theking25 Posted May 18, 2012 Posted May 18, 2012 my problem is when i start the program it turn the memorycard reader on and off continuously and the program hangs. what is the problem ?
Fiery Posted May 18, 2012 Posted May 18, 2012 Please create a Quick Report of the Devices / USB Devices page of AIDA64 (right-click on USB Devices in the left menu --> Quick Report --> Plain text), and copy-paste the full results into this topic. We'll use the data to filter out the USB ID of your card reader from the external disks enumeration. That will fix the on/off issues. Thanks, Fiery
theking25 Posted May 18, 2012 Author Posted May 18, 2012 here ist the report http://tinypaste.com/e8d8012a
Fiery Posted May 18, 2012 Posted May 18, 2012 Thank you, we'll fix that in the next AIDA64 beta release. However, please note that you were not using AIDA64 Extreme Edition, but an old Everest release
theking25 Posted May 18, 2012 Author Posted May 18, 2012 i have used an old everest release because aida64 hangs when it start
Fiery Posted May 20, 2012 Posted May 20, 2012 Make sure to upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1950z5qmwvn6bfzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Thanks, Fiery
Talos Posted June 14, 2012 Posted June 14, 2012 Hello, i have the same problem with my Silverstone FP37 USB 3.0 Cardreader. http://tinypaste.com/48a1eeed the new beta is installed
Fiery Posted June 16, 2012 Posted June 16, 2012 i have the same problem with my Silverstone FP37 USB 3.0 Cardreader. Make sure to upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild2018px8g7jbrkyzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps
Please sign in to comment
Sign In Now
