Elderdeekey Posted November 1, 2021 Posted November 1, 2021 I've lost Corsair's Vengeance RGB Pro modules temperature reading - Corsair made microcode update just recently to those modules to firmware 1.02.64. Temperature reading of those modules works just fine inside Corsair's ICUE software. Version: 6.50.5806 beta (Oct 28, 2021) fixed the problem with all OCTO sensors after aqua computer updated its microcode but not with Corsair RAM. DIMM thermal sensor support enabled: Attaching 2 debug files, please let me know if I should debug something else. Fiery, many thanks in advance, as usual! aquacomputerdump.txt sensorprof.txt Quote
Fiery Posted November 8, 2021 Posted November 8, 2021 On 11/1/2021 at 4:11 PM, Elderdeekey said: I've lost Corsair's Vengeance RGB Pro modules temperature reading - Corsair made microcode update just recently to those modules to firmware 1.02.64. Temperature reading of those modules works just fine inside Corsair's ICUE software. Version: 6.50.5806 beta (Oct 28, 2021) fixed the problem with all OCTO sensors after aqua computer updated its microcode but not with Corsair RAM. DIMM thermal sensor support enabled: Attaching 2 debug files, please let me know if I should debug something else. Fiery, many thanks in advance, as usual! Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Elderdeekey Posted November 9, 2021 Author Posted November 9, 2021 Not sure debug worked as intended, see no info in the file except MB info. Anyway, please find attache that file. Thank you! smbusdump_full.txt Quote
Elderdeekey Posted November 21, 2021 Author Posted November 21, 2021 Case closed! After playing with AIDA64 Stability settings I've managed to find the reason why SMBus Dump (full) had no information. The reason was enabled "SMBus acess through ACPI (Asus motherboard)": As soon as I uncheck it: 1. SMBus Dump (full) started to produce full results (attached) AND 2. I see all 4 DIMMs temperature now: I do not know is it a bug or a feature of this setting but enabling it on my ASUS ROG Maximus X Formula blocks DIMMs temp. reading. smbusdump_full_new.txt 1 Quote
Alpharius68 Posted December 2, 2021 Posted December 2, 2021 Thanks... thats fixed my RAM Temp issues. Quote
