Hey all,
This is my first post here, what an awesome forum and this program rocks !
I am having a little trouble setting up my smpt settings for gmail.
Under preferances i have selected SMTP
Displayname user
e-mail User@gmail.com
Server: smtp.gmail.com
SMPT Port:587
User SMPT Authentication
User@gmail.com
PasswordI
I get this error when i press test
Alter Message cannot be sent
5.7.9 Must Issue a Starttls command first pk9sm11256925pbb.4
Are you using AIDA64 v2.60? Previous versions didn't support Gmail SMTP.
Also make sure to double-check if there's a typo or needless space character in the server address. AIDA64 will only use STARTTLS command if the server name equals to smtp.gmail.com
If everything is fine, then please try to enter your username and password again.
  • 11 months later...
