Samsung 830 SSD no longer shows in Hardware Monitoring (ASRock X79 Extreme9)
After updating to the latest version (2.5), my samsung ssd no longer shows in hardware temperature monitoring. I re-installed 2.2 and it showed there.
1) Which Samsung SSD do you have?
2) What motherboard do you have?
3) Do you have any RAID arrays defined?
4) Do you have Intel RST or RST Enterprise drivers installed? If yes, then which version of it?
Make sure to have the latest WHQL Intel RST Enterprise driver installed, and use the latest AIDA64 beta release available at:
http://www.aida64.co...18px8g7jbrkyzip
Also, make sure to have the options RAID member enumeration and RAID SMART support both enabled in AIDA64 / main menu / File / Preferences / Stability.
