NailJ Posted October 19, 2021 Posted October 19, 2021 HI, Sorry if this has been answered before but I didn't find it. I want to upload to the newest Aida64 Extreme but I use a portable version. Is there anyway to update a portable version, so I can keep all my settings and Sensorpanel etc? Thanks Quote
NailJ Posted October 19, 2021 Author Posted October 19, 2021 I mean UPDATE ofc, not 'upload' lol. Sorry! Quote
NailJ Posted October 19, 2021 Author Posted October 19, 2021 Turns out I could just 'Check for update' under Help. Didn't know that worked on a portable version. Fail on my part! Any moderator: feel fre to delete this thread. Thanks and sorry. Quote
Fiery Posted October 19, 2021 Posted October 19, 2021 3 minutes ago, NailJ said: I mean UPDATE ofc, not 'upload' lol. Sorry! You can simply extract the portable ZIP package directly into the installation folder of the old AIDA64 version -- or the folder where you kept the old portable version. Let it overwrite any existing files. It will retain your previous settings, your SensorPanel and LCD layouts, your license, etc. 1 Quote
Fiery Posted October 19, 2021 Posted October 19, 2021 Just now, NailJ said: Turns out I could just 'Check for update' under Help. Didn't know that worked on a portable version. Fail on my part! Any moderator: feel fre to delete this thread. Thanks and sorry. That indeed works too as long as you have a valid license. 1 Quote
