Sensor Moderators COSTAJUNIOR Posted May 18, 2022 Sensor Moderators Posted May 18, 2022 Hello, I would like to know if there is a way to add a sensor to measure the voltage and voltage of my power supply. I'm using the current version of AIDA64 but nothing appears that could help me. Quote
Fiery Posted May 19, 2022 Posted May 19, 2022 7 hours ago, COSTAJUNIOR said: Hello, I would like to know if there is a way to add a sensor to measure the voltage and voltage of my power supply. I'm using the current version of AIDA64 but nothing appears that could help me. If you mean the input voltage and power draw of the power supply unit, then most PSU's aren't capable of measuring such rails. What PSU do you have? Quote
Sensor Moderators COSTAJUNIOR Posted May 19, 2022 Author Sensor Moderators Posted May 19, 2022 11 hours ago, Fiery said: Se você quer dizer a tensão de entrada e o consumo de energia da fonte de alimentação, a maioria das PSUs não é capaz de medir esses trilhos. Qual PSU você tem? My power supply is an EVGA Supernova G+ 1300w Quote
