Neostarchild Posted October 9, 2012 Posted October 9, 2012 Hi, I'm new to the forums here and I like what I see so far. I've been using Everest and now AIDA64 for a while but I'm running into probably a simple fix for a sensor panel problem I've been having. I've searched through the forums but I didn't see a possible fix and I see in the screenshots of other peoples work my issue is not there. I have the annoying magenta Right-Click on the panel to add or edit SensorPanel items and I don't know how I remove it. I hope its a simple fix. thanks Quote
Fiery Posted October 9, 2012 Posted October 9, 2012 Right-click on the magenta text to delete it Same goes for any SensorPanel items: you need to use the right-click context menu to remove, edit or move an item. Quote
Neostarchild Posted October 9, 2012 Author Posted October 9, 2012 I knew it had to be simple .. but never thought of that .. thanks for the help and fast response Quote
