On Sensor page all OK (APC Smart-UPS 1000)
but it's impossible to set desired values (20-30V for battery and 200-250V for UPS input/output) in Preferences -> Alerting -> New -> Battery, Battery Input and Battery Output
there's 15V max.
Thank you for reporting about that issue. It will be fixed in the next AIDA64 beta release. I'll drop a message into this topic once the new beta is available.
Battery Input/Output values are now normal. And Battery max value is still has 15 V limitation. My APC Smart-UPS 1000 contains two batteries in series. Current voltage (27.270 V) you can see in the picture in the first message on this topic. In my case the output voltage should not be below 20 V and above in 30 V.
Thank you, we'll fix that in the next AIDA64 beta release.
