Hi, has anyone been able to figure out how / what sensor in AIDA displays this port? Under the sensor / cooling fans I have: CPU, CPU Out, Chassis #1,2,3 and one called PCH.
(it also shows Power supply, Water Pump, Water Flow, GPU and GPU2 but I don't think they are the correct ones).
I thought it might be the PCH sensor in AIDA, but using AI_Suite, I can change the RPM of the "High Amp Fan" but so far no changes to the PCH sensor so I guess that's not the right one.
Any ideas?
(currently using licensed v6.33.5749 beta - and btw, love the addition of GPU VRAM!!!)
Any ideas?
We've checked and HAMP fan measurement should work properly.  We may find a trick there if you could kindly submit an ISA Sensor Dump and an Embedded Controller Dump.  Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
