Posted (edited)
G'day all,
Just swapped from an Asus Extreme z690 to the Classified z690 and noticed that Aida's not picking up any of my fans headers.  As a result, I can't display fan or pump RPMs in my sensor panel as normal.  Realize the EVGA boards aren't the most common, but has anybody else experienced this?
Thanks!
EC Dump.txt ISA Sensor Dump.txt
Edited by NeuroMortis
Initially added txt files to reply. Adding them to main post.
3 minutes ago, NeuroMortis said:
G'day all,
Thanks!
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
