Is there some way to find what fonts were used for a sensor panel someone made?  Or is there a font pack that has some of the common ones used here?  I spend more time just trying to find fonts that match what they used after I import it and they just load to default.
We do not offer font packs.  If you download the .sensorpanel file that someone else made and open it in Notepad (or any other text viewer/editor), you can see what fonts are used there.
  • 1 year later...
  • 3 weeks later...
