jalong Posted June 9, 2012 Posted June 9, 2012 I've been trying to make a DL and UL speed graph for the Logitech G19 LCD. My download speeds range from 0 to ~11000 KBps. Unfortunately, I can't get the graphs to autoscale. I check off autoscale when I'm modifying the graph properties but it has no effect. When I subsequently open up the properties sheet again, the autoscale checkbox is blank. Any possibility of a fix? I'm using Extreme Edition v.2.50.2000. Quote
Fiery Posted June 9, 2012 Posted June 9, 2012 Please export your SensorPanel settings (right-click on the SensorPanel --> SensorPanel Manager --> Export button) into a file, and attach the .sensorpanel file into a message in this topic. We'll check your settings and provide you a solution. Thanks, Fiery Quote
jalong Posted June 11, 2012 Author Posted June 11, 2012 Thanks, here's the file. Autoscaling works in the sensor panel but not on the LCD. 2012-06-11.zip Quote
Fiery Posted June 11, 2012 Posted June 11, 2012 Thank you. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild2013jdgxb3fcslzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
