Hincho Posted February 1, 2022 Posted February 1, 2022 My case fan and CPU fan are not detected by AIDA64. I can see the fan speeds in the BIOS and in the motherboard software AI Suit 3. The fans are connected directly into the motherboard headers. I am a novice with AIDA64, so I am probably doing something wrong. Hardware Motherboard: ASUS Strix B560-I Gaming CPU: Core i7 11700K Fans: Noctua NF-A12x25 Chromax black Also, I see often the techs will ask for - Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug -->ISA Sensor Dump. I can't see any status bar at the bottom of the main window to right click on? Quote
LusekGaming Posted February 6, 2022 Posted February 6, 2022 Park here. I also had the same issue. Quote
Fiery Posted February 15, 2022 Posted February 15, 2022 On 2/1/2022 at 12:42 PM, Hincho said: My case fan and CPU fan are not detected by AIDA64. I can see the fan speeds in the BIOS and in the motherboard software AI Suit 3. The fans are connected directly into the motherboard headers. I am a novice with AIDA64, so I am probably doing something wrong. Hardware Motherboard: ASUS Strix B560-I Gaming CPU: Core i7 11700K Fans: Noctua NF-A12x25 Chromax black Also, I see often the techs will ask for - Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug -->ISA Sensor Dump. I can't see any status bar at the bottom of the main window to right click on? Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
Mario FL Posted June 10, 2022 Posted June 10, 2022 On 2/15/2022 at 9:23 PM, Fiery said: Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. not work Quote
Fiery Posted June 10, 2022 Posted June 10, 2022 1 minute ago, Mario FL said: not work Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
HDCL Posted June 22, 2022 Posted June 22, 2022 I have the exact same issue with an Asus Tuf Gaming Z690 Plus WiFi motherboard. I only see the GPU fans. No case fans and no CPU can. Every other software (3rd party or otherwise like HWInfo64) can see these fans and their RPM. Sensor Dump attached isasensordump.txt Quote
Wallerz Posted August 1, 2022 Posted August 1, 2022 Is there any update on this? I have the same problem Quote
NAVEIN PUSPANADAN Posted August 4, 2022 Posted August 4, 2022 Having the same issue of CPU Fan not appearing. isasensordump.txt Quote
BeastWookie Posted August 30, 2022 Posted August 30, 2022 im also having the same issue please someone update on fix. chassis fan wont read anymore and wont let me make changes to it either in aida64. ISA sensor dump below ------[ Versions ]------ Program Version : AIDA64 Extreme v6.75.6100 BenchDLL Version: 4.6.871.8-x64 Windows Version : Microsoft Windows 10 Home 10.0.19044.1889 (64-bit) GetProductInfo : 0x00000065 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : MSI MEG Z590 Godlike (MS-7D03) Motherboard Chipset : Intel Tiger Point Z590, Intel Rocket Lake-S DMI MB Manufacturer : Micro-Star International Co., Ltd. DMI MB Product : MEG Z590 GODLIKE (MS-7D03) DMI MB Version : 2.0 DMI MB Serial : 07D0321_L31E080926 DMI SYS Manufacturer: Micro-Star International Co., Ltd. DMI SYS Product : MS-7D03 DMI SYS Version : 2.0 DMI SYS Serial : Default string DMI BIOS Version : A.50 ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 4Eh Winbond SuperIO HWMonitor Port/60 = 0A20h (0000h / 0A20h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = D592h (0000h / D592h) Winbond Sensor ID A3/5C/reg$58 = FF / FF / FF Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #0 ]------ 0000 D5 92 1C 00 00 00 00 03 FF 00 FC 83 01 00 01 F8 0010 3F E6 2F 00 00 00 06 79 FF FF FE FF FF FF FF FF 0020 FF FF 00 00 00 00 01 40 FF FF FF FF FF FF FF FF 0030 C3 01 00 04 00 00 00 00 00 44 0E 03 1E 01 00 92 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 DC EB F5 FE 05 0C 12 19 20 27 2F 39 45 55 73 A7 0090 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 B0 F0 A0 90 70 70 60 70 70 70 80 A0 C0 00 E0 48 00B0 40 00 00 17 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #1 ]------ 0000 26 80 27 00 29 00 37 00 24 80 D8 00 D8 00 2A 00 0010 2B 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 3E C0 3E 80 4C 40 4C C0 2A 40 7F A0 7F A0 5E 80 0030 CC C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 06 28 00 00 00 00 00 00 00 00 00 00 05 80 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 B2 FF 99 99 99 99 FF 99 09 00 3A 00 00 61 45 75 0070 06 00 00 00 00 00 00 00 00 00 FF 01 BE 03 00 07 0080 80 00 08 20 00 05 01 05 2F 02 02 0A 00 00 7A FF 0090 2A 2B 27 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 20 02 09 31 0A 0B 0C 50 51 52 00 00 00 00 00 00 00B0 66 67 68 69 6A 6B 6C 6D 60 00 00 00 00 00 00 00 00C0 A1 A3 AB AD AF B1 B3 A6 A7 A9 20 20 20 20 20 20 00D0 A0 A2 AA AC AE B0 B2 A4 06 06 06 06 06 06 06 06 00E0 06 40 06 40 06 40 06 40 06 40 06 40 06 40 06 40 00F0 80 80 80 80 80 80 80 80 00 03 40 05 20 00 09 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #2 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 83 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 00 01 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 00 00 00 08 00 00 00 00 60 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #3 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #4 ]------ 0000 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 93 96 40 00 33 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 80 04 03 82 00 28 03 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #5 ]------ 0000 01 01 00 33 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 F1 F5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 10 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 81 01 07 07 05 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #6 ]------ 0000 D5 92 02 00 15 03 03 03 01 00 00 00 12 05 16 00 0010 C7 31 FF FF 12 05 1E 00 00 00 00 00 00 00 00 00 0020 C7 03 00 1A 8B 01 00 00 00 00 00 00 00 00 00 00 0030 00 01 00 00 00 00 00 00 47 10 00 00 00 00 00 00 0040 50 00 47 10 00 00 00 00 00 00 00 00 00 00 00 00 0050 A7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 01 00 00 50 00 02 00 00 00 00 00 00 00 00 01 00B0 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 12 05 16 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #7 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 C0 00 00 00 00 00 80 00 00 00 00 80 00 00 00 00 0020 00 00 00 00 00 00 00 00 80 20 09 01 01 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 08 08 00 80 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #8 ]------ 0000 01 80 11 0A 03 00 00 03 00 00 00 00 00 00 00 00 0010 11 11 11 11 11 11 11 11 11 11 01 01 01 01 01 01 0020 01 01 01 01 01 01 01 01 01 01 01 01 01 01 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 85 80 B1 40 CA 80 00 00 00 00 00 00 00 00 00 00 0050 FF F8 FF F8 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 40 40 00 00 00 00 00 00 66 66 00 00 00 00 00 00 00F0 99 00 00 00 A5 A8 06 06 06 40 06 40 80 80 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #9 ]------ 0000 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0 00 00 00 00 00 00 0010 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 01 0020 00 00 00 01 00 00 00 01 00 00 00 08 00 00 00 01 0030 00 00 00 01 00 00 00 04 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 65 65 65 65 65 65 65 65 65 65 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 03 03 03 03 03 03 03 03 03 03 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #10 ]------ 0000 00 00 00 00 00 00 00 00 40 40 40 40 40 40 40 40 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 66 66 66 66 66 66 66 66 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 05 DC 09 C4 64 64 64 11 0050 00 00 00 00 00 00 00 00 00 28 41 B0 02 02 00 03 0060 00 80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 80 17 28 00 00 00 80 00 00 00 0080 01 00 00 00 0A 00 00 00 02 00 00 00 A0 00 00 00 0090 04 00 00 00 00 0A 00 00 08 00 00 00 00 A0 00 00 00A0 10 00 00 00 00 00 0A 00 20 00 00 00 00 00 A0 00 00B0 40 00 00 00 00 00 00 0A 80 00 00 00 00 00 00 A0 00C0 00 01 00 0A 00 00 00 00 00 02 00 A0 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #11 ]------ 0000 00 1E 32 64 64 64 64 00 B2 00 B2 00 B2 00 B2 00 0010 B2 00 B2 00 B2 00 00 05 20 20 20 20 20 20 20 00 0020 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 00 05 0030 0A 14 1E 28 32 3C 46 00 99 00 99 00 99 00 99 00 0040 99 00 99 00 99 00 00 05 0A 14 1E 28 32 3C 46 00 0050 99 00 99 00 99 00 99 00 99 00 99 00 99 00 00 05 0060 0A 14 1E 28 32 3C 46 00 99 00 99 00 99 00 99 00 0070 99 00 99 00 99 00 00 05 0A 14 1E 28 32 3C 46 00 0080 99 00 99 00 99 00 99 00 99 00 99 00 99 00 00 05 0090 00 2B 47 64 64 64 64 00 FF 00 FF 00 FF 00 FF 00 00A0 FF 00 FF 00 FF 00 00 05 0A 14 1E 28 32 3C 46 00 00B0 99 00 99 00 99 00 99 00 99 00 99 00 99 00 00 05 00C0 0A 14 1E 28 32 3C 46 00 99 00 99 00 99 00 99 00 00D0 99 00 99 00 99 00 00 05 41 4B 5A 64 64 64 64 00 00E0 00 00 3F 00 66 00 99 00 99 00 99 00 99 00 00 05 00F0 0A 14 1E 28 32 3C 46 00 66 00 7F 00 99 00 B2 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #12 ]------ 0000 CC 00 E5 00 FF 02 05 05 0A 14 1E 28 32 3C 46 00 0010 66 00 7F 00 99 00 B2 00 CC 00 E5 00 FF 02 05 05 0020 0A 14 1E 28 32 3C 46 00 66 00 7F 00 99 00 B2 00 0030 CC 00 E5 00 FF 02 05 05 0A 14 1E 28 32 3C 46 00 0040 66 00 7F 00 99 00 B2 00 CC 00 E5 00 FF 02 05 05 0050 0A 14 1E 28 32 3C 46 00 66 00 7F 00 99 00 B2 00 0060 CC 00 E5 00 FF 02 05 05 0A 14 1E 28 32 3C 46 00 0070 66 00 7F 00 99 00 B2 00 CC 00 E5 00 FF 02 05 05 0080 00 B2 00 FF 00 99 00 99 00 99 00 99 00 FF 00 99 0090 00 99 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 2B 2B 2B 2B 2B 2B 36 2B 2B 29 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 60 00 00 03 FF 80 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #13 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #14 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #15 ]------ 0000 28 37 46 55 65 99 99 99 99 01 01 01 03 C3 01 00 0010 99 26 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A20 / Bank #16 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 FF 90 00 57 00 00 00 00 00 00 00 00 00 00 00 00 00F0 11 00 00 00 80 C1 00 00 00 00 00 81 C1 00 00 00 0100 0102 0104 0106 0108 T: 43 39 41 54 36 T: 48 39 41 55 36 T: 48 39 41 55 36 T: 39 39 41 54 36 T: 39 39 41 53 36 T: 45 39 41 53 36 T: 41 39 41 53 36 T: 39 39 41 52 36 T: 42 39 41 54 37 T: 39 39 41 53 37 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #0 ]------ 0000 D5 92 1C 00 00 00 00 03 FF 00 FC 83 01 00 01 F8 0010 3F E6 2F 00 00 00 06 79 FF FF FE FF FF FF FF FF 0020 FF FF 00 00 00 00 01 40 FF FF FF FF FF FF FF FF 0030 C3 01 00 04 00 00 00 00 00 44 0E 03 1E 01 00 92 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 DC EB F5 FE 05 0C 12 19 20 27 2F 39 45 55 73 A7 0090 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 B0 F0 A0 90 70 70 60 70 70 70 80 A0 C0 00 E0 48 00B0 40 00 00 17 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #1 ]------ 0000 26 00 27 80 29 80 35 00 25 00 D8 00 D8 00 2A 00 0010 2B 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 3E A0 3E 80 4C 40 4C C0 2A 40 7F A0 7F A0 5E A0 0030 CC C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 06 20 00 00 00 00 00 00 00 00 00 00 05 8A 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 B2 FF 99 99 99 99 FF 99 09 00 7B 00 00 F7 02 C6 0070 06 00 00 00 00 00 00 00 00 00 FF 01 BE 03 00 07 0080 80 00 08 20 00 05 01 05 2F 02 02 0A 00 00 7A FF 0090 80 80 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 20 02 09 31 0A 0B 0C 50 51 52 00 00 00 00 00 00 00B0 66 67 68 69 6A 6B 6C 6D 60 00 00 00 00 00 00 00 00C0 A1 A3 AB AD AF B1 B3 A6 A7 A9 20 20 20 20 20 20 00D0 A0 A2 AA AC AE B0 B2 A4 06 06 06 06 06 06 06 06 00E0 06 40 06 40 06 40 06 40 06 40 06 40 06 40 06 40 00F0 80 80 80 80 80 80 80 80 00 03 40 05 20 00 09 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #2 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 83 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 00 01 00 00 00 01 00 01 00 00 00 00 00 00 00 00 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 00 00 00 08 00 00 00 00 60 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #3 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #4 ]------ 0000 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 93 96 40 00 33 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 80 04 03 82 00 28 03 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #5 ]------ 0000 01 01 00 33 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 F1 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 10 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 81 01 07 07 05 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #6 ]------ 0000 D5 92 02 00 15 03 03 03 01 00 00 00 12 05 16 00 0010 C7 31 FF FF 12 05 1E 00 00 00 00 00 00 00 00 00 0020 CE 03 00 1B 8B 01 00 00 00 00 00 00 00 00 00 00 0030 00 01 00 00 00 00 00 00 47 10 00 00 00 00 00 00 0040 50 00 47 10 00 00 00 00 00 00 00 00 00 00 00 00 0050 A7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 01 00 00 50 00 02 00 00 00 00 00 00 00 00 01 00B0 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 12 05 16 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #7 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 C0 00 00 00 00 00 80 00 00 00 00 80 00 00 00 00 0020 00 00 00 00 00 00 00 00 80 20 09 01 01 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 08 08 00 80 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #8 ]------ 0000 01 80 11 0A 03 00 00 03 00 00 00 00 00 00 00 00 0010 11 11 11 11 11 11 11 11 11 11 01 01 01 01 01 01 0020 01 01 01 01 01 01 01 01 01 01 01 01 01 01 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 85 80 B1 40 CA C0 00 00 00 00 00 00 00 00 00 00 0050 FF F8 FF F8 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 40 40 00 00 00 00 00 00 66 66 00 00 00 00 00 00 00F0 99 00 00 00 A5 A8 06 06 06 40 06 40 80 80 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #9 ]------ 0000 C0 C0 C0 C0 C0 C0 C0 C0 C0 C0 00 00 00 00 00 00 0010 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 01 0020 00 00 00 01 00 00 00 01 00 00 00 08 00 00 00 01 0030 00 00 00 01 00 00 00 04 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 65 65 65 65 65 65 65 65 65 65 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 03 03 03 03 03 03 03 03 03 03 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #10 ]------ 0000 00 00 00 00 00 00 00 00 40 40 40 40 40 40 40 40 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 66 66 66 66 66 66 66 66 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 05 DC 09 C4 64 64 64 11 0050 00 00 00 00 00 00 00 00 00 28 41 B0 02 02 00 03 0060 00 80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 80 17 28 00 00 00 80 00 00 00 0080 01 00 00 00 0A 00 00 00 02 00 00 00 A0 00 00 00 0090 04 00 00 00 00 0A 00 00 08 00 00 00 00 A0 00 00 00A0 10 00 00 00 00 00 0A 00 20 00 00 00 00 00 A0 00 00B0 40 00 00 00 00 00 00 0A 80 00 00 00 00 00 00 A0 00C0 00 01 00 0A 00 00 00 00 00 02 00 A0 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #11 ]------ 0000 00 1E 32 64 64 64 64 00 B2 00 B2 00 B2 00 B2 00 0010 B2 00 B2 00 B2 00 00 05 20 20 20 20 20 20 20 00 0020 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 00 05 0030 0A 14 1E 28 32 3C 46 00 99 00 99 00 99 00 99 00 0040 99 00 99 00 99 00 00 05 0A 14 1E 28 32 3C 46 00 0050 99 00 99 00 99 00 99 00 99 00 99 00 99 00 00 05 0060 0A 14 1E 28 32 3C 46 00 99 00 99 00 99 00 99 00 0070 99 00 99 00 99 00 00 05 0A 14 1E 28 32 3C 46 00 0080 99 00 99 00 99 00 99 00 99 00 99 00 99 00 00 05 0090 00 2B 47 64 64 64 64 00 FF 00 FF 00 FF 00 FF 00 00A0 FF 00 FF 00 FF 00 00 05 0A 14 1E 28 32 3C 46 00 00B0 99 00 99 00 99 00 99 00 99 00 99 00 99 00 00 05 00C0 0A 14 1E 28 32 3C 46 00 99 00 99 00 99 00 99 00 00D0 99 00 99 00 99 00 00 05 41 4B 5A 64 64 64 64 00 00E0 00 00 3F 00 66 00 99 00 99 00 99 00 99 00 00 05 00F0 0A 14 1E 28 32 3C 46 00 66 00 7F 00 99 00 B2 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #12 ]------ 0000 CC 00 E5 00 FF 02 05 05 0A 14 1E 28 32 3C 46 00 0010 66 00 7F 00 99 00 B2 00 CC 00 E5 00 FF 02 05 05 0020 0A 14 1E 28 32 3C 46 00 66 00 7F 00 99 00 B2 00 0030 CC 00 E5 00 FF 02 05 05 0A 14 1E 28 32 3C 46 00 0040 66 00 7F 00 99 00 B2 00 CC 00 E5 00 FF 02 05 05 0050 0A 14 1E 28 32 3C 46 00 66 00 7F 00 99 00 B2 00 0060 CC 00 E5 00 FF 02 05 05 0A 14 1E 28 32 3C 46 00 0070 66 00 7F 00 99 00 B2 00 CC 00 E5 00 FF 02 05 05 0080 00 B2 00 FF 00 99 00 99 00 99 00 99 00 FF 00 99 0090 00 99 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 28 28 28 28 28 28 35 28 28 29 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 60 00 00 03 FF 80 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #13 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #14 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #15 ]------ 0000 28 37 46 55 65 99 99 99 99 01 01 01 03 C3 01 00 0010 99 27 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ NCT6683 ISA Sensor Device at 0A24 / Bank #16 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 FF 90 00 57 00 00 00 00 00 00 00 00 00 00 00 00 00F0 11 00 00 00 80 C1 00 00 00 00 00 81 C1 00 00 00 0100 0102 0104 0106 0108 T: 40 39 41 53 37 T: 48 39 41 53 37 T: 48 39 41 53 37 T: 39 39 41 53 37 T: 39 39 41 53 37 T: 38 39 41 53 37 T: 38 39 41 52 37 T: 39 40 41 53 37 T: 39 39 41 53 37 T: 41 39 41 53 37 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA> _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : Quote
fredz69 Posted September 22, 2022 Posted September 22, 2022 I have different MB but same issue, but can see all missing from Aida64 in Bios & HWMonitor etc Quote
StevenGriffin Posted March 31, 2023 Posted March 31, 2023 I have the same issue any fix? I have CPU but not my case fans isasensordump.txt Quote
Maybe_Me Posted June 15, 2024 Posted June 15, 2024 I have the same problem any one resolve this? Quote
Fiery Posted June 17, 2024 Posted June 17, 2024 On 6/15/2024 at 8:55 AM, Maybe_Me said: I have the same problem any one resolve this? In AIDA64 please press Ctrl+Alt+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Maybe_Me Posted June 17, 2024 Posted June 17, 2024 Can you please identify why mine is not showing either Many Thanks Andy MSI b790.txt Quote
Fiery Posted June 19, 2024 Posted June 19, 2024 On 6/17/2024 at 4:36 PM, Maybe_Me said: Can you please identify why mine is not showing either Many Thanks Andy MSI b790.txt 38.59 kB · 2 downloads The issue will be fixed in the next AIDA64 beta update. Quote
Fiery Posted July 3, 2024 Posted July 3, 2024 On 6/17/2024 at 4:36 PM, Maybe_Me said: Can you please identify why mine is not showing either Please check the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta Quote
Growcub Posted August 12, 2024 Posted August 12, 2024 I'm having the same issue after upgrading to the beta and restarting. isasensordump.txt Quote
KKFatso Posted August 15, 2024 Posted August 15, 2024 Same here after v7.35.7004 Beta update. Lost RPM sensors, CPU and motherboard temps and GPU clock and utilization. Downgraded to .7000 and that works. isasensordump.txt Quote
Fiery Posted August 16, 2024 Posted August 16, 2024 On 8/12/2024 at 8:02 AM, Growcub said: I'm having the same issue after upgrading to the beta and restarting Something got mixed up about the AIDA64 kernel driver. Try to restart Windows, in most cases that helps. Quote
Fiery Posted August 16, 2024 Posted August 16, 2024 21 hours ago, KKFatso said: Same here after v7.35.7004 Beta update. Lost RPM sensors, CPU and motherboard temps and GPU clock and utilization. Downgraded to .7000 and that works. Something got mixed up about the AIDA64 kernel driver. Try to restart Windows, in most cases that helps. Quote
Rike Posted February 26, 2025 Posted February 26, 2025 Hi, i am having no fan information at all in the sensors panel. It does not recognize CPU and GPU Fans. I have a Laptop, Schenker Vision Pro 16, using AIDA 7.60.7304 beta. Restarts and such did not help. I would be happy for any help, Thanks Sensor Eigenschaften Sensortyp CPU, HDD, DIMM TS, ACPI, SNB GPU Sensortyp Driver (NV-DRV) Temperaturen CPU 48 °C CPU Package 54 °C CPU IA Cores 54 °C CPU GT Cores 46 °C 1. CPU / 1. Kern 43 °C 1. CPU / 2. Kern 41 °C 1. CPU / 3. Kern 56 °C 1. CPU / 4. Kern 44 °C 1. CPU / 5. Kern 44 °C 1. CPU / 6. Kern 41 °C 1. CPU / 7. Kern 46 °C 1. CPU / 8. Kern 46 °C 1. CPU / 9. Kern 46 °C 1. CPU / 10. Kern 46 °C 1. CPU / 11. Kern 44 °C 1. CPU / 12. Kern 44 °C 1. CPU / 13. Kern 44 °C 1. CPU / 14. Kern 44 °C GPU Hotspot 47 °C GPU Speicher 50 °C DIMM1 40 °C DIMM3 39 °C Samsung SSD 980 PRO 2TB 37 °C / 48 °C Samsung SSD 990 PRO 2TB 35 °C / 50 °C Spannungswerte CPU Kern 0.675 V CPU VID 0.675 V Akku 16.677 V GPU Kern 0.630 V GPU 12VHPWR 22.715 V Leistungswerte CPU Package 10.69 W CPU IA Cores 4.44 W CPU GT Cores 0.00 W Akku Aufladeanteil Netzanschluss Grafikprozessor (GPU) 590.01 W GPU TDP% 0% GPU 12VHPWR 587.00 W 0 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : NB02 PH6PG01_PH6PG71 Motherboard Chipset : Intel Raptor Point-P, Intel Raptor Lake-H/P/PX DMI MB Manufacturer : NB02 DMI MB Product : PH6PG01_PH6PG71 DMI MB Version : Standard DMI MB Serial : Standard DMI SYS Manufacturer: SchenkerTechnologiesGmbH DMI SYS Product : SCHENKER VISION (M23) DMI SYS Version : Standard DMI SYS Serial : PH6PG012232107364 DMI BIOS Version : N.1.10A07 ------[ PCI Devices ]------ B00-D00-F00 [8086-A706] [1D05-124E] [CC0600]: Intel Raptor Lake-H/P/PX 6+8 - Host Bridge/DRAM Controller ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = 0000h (0000h / 0000h) Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3222</DATA> _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : ========================================================================== ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : EFA0 Can Have SPD: Yes DDR5 : Yes Scan Type : Full ------[ SMBus Device B00-D44 ]------ 0000 00 00 00 04 00 00 00 00 00 03 06 08 03 26 02 25 .............&.% 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF03 FF06 FF08 FF03 FF26 FF02 FF25 0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 ------[ SMBus Device B00-D48 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010 00 00 00 00 00 2C 20 00 00 04 00 05 60 00 60 60 ....., .....`.`` 0020 89 78 63 00 00 78 63 78 63 90 9A 42 20 22 04 5A .xc..xcxc..B ".Z 0030 00 00 80 00 0E 00 00 00 00 00 00 12 8A 8C 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D48 ]------ 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0010 0000 0000 0000 0000 2C00 202C 0020 0000 0400 0004 0500 6005 0060 6000 6060 8960 0020 7889 6378 0063 0000 7800 6378 7863 6378 9063 9A90 429A 2042 2220 0422 5A04 005A 0030 0000 8000 0080 0E00 000E 0000 0000 0000 0000 0000 1200 8A12 8C8A 008C 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ------[ SMBus Device B00-D4A ]------ 0000 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 ................ 0010 00 00 00 00 00 2C 20 00 00 04 00 05 60 00 60 60 ....., .....`.`` 0020 89 78 63 00 00 78 63 78 63 90 9A 42 20 22 04 5A .xc..xcxc..B ".Z 0030 00 00 80 04 0E 00 00 00 00 00 00 12 8A 8C 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D4A ]------ 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0200 0002 0000 0000 0000 0000 0000 0010 0000 0000 0000 0000 2C00 202C 0020 0000 0400 0004 0500 6005 0060 6000 6060 8960 0020 7889 6378 0063 0000 7800 6378 7863 6378 9063 9A90 429A 2042 2220 0422 5A04 005A 0030 0000 8000 0480 0E04 000E 0000 0000 0000 0000 0000 1200 8A12 8C8A 008C 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ------[ SMBus Device B00-D50 ]------ 0000 30 10 12 03 04 00 20 62 00 00 00 00 A0 01 07 00 0..... b........ 0010 00 00 00 00 A0 01 F2 03 7A 0D 00 00 00 00 80 3E ........z......> 0020 80 3E 80 3E 00 7D 80 BB 30 75 27 01 A0 00 82 00 .>.>.}..0u'..... 0030 00 00 00 00 00 00 D4 00 00 00 D4 00 00 00 D4 00 ................ 0040 00 00 D4 00 00 00 88 13 08 88 13 08 20 4E 20 10 ............ N . 0050 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00 '..4 .'....L.... 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 10 00 86 32 80 15 8A 8C 82 13 00 00 00 00 00 00 ...2............ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 0F 01 00 82 00 22 00 00 00 00 ...........".... 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7D 84 ..............}. 0200 85 9B 00 23 39 E9 07 74 C0 43 54 31 36 47 34 38 ...#9..t.CT16G48 0210 43 34 30 53 35 2E 4D 38 41 31 20 20 20 20 20 20 C40S5.M8A1 0220 20 20 20 20 20 20 20 55 80 2C 41 31 30 30 30 34 U.,A10004 0230 37 38 36 34 34 00 00 00 00 00 00 00 00 00 00 00 78644........... 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0320 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0330 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D50 ]------ 0000 51 18 0A 86 32 03 32 00 00 00 00 07 FF 03 00 00 Q...2.2......... 0010 00 00 00 00 00 00 00 00 00 00 00 00 70 03 00 00 ............p... 0020 50 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 P............... 0030 80 78 02 00 20 00 00 00 00 00 00 00 00 00 00 00 .x.. ........... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D50 ]------ 0000 30 10 12 03 04 00 20 62 00 00 00 00 A0 01 07 00 0..... b........ 0010 00 00 00 00 A0 01 F2 03 7A 0D 00 00 00 00 80 3E ........z......> 0020 80 3E 80 3E 00 7D 80 BB 30 75 27 01 A0 00 82 00 .>.>.}..0u'..... 0030 00 00 00 00 00 00 D4 00 00 00 D4 00 00 00 D4 00 ................ 0040 00 00 D4 00 00 00 88 13 08 88 13 08 20 4E 20 10 ............ N . 0050 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00 '..4 .'....L.... 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 10 00 86 32 80 15 8A 8C 82 13 00 00 00 00 00 00 ...2............ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 0F 01 00 82 00 22 00 00 00 00 ...........".... 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7D 84 ..............}. 0200 85 9B 00 23 39 E9 07 74 C0 43 54 31 36 47 34 38 ...#9..t.CT16G48 0210 43 34 30 53 35 2E 4D 38 41 31 20 20 20 20 20 20 C40S5.M8A1 0220 20 20 20 20 20 20 20 55 80 2C 41 31 30 30 30 34 U.,A10004 0230 37 38 36 34 34 00 00 00 00 00 00 00 00 00 00 00 78644........... 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0320 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0330 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D50 ]------ 0000 1851 0A18 860A 3286 0332 3203 0032 0000 0000 0000 0700 FF07 03FF 0003 0000 0000 0010 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 7000 0370 0003 0000 5000 0020 0550 0005 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 8000 0030 7880 0278 0002 2000 0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ------[ SMBus Device B00-D52 ]------ 0000 30 10 12 03 04 00 20 62 00 00 00 00 A0 01 07 00 0..... b........ 0010 00 00 00 00 A0 01 F2 03 7A 0D 00 00 00 00 80 3E ........z......> 0020 80 3E 80 3E 00 7D 80 BB 30 75 27 01 A0 00 82 00 .>.>.}..0u'..... 0030 00 00 00 00 00 00 D4 00 00 00 D4 00 00 00 D4 00 ................ 0040 00 00 D4 00 00 00 88 13 08 88 13 08 20 4E 20 10 ............ N . 0050 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00 '..4 .'....L.... 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 10 00 86 32 80 15 8A 8C 82 13 00 00 00 00 00 00 ...2............ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 0F 01 00 82 00 22 00 00 00 00 ...........".... 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7D 84 ..............}. 0200 85 9B 00 23 39 E9 07 75 73 43 54 31 36 47 34 38 ...#9..usCT16G48 0210 43 34 30 53 35 2E 4D 38 41 31 20 20 20 20 20 20 C40S5.M8A1 0220 20 20 20 20 20 20 20 55 80 2C 41 31 30 30 30 34 U.,A10004 0230 37 38 36 34 34 00 00 00 00 00 00 00 00 00 00 00 78644........... 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0320 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0330 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D52 ]------ 0000 51 18 0A 86 32 03 32 00 00 00 00 07 FF 03 00 00 Q...2.2......... 0010 00 00 00 00 00 00 00 00 00 00 00 00 70 03 00 00 ............p... 0020 50 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 P............... 0030 80 70 02 00 20 00 00 00 00 00 00 00 00 00 00 00 .p.. ........... 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D52 ]------ 0000 30 10 12 03 04 00 20 62 00 00 00 00 A0 01 07 00 0..... b........ 0010 00 00 00 00 A0 01 F2 03 7A 0D 00 00 00 00 80 3E ........z......> 0020 80 3E 80 3E 00 7D 80 BB 30 75 27 01 A0 00 82 00 .>.>.}..0u'..... 0030 00 00 00 00 00 00 D4 00 00 00 D4 00 00 00 D4 00 ................ 0040 00 00 D4 00 00 00 88 13 08 88 13 08 20 4E 20 10 ............ N . 0050 27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00 '..4 .'....L.... 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 10 00 86 32 80 15 8A 8C 82 13 00 00 00 00 00 00 ...2............ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 0F 01 00 82 00 22 00 00 00 00 ...........".... 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7D 84 ..............}. 0200 85 9B 00 23 39 E9 07 75 73 43 54 31 36 47 34 38 ...#9..usCT16G48 0210 43 34 30 53 35 2E 4D 38 41 31 20 20 20 20 20 20 C40S5.M8A1 0220 20 20 20 20 20 20 20 55 80 2C 41 31 30 30 30 34 U.,A10004 0230 37 38 36 34 34 00 00 00 00 00 00 00 00 00 00 00 78644........... 0240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0260 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0270 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0280 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0290 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 02F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0300 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0310 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0320 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0330 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0340 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0350 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0370 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0380 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0390 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 03F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D52 ]------ 0000 1851 0A18 860A 3286 0332 3203 0032 0000 0000 0000 0700 FF07 03FF 0003 0000 0000 0010 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 7000 0370 0003 0000 5000 0020 0550 0005 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 8000 0030 7080 0270 0002 2000 0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 *** SMBus Semaphore Disabled = 0 ------[ Chips Found ]------ B00-D52: uPI uP???? Quote
