Борислав Стефанов Posted July 20, 2021 Posted July 20, 2021 Hey all. When using the program I got to think how the tool actually monitors the temperatures of the system. Researching a bit I found out that you could check your CPU temperature (as an example) using Windows' WMI. However a lot of people have mentioned that this is not an accurate method of doing so. What do you guys think? Quote
Fiery Posted July 21, 2021 Posted July 21, 2021 On 7/20/2021 at 4:49 PM, Борислав Стефанов said: Hey all. When using the program I got to think how the tool actually monitors the temperatures of the system. Researching a bit I found out that you could check your CPU temperature (as an example) using Windows' WMI. However a lot of people have mentioned that this is not an accurate method of doing so. What do you guys think? Expand AIDA64 only uses WMI as a temperature measurement interface on certain mobile computers. But, it only goes WMI (which is a slow interface) when the CPU thermal reading cannot be measured using a direct method. Quote
Борислав Стефанов Posted July 21, 2021 Author Posted July 21, 2021 On 7/21/2021 at 1:09 PM, Fiery said: AIDA64 only uses WMI as a temperature measurement interface on certain mobile computers. But, it only goes WMI (which is a slow interface) when the CPU thermal reading cannot be measured using a direct method. Expand So that direct method would be directly accessing the hardware's sensors? Quote
Fiery Posted July 21, 2021 Posted July 21, 2021 On 7/21/2021 at 4:21 PM, Борислав Стефанов said: So that direct method would be directly accessing the hardware's sensors? Expand Yes, as long as it's available. But certainly more direct than WMI which is a high-level, hardware agnostic interface. Quote
