fixed: AIDA64 Extreme and CPU FSB 275MHz (ASRrock H670M-ITX/ax + i5-12600)
Hi there folks!
I built a new 4K gaming system and am pretty happy with it. I'm posting this because I haven't seen anyone having similar issues. And trust me, I have looked!
I'm using the latest Aida64 Extreme (v.6.60.5900) and these components:
  • ASRrock H670M-ITX/ax (latest BIOS 5.01)
  • latest chipset drivers from ASRock
  • Intel i5-12600@stock (3.3GHz - 4.8GHz, 6P + 0E cores)
  • TeamGroup DDR4-3600cl14@stock (2x16Gb, dual rank)
  • EVGA 3080 Ti FTW3 Ultra (undervolted)
  • Samsung 980 Pro M.2 SSD
And here's the problem. Aida reports my CPU FSB as 275.2 MHz (original: 100MHz, overclock 175%). I admit that after using AMD for many years I may be mistaken, but shouldn't CPU FSB be 100MHz? Another thing that jumps to my eyes is that my RAM is reported as DDR4-9907. Umm... I wish!
CPU-Z reports Bus Speed a tad less than 100MHz.
Like I said, although I haven't seen anyone report similar irregularities, I don't believe I am the only one out...there? What's going on? Is my PC possessed? :-P
BR,
Mark
  • Solution
14 minutes ago, Marcoolio said:
Hi there folks!
BR,
Mark
In case it still doesn't work properly, then disable Hyper-V and Memory Integrity in Windows Settings to remove the sandboxing of AIDA64.
Just now, Marcoolio said:
Thanks a lot!
Beta version reports CPU FSB and RAM speed correctly. I'm a happy camper now.
Cheers!
Thank you for your feedback!
  • Thanks 1
  • Fiery changed the title to fixed: AIDA64 Extreme and CPU FSB 275MHz (ASRrock H670M-ITX/ax + i5-12600)
