Vesimas Posted October 24, 2021 Posted October 24, 2021 As subject, i created a sensor panel in an old version, today i installed all the software in the new computer, included the last version of Aida64, but now i don't have the single temperature of the 8 core but i can only use CPU temp or CPU Package and not the single cores. Is it normal? TY Quote
Fiery Posted October 25, 2021 Posted October 25, 2021 19 hours ago, Vesimas said: As subject, i created a sensor panel in an old version, today i installed all the software in the new computer, included the last version of Aida64, but now i don't have the single temperature of the 8 core but i can only use CPU temp or CPU Package and not the single cores. Is it normal? TY What CPU do you have? Please note that AMD processors do not feature a per-core thermal diode. By going from Intel to AMD CPU, you may indeed lose core temperature readings due to hardware limitation. Quote
Vesimas Posted October 25, 2021 Author Posted October 25, 2021 Ok, mistery solved. I have done it on Intel CPU and now i have a Ryzen :V TY Fiery Quote
