ZordTra Posted December 25, 2021 Posted December 25, 2021 i just got this program and tried to change the gauges but when i click on sensor panel manager it wont open it (it does nothing) is there a solution for this Quote
Fiery Posted December 27, 2021 Posted December 27, 2021 On 12/25/2021 at 4:09 PM, ZordTra said: i just got this program and tried to change the gauges but when i click on sensor panel manager it wont open it (it does nothing) is there a solution for this I suppose the SensorPanel Manager opens on another, currently inactive monitor or some other part of the Windows Desktop that's not visible. Try to open Registry Editor (run REGEDIT.EXE), navigate to: HKEY_CURRENT_USER\Software\FinalWire\AIDA64 And remove the following entries: SensorPanelMgrPosX SensorPanelMgrPosY SensorPanelMgrWindowSizeX SensorPanelMgrWindowSizeY That should reset the SensorPanel Manager window position and dimensions and should make you see it and use it again. Quote
