Hi there,
i'm running a portable version of AIDA.
In my case it's stored in Dropbox or in OneDrive. I see a constant change/write in the file aida64.reg.ini
Can anyone confirm this behaviour, how can i fix this - cause even the file is very smal (4 kb) i don't want a permanent change in my cloud drives...
thanks and regards
7 hours ago, dynamic said:
Hi there,
thanks and regards
AIDA64.REG.INI file is created and updated when you have the option NoRegistry enabled in the AIDA64.INI settings file.  In that case AIDA64.REG.INI acts as a proxy for Registry, hence it's normal that it's being updated frequently.
