><REV>0200</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0c04&mi_01&col01#7&358fffca&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_0C04&MI_01&COL01\7&358FFFCA&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col04#8&2c58a559&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL04\8&2C58A559&0&0003</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0306&mi_00&col01#2&373ba01a&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_0306&MI_00&COL01\2&373BA01A&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col03#8&1d19aaad&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL03\8&1D19AAAD&0&0002</INSTANCE><BUSNUM>0000000D</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col05#8&2c58a559&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL05\8&2C58A559&0&0004</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col04#8&1d19aaad&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL04\8&1D19AAAD&0&0003</INSTANCE><BUSNUM>0000000D</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col06#8&2c58a559&0&0005#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL06\8&2C58A559&0&0005</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000006</ADDR><REV>0100</REV>
<DESC>Razer BlackWidow Ultimate</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_02#8&5561e68&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_02\8&5561E68&0&0000</INSTANCE><BUSNUM>0000000E</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_0c76&pid_2038&mi_03#9&2f5eb333&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C76&PID_2038&MI_03\9&2F5EB333&0&0000</INSTANCE><BUSNUM>0000000F</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col05#8&1d19aaad&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL05\8&1D19AAAD&0&0004</INSTANCE><BUSNUM>0000000D</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col07#8&2c58a559&0&0006#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL07\8&2C58A559&0&0006</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000007</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_04#8&2c86d75a&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_04\8&2C86D75A&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col08#8&2c58a559&0&0007#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL08\8&2C58A559&0&0007</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000008</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_00&col03#9&e03996d&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_00&COL03\9&E03996D&1&0000</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000001</ADDR>
<DESC>Razer BlackWidow Ultimate</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col01#8&1d19aaad&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL01\8&1D19AAAD&0&0000</INSTANCE><BUSNUM>0000000D</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0c04&mi_01&col02#7&358fffca&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0C04&MI_01&COL02\7&358FFFCA&0&0001</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000002</ADDR><REV>0200</REV>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_0c04&mi_01&col03#7&358fffca&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0C04&MI_01&COL03\7&358FFFCA&0&0002</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV>
<DESC>Razer DeathAdder V2 Pro</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_01&col01#8&2c58a559&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_01&COL01\8&2C58A559&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0c04&mi_01&col04#7&358fffca&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0C04&MI_01&COL04\7&358FFFCA&0&0003</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0c04&mi_01&col05#7&358fffca&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0C04&MI_01&COL05\7&358FFFCA&0&0004</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0b05&pid_1939&mi_02#7&aad647&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0B05&PID_1939&MI_02\7&AAD647&0&0000</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0306&mi_00&col03#2&695c1ff&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0306&MI_00&COL03\2&695C1FF&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000001</ADDR>
<DESC>Razer Firefly V2</DESC><DEVPATH>\\?\hid#vid_1532&pid_0c04&mi_00#7&2f632e66&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0C04&MI_00\7&2F632E66&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant game controller</DESC><DEVPATH>\\?\hid#vid_045e&pid_028e&ig_00#8&6ec1b80&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_045E&PID_028E&IG_00\8&6EC1B80&1&0000</INSTANCE><BUSNUM>00000010</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007d&mi_02#8&14951914&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_007D&MI_02\8&14951914&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>Razer DeathAdder V2 Pro</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_00#7&20035850&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_00\7&20035850&0&0000</INSTANCE><BUSNUM>00000011</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>Razer DeathAdder V2 Pro</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_01&col01#7&37c6e495&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_01&COL01\7&37C6E495&0&0000</INSTANCE><BUSNUM>00000012</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_01&col02#7&37c6e495&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_01&COL02\7&37C6E495&0&0001</INSTANCE><BUSNUM>00000012</BUSNUM><ADDR>00000002</ADDR><REV>0100</REV>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_01&col03#7&37c6e495&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_01&COL03\7&37C6E495&0&0002</INSTANCE><BUSNUM>00000012</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_01&col04#7&37c6e495&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_01&COL04\7&37C6E495&0&0003</INSTANCE><BUSNUM>00000012</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_01&col05#7&37c6e495&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_01&COL05\7&37C6E495&0&0004</INSTANCE><BUSNUM>00000012</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_03#7&fe796ef&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_03\7&FE796EF&0&0000</INSTANCE><BUSNUM>00000013</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_00&col03#8&20ec6058&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_00&COL03\8&20EC6058&0&0000</INSTANCE><BUSNUM>00000014</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_007c&mi_02#7&13efa6d3&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_007C&MI_02\7&13EFA6D3&0&0000</INSTANCE><BUSNUM>00000015</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_03&COL02\8&386C56D6&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_01&COL03\8&2C58A559&0&0002
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_011A&MI_01&COL02\8&1D19AAAD&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_01&COL04\8&2C58A559&0&0003
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_011A&MI_01&COL03\8&1D19AAAD&0&0002
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_01&COL05\8&2C58A559&0&0004
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_011A&MI_01&COL04\8&1D19AAAD&0&0003
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_01&COL06\8&2C58A559&0&0005
Usage                     : 0000h
Usage Page                : 0001h
Product                   : HEXXA
Revision                  : 0100h
Device Instance           : HID\VID_0C76&PID_2038&MI_03\9&2F5EB333&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Output Report Byte Length : 5
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_011A&MI_01&COL05\8&1D19AAAD&0&0004
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_01&COL07\8&2C58A559&0&0006
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007D&MI_01&COL08\8&2C58A559&0&0007
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0101h
Device Instance           : HID\VID_1532&PID_007D&MI_00&COL03\9&E03996D&1&0000
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0C04&MI_01&COL02\7&358FFFCA&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0C04&MI_01&COL03\7&358FFFCA&0&0002
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0C04&MI_01&COL04\7&358FFFCA&0&0003
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0C04&MI_01&COL05\7&358FFFCA&0&0004
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_0B05&PID_1939&MI_02\7&AAD647&0&0000
Usage                     : 00A1h
Usage Page                : FF72h
Device ID                 : 1532-0306
Revision                  : 0101h
Device Instance           : HID\VID_1532&PID_0306&MI_00&COL03\2&695C1FF&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
------[ HID Device Info / HID-compliant game controller ]------
Product                   : Controller (XBOX 360 For Windows)
Revision                  : 0000h
Device Instance           : HID\VID_045E&PID_028E&IG_00\8&6EC1B80&1&0000
Usage                     : 0005h
Usage Page                : 0001h
Input Report Byte Length  : 15
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007C&MI_01&COL02\7&37C6E495&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007C&MI_01&COL03\7&37C6E495&0&0002
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007C&MI_01&COL04\7&37C6E495&0&0003
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0100h
Device Instance           : HID\VID_1532&PID_007C&MI_01&COL05\7&37C6E495&0&0004
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 0101h
Device Instance           : HID\VID_1532&PID_007C&MI_00&COL03\8&20EC6058&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
<DESC>Communications Port (COM1)</DESC><DEVPATH>\\?\acpi#pnp0501#0#{86e0d1e0-8089-11d0-9ce4-08003e301f73}</DEVPATH><INSTANCE>ACPI\PNP0501\0</INSTANCE><BUSNUM>00000000</BUSNUM>
< No Modem Found >
SiUSBXp.dll Path =
  • 2 months later...
  • 4 months later...
  • 5 months later...
Here are my results:
Program Version : AIDA64 Extreme v6.75.6100
BenchDLL Version: 4.6.871.8-x64
Windows Version : Microsoft Windows 11 Home 10.0.22000.856 (64-bit)
GetProductInfo  : 0x00000065
Motherboard ID      : 63-0100-000001-00101111-090216-Chipset$0AAAA000_BIOS DATE: 07/13/21 09:12:06 VER: 05.0000C
Motherboard Model   : Asus ROG Maximus X Formula
Motherboard Chipset : Intel Kaby Point Z370, Intel Coffee Lake-S
DMI MB Product      : ROG MAXIMUS X FORMULA
DMI MB Serial       : 171013576301015
DMI BIOS Version    : 2701
- [Port 1] Generic USB Hub
- - [Port 1] < No Device Connected >
- - [Port 3] < No Device Connected >
- [Port 2] Generic USB Hub
- [Port 5] USB Composite Device (SteelSeries Rival 650 Wireless)
- - SteelSeries Rival 650 Wireless
- - SteelSeries GG Component
- [Port 10] Generic USB Hub (Massdrop Hub)
- - [Port 2] USB Composite Device (CTRL Keyboard)
- [Port 11] Realtek Bluetooth Adapter (Bluetooth Radio)
- - - Xbox Wireless Controller
- - - - Bluetooth LE Generic Attribute Service
- - - - Device Information Service
- - - - Generic Access Profile
- - - - Generic Attribute Profile
- - - - Bluetooth LE XINPUT compatible input device
- [Port 12] USB Input Device (AURA LED Controller)
- [Port 13] Generic USB Hub
- [Port 14] Generic USB Hub (USB2.0 Hub)
- - [Port 2] USB Composite Device (LianLi-SL-infinity-v0.8)
- - - LianLi-SL-infinity-v0.4
- - [Port 4] USB Composite Device (LianLi-Strimer Plus-1.3)
- - - LianLi-Strimer Plus-1.0
- [Port 15] < No Device Connected >
- [Port 16] < No Device Connected >
- [Port 17] Generic SuperSpeed USB Hub
- [Port 18] Generic SuperSpeed USB Hub
- [Port 25] < No Device Connected >
- [Port 26] < No Device Connected >
- [Port 1] Generic SuperSpeed USB Hub
- - [Port 4] Generic SuperSpeed USB Hub
- - - [Port 1] < No Device Connected >
- - - [Port 2] < No Device Connected >
- - - [Port 3] < No Device Connected >
- - - [Port 4] < No Device Connected >
- [Port 3] Generic USB Hub
- - [Port 4] Generic USB Hub
Device ID            : 2109-2817
Revision             : 9023h
Revision             : 9023h
Device ID            : 1038-172B
Revision             : 0126h
Product              : SteelSeries Rival 650 Wireless
Device ID            : 04D8-EEC5
Device Class         : 09 / 00 (Full-Speed Hub)
Revision             : 0101h
Manufacturer         : Massdrop Inc.
Product              : Massdrop Hub
Serial Number        : 1530583756
Device ID            : 04D8-EED2
Revision             : 0101h
Product              : CTRL Keyboard
------[ Realtek Bluetooth Adapter]------
Device Description   : Realtek Bluetooth Adapter
Device ID            : 0B05-185C
Revision             : 0110h
Manufacturer         : Realtek
Product              : Bluetooth Radio
Serial Number        : 00e04c000001
Device ID            : 0B05-1872
Revision             : 0200h
Serial Number        : 00000000001A
Revision             : 8536h
Revision             : 8536h
Device ID            : 0CF2-A102
Revision             : 0100h
Manufacturer         : ENE
Product              : LianLi-SL-infinity-v0.8
Device ID            : 0CF2-A200
Revision             : 0100h
Manufacturer         : ENE
Product              : LianLi-Strimer Plus-1.3
------[ Generic SuperSpeed USB Hub]------
Device Description   : Generic SuperSpeed USB Hub
Device ID            : 2109-0817
Device Class         : 09 / 00 (Hub)
Device Protocol      : 03
Revision             : 9023h
Supported USB Version: 3.10
Current Speed        : Super  (USB 3.0)
Revision             : 9023h
Device ID            : 05E3-0617
Revision             : 4428h
Supported USB Version: 3.00
Revision             : 4428h
Revision             : 4428h
Revision             : 4428h
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#5&c1bd4d0&0&13#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>194</DEVINST><INSTANCE>USB\VID_05E3&PID_0608\5&C1BD4D0&0&13</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000D</ADDR><REV>8536</REV>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&1cf89861&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>73</DEVINST><INSTANCE>USB\ROOT_HUB30\5&1CF89861&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0610#6&8042f4d&0&3#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>139</DEVINST><INSTANCE>USB\VID_05E3&PID_0610\6&8042F4D&0&3</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>4428</REV>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&14c0473e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>144</DEVINST><INSTANCE>USB\ROOT_HUB30\5&14C0473E&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_2109&pid_2817#5&c1bd4d0&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>21</DEVINST><INSTANCE>USB\VID_2109&PID_2817\5&C1BD4D0&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>9023</REV>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#4&1dc5b97&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>155</DEVINST><INSTANCE>USB\ROOT_HUB30\4&1DC5B97&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic SuperSpeed USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0617#6&8042f4d&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>177</DEVINST><INSTANCE>USB\VID_05E3&PID_0617\6&8042F4D&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>4428</REV>
<DESC>Generic SuperSpeed USB Hub</DESC><DEVPATH>\\?\usb#vid_2109&pid_0817#5&c1bd4d0&0&18#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>158</DEVINST><INSTANCE>USB\VID_2109&PID_0817\5&C1BD4D0&0&18</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000012</ADDR><REV>9023</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_2109&pid_2817#5&c1bd4d0&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>20</DEVINST><INSTANCE>USB\VID_2109&PID_2817\5&C1BD4D0&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>9023</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#5&c1bd4d0&0&14#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>195</DEVINST><INSTANCE>USB\VID_05E3&PID_0608\5&C1BD4D0&0&14</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000E</ADDR><REV>8536</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0610#7&dfa034d&0&4#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>14</DEVINST><INSTANCE>USB\VID_05E3&PID_0610\7&DFA034D&0&4</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>4428</REV>
<DESC>Generic SuperSpeed USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0617#7&37b7337b&0&4#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>169</DEVINST><INSTANCE>USB\VID_05E3&PID_0617\7&37B7337B&0&4</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>4428</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_04d8&pid_eec5#5&c1bd4d0&0&10#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>196</DEVINST><INSTANCE>USB\VID_04D8&PID_EEC5\5&C1BD4D0&0&10</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000A</ADDR><REV>0101</REV>
<DESC>Generic SuperSpeed USB Hub</DESC><DEVPATH>\\?\usb#vid_2109&pid_0817#5&c1bd4d0&0&17#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>157</DEVINST><INSTANCE>USB\VID_2109&PID_0817\5&C1BD4D0&0&17</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000011</ADDR><REV>9023</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_04d8&pid_eed2#1530583756#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>38</DEVINST><INSTANCE>USB\VID_04D8&PID_EED2\1530583756</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0101</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0cf2&pid_a200#6243168001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>151</DEVINST><INSTANCE>USB\VID_0CF2&PID_A200\6243168001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV>
<DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_0b05&pid_1872#00000000001a#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>85</DEVINST><INSTANCE>USB\VID_0B05&PID_1872\00000000001A</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000C</ADDR><REV>0200</REV>
<DESC>Realtek Bluetooth Adapter</DESC><DEVPATH>\\?\usb#vid_0b05&pid_185c#00e04c000001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>77</DEVINST><INSTANCE>USB\VID_0B05&PID_185C\00E04C000001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000B</ADDR><REV>0110</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1038&pid_172b#000000000000#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>162</DEVINST><INSTANCE>USB\VID_1038&PID_172B\000000000000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>0126</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0cf2&pid_a102#6243168001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>76</DEVINST><INSTANCE>USB\VID_0CF2&PID_A102\6243168001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0100</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0cf2&pid_a102&mi_01#8&113d0838&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>175</DEVINST><INSTANCE>HID\VID_0CF2&PID_A102&MI_01\8&113D0838&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#virtualdevice&10&col05#2&90c581f&1&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>161</DEVINST><INSTANCE>HID\VIRTUALDEVICE&10&COL05\2&90C581F&1&0004</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000005</ADDR>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_03#7&20ff0321&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>37</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_03\7&20FF0321&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR><REV>0126</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0cf2&pid_a200&mi_01#8&369eb513&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>82</DEVINST><INSTANCE>HID\VID_0CF2&PID_A200&MI_01\8&369EB513&0&0000</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_04d8&pid_eed2&mi_00#8&114f6e26&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>46</DEVINST><INSTANCE>HID\VID_04D8&PID_EED2&MI_00\8&114F6E26&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000001</ADDR><REV>0101</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#virtualdevice&10&col01#2&90c581f&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>171</DEVINST><INSTANCE>HID\VIRTUALDEVICE&10&COL01\2&90C581F&1&0000</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#virtualdevice&10&col02#2&90c581f&1&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>168</DEVINST><INSTANCE>HID\VIRTUALDEVICE&10&COL02\2&90C581F&1&0001</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000002</ADDR>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_04d8&pid_eed2&mi_02#8&2689ffb1&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>170</DEVINST><INSTANCE>HID\VID_04D8&PID_EED2&MI_02\8&2689FFB1&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000001</ADDR><REV>0101</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_02&col02#7&342f1f5f&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>69</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_02&COL02\7&342F1F5F&0&0001</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000002</ADDR><REV>0126</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_01&col01#7&5d0664e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>99</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_01&COL01\7&5D0664E&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000001</ADDR><REV>0126</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_02&col01#7&342f1f5f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>27</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_02&COL01\7&342F1F5F&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000001</ADDR><REV>0126</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#virtualdevice&10&col03#2&90c581f&1&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>166</DEVINST><INSTANCE>HID\VIRTUALDEVICE&10&COL03\2&90C581F&1&0002</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000003</ADDR>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_00#7&2e3b1417&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>146</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_00\7&2E3B1417&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000001</ADDR><REV>0126</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_01&col02#7&5d0664e&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>94</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_01&COL02\7&5D0664E&0&0001</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000002</ADDR><REV>0126</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_0b05&pid_1872#6&16128b8d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>40</DEVINST><INSTANCE>HID\VID_0B05&PID_1872\6&16128B8D&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#virtualdevice&10&col04#2&90c581f&1&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>165</DEVINST><INSTANCE>HID\VIRTUALDEVICE&10&COL04\2&90C581F&1&0003</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000004</ADDR>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_04d8&pid_eed2&mi_01&col01#8&39ba1bef&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>66</DEVINST><INSTANCE>HID\VID_04D8&PID_EED2&MI_01&COL01\8&39BA1BEF&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000001</ADDR><REV>0101</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1038&pid_172b&mi_01&col03#7&5d0664e&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>89</DEVINST><INSTANCE>HID\VID_1038&PID_172B&MI_01&COL03\7&5D0664E&0&0002</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000003</ADDR><REV>0126</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_04d8&pid_eed2&mi_01&col02#8&39ba1bef&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>104</DEVINST><INSTANCE>HID\VID_04D8&PID_EED2&MI_01&COL02\8&39BA1BEF&0&0001</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000002</ADDR><REV>0101</REV>
Manufacturer              : ENE
Revision                  : 0100h
Device Instance           : HID\VID_0CF2&PID_A102&MI_01\8&113D0838&0&0000
Usage                     : 00A1h
Usage Page                : FF72h
Output Report Byte Length : 353
Feature Report Byte Length: 7
Device ID                 : 1B1C-1BF0
Revision                  : 0001h
Device Instance           : HID\VIRTUALDEVICE&10&COL05\2&90C581F&1&0004
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0126h
Device Instance           : HID\VID_1038&PID_172B&MI_03\7&20FF0321&0&0000
Usage                     : 0001h
Usage Page                : FFC1h
Input Report Byte Length  : 9
Manufacturer              : ENE
Revision                  : 0100h
Device Instance           : HID\VID_0CF2&PID_A200&MI_01\8&369EB513&0&0000
Usage                     : 00A1h
Usage Page                : FF72h
Output Report Byte Length : 255
Revision                  : 0126h
Device Instance           : HID\VID_1038&PID_172B&MI_02&COL02\7&342F1F5F&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0126h
Device Instance           : HID\VID_1038&PID_172B&MI_00\7&2E3B1417&0&0000
Usage                     : 0001h
Usage Page                : FFC0h
Feature Report Byte Length: 263
Revision                  : 0200h
Device Instance           : HID\VID_0B05&PID_1872\6&16128B8D&0&0000
Usage                     : 0001h
Usage Page                : 00FFh
Revision                  : 0101h
Device Instance           : HID\VID_04D8&PID_EED2&MI_01&COL01\8&39BA1BEF&0&0000
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0126h
Device Instance           : HID\VID_1038&PID_172B&MI_01&COL03\7&5D0664E&0&0002
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0101h
Device Instance           : HID\VID_04D8&PID_EED2&MI_01&COL02\8&39BA1BEF&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
< No Modem Found >
SiUSBXp.dll Path = C:\Program Files (x86)\Corsair\Corsair Utility Engine\SiUSBXp.dll
DLL Version      = 3.5.0.0
Driver Version   =
------[ Smart Dev V2 Devices ]------
< No Smart Dev V2 Device Found >
  • 2 months later...
Hi, I’m running LConnect 3 and Hub + 6 of the new infinity fans. How do we get the Lian Li capability into Aida 64?
Considering moving to a Lian Li 360 CPU cooler, but don’t want to lose the NZXT pump data I’m currently getting…..
I am running the same motherboard and also multiple SL INF fan groups.  Do you use Lconnect3 to control the fans or have you been able to get the MB RPM Sync to work proper?
  • 4 months later...
Having the same issue on my 2000 RPM fan (This is a dump with spanish stuff since i downloaded a spanish version of AIDA64 Extreme)
Program Version : AIDA64 Extreme v6.25.5400
BenchDLL Version: 4.5.816.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.10586.164 (64-bit)
Motherboard Model   : Toshiba TE5
Motherboard Chipset : Intel Cougar Point HM65, Intel Sandy Bridge
DMI MB Manufacturer : Intel Corp.
DMI MB Product      : Base Board Product Name
DMI MB Version      : Base Board Version
DMI MB Serial       : Base Board Serial Number
DMI SYS Manufacturer: TOSHIBA
DMI SYS Product     : TE5
DMI SYS Version     : xxxxxx-xxxxxx
DMI SYS Serial      : 123456789
DMI BIOS Version    :
Controladora de host mejorada USB de la familia Chipset Intel(R) serie 6/serie C200 - 1C2D
- - [Port 4] Dispositivo compuesto USB
- - - Chicony USB 2.0 Camera
- - [Port 5] < No Device Connected >
- - [Port 6] Generic Bluetooth Adapter
Controladora de host mejorada USB de la familia Chipset Intel(R) serie 6/serie C200 - 1C26
- - [Port 2] Generic USB Hub (USB2.0 HUB)
- - - [Port 1] Generic USB Hub
- - - - [Port 1] < No Device Connected >
- - - - [Port 2] < No Device Connected >
- - - - [Port 3] < No Device Connected >
- - - - [Port 4] < No Device Connected >
- - - [Port 3] Dispositivo compuesto USB (USB Keyboard)
- - - - Dispositivo de entrada USB
- - - - - Dispositivo de teclado HID
- - - - - Controlador del sistema compatible con HID
- - - - - Dispositivo de control del consumidor compatible con HID
- - - [Port 4] Dispositivo compuesto USB (USB OPTICAL MOUSE)
- - - - - Mouse compatible con HID
- - - - - Dispositivo definido por el proveedor compatible con HID
- - [Port 5] Dispositivo de almacenamiento USB (USB2.0-CRW)
- - - Generic- Multi-Card USB Device
- - [Port 6] < No Device Connected >
Device ID            : 8087-0024
Revision             : 0000h
------[ Dispositivo compuesto USB]------
Device Description   : Dispositivo compuesto USB
Device ID            : 04F2-B1D6
Revision             : 2613h
------[ Generic Bluetooth Adapter]------
Device Description   : Generic Bluetooth Adapter
Device ID            : 0930-0215
Revision             : 0001h
Revision             : 0000h
Device ID            : 0A05-7211
Revision             : 0100h
Product              : USB2.0 HUB
Revision             : 0100h
Device ID            : 1A2C-2C27
Revision             : 0110h
Manufacturer         : USB
Product              : USB Keyboard
Device ID            : 18F8-0F99
Revision             : 0100h
Product              : USB OPTICAL MOUSE
------[ Dispositivo de almacenamiento USB]------
Device Description   : Dispositivo de almacenamiento USB
Device ID            : 0BDA-0138
Device Class         : 08 / 06 (Mass Storage)
Device Protocol      : 50
Revision             : 3882h
Manufacturer         : Generic
Product              : USB2.0-CRW
Serial Number        : 20090516388200000
<DESC>Concentrador raíz USB</DESC><DEVPATH>\\?\usb#root_hub20#4&17684393&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB20\4&17684393&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_8087&pid_0024#5&31c9d4a9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_8087&PID_0024\5&31C9D4A9&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0000</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_8087&pid_0024#5&18a2bf63&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_8087&PID_0024\5&18A2BF63&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0000</REV>
<DESC>Concentrador raíz USB</DESC><DEVPATH>\\?\usb#root_hub20#4&125bc64d&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB20\4&125BC64D&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_0a05&pid_7211#6&9a5f18c&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_0A05&PID_7211\6&9A5F18C&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0100</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_0a05&pid_7211#7&23d3912e&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_0A05&PID_7211\7&23D3912E&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>Dispositivo compuesto USB</DESC><DEVPATH>\\?\usb#vid_1a2c&pid_2c27#7&23d3912e&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1A2C&PID_2C27\7&23D3912E&0&3</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0110</REV>
<DESC>Dispositivo compuesto USB</DESC><DEVPATH>\\?\usb#vid_18f8&pid_0f99#7&23d3912e&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_18F8&PID_0F99\7&23D3912E&0&4</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV>
<DESC>Dispositivo de almacenamiento USB</DESC><DEVPATH>\\?\usb#vid_0bda&pid_0138#20090516388200000#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0BDA&PID_0138\20090516388200000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>3882</REV>
<DESC>Dispositivo compuesto USB</DESC><DEVPATH>\\?\usb#vid_04f2&pid_b1d6#6&2c9ddd91&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_04F2&PID_B1D6\6&2C9DDD91&0&4</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>2613</REV>
<DESC>Dispositivo de teclado HID</DESC><DEVPATH>\\?\hid#vid_18f8&pid_0f99&mi_01&col01#9&804cd2c&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_18F8&PID_0F99&MI_01&COL01\9&804CD2C&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>Dispositivo de teclado HID</DESC><DEVPATH>\\?\hid#vid_1a2c&pid_2c27&mi_00#9&169f3563&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1A2C&PID_2C27&MI_00\9&169F3563&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0110</REV>
<DESC>Dispositivo de control del consumidor compatible con HID</DESC><DEVPATH>\\?\hid#vid_18f8&pid_0f99&mi_01&col02#9&804cd2c&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_18F8&PID_0F99&MI_01&COL02\9&804CD2C&0&0001</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>Dispositivo definido por el proveedor compatible con HID</DESC><DEVPATH>\\?\hid#vid_18f8&pid_0f99&mi_01&col03#9&804cd2c&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_18F8&PID_0F99&MI_01&COL03\9&804CD2C&0&0002</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>Dispositivo definido por el proveedor compatible con HID</DESC><DEVPATH>\\?\hid#vid_18f8&pid_0f99&mi_01&col04#9&804cd2c&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_18F8&PID_0F99&MI_01&COL04\9&804CD2C&0&0003</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>Dispositivo de control del consumidor compatible con HID</DESC><DEVPATH>\\?\hid#vid_1a2c&pid_2c27&mi_01&col01#9&3340768c&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1A2C&PID_2C27&MI_01&COL01\9&3340768C&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000004</ADDR><REV>0110</REV>
<DESC>Controlador del sistema compatible con HID</DESC><DEVPATH>\\?\hid#vid_1a2c&pid_2c27&mi_01&col02#9&3340768c&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1A2C&PID_2C27&MI_01&COL02\9&3340768C&0&0001</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000004</ADDR><REV>0110</REV>
<DESC>Mouse compatible con HID</DESC><DEVPATH>\\?\hid#vid_18f8&pid_0f99&mi_00#9&1fc85971&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_18F8&PID_0F99&MI_00\9&1FC85971&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV>
------[ HID Device Info / Dispositivo de control del consumidor compatible con HID ]------
Revision                  : 0100h
Device Instance           : HID\VID_18F8&PID_0F99&MI_01&COL02\9&804CD2C&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
------[ HID Device Info / Dispositivo definido por el proveedor compatible con HID ]------
Revision                  : 0100h
Device Instance           : HID\VID_18F8&PID_0F99&MI_01&COL03\9&804CD2C&0&0002
Usage                     : 0001h
Usage Page                : FF00h
Revision                  : 0100h
Device Instance           : HID\VID_18F8&PID_0F99&MI_01&COL04\9&804CD2C&0&0003
Usage                     : 0001h
Usage Page                : FF01h
Feature Report Byte Length: 8
Manufacturer              : USB
Revision                  : 0110h
Device Instance           : HID\VID_1A2C&PID_2C27&MI_01&COL01\9&3340768C&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
------[ HID Device Info / Controlador del sistema compatible con HID ]------
Manufacturer              : USB
Revision                  : 0110h
Device Instance           : HID\VID_1A2C&PID_2C27&MI_01&COL02\9&3340768C&0&0001
Usage                     : 0080h
Usage Page                : 0001h
< No Modem Found >
SiUSBXp.dll Path =
------[ Kraken X42/X52/X62/X72 Devices ]------
< No Kraken X42/X52/X62/X72 Device Found >
  • 7 months later...
On 3/4/2024 at 7:21 PM, dynamic said:
@Fiery please.. See all the users missing this Feature or a workaround, years waiting to support the Lian Li Fans…
We've tried our best, but so far we couldn't find a way to talk to Lian Li Uni fan controllers, no matter what technique we've tried :(
It is that they (Lian Li) are not working with you (Finalwire) or is it a technical limitation?
