DocCruncher Posted December 7, 2014 Share Posted December 7, 2014 I want to turn the Sensor Panel on/off with one of my mouse buttons. It needs to be a cycle-able option so the same button can either turn it on or off. I see no option for this feature; is it doable? Doc Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 8, 2014 Share Posted December 8, 2014 Hot keys are not supported by AIDA64 at all. We may implement that sometime in the future, but it's not on our short-term roadmap right now. Regards, Fiery Quote Link to comment Share on other sites More sharing options...
DocCruncher Posted December 8, 2014 Author Share Posted December 8, 2014 Bummer. I was using a Logitech G19 gaming keyboard with four LCD screens customized to my needs but due to the long-term unreliability of the Logitech Gaming software (often times it simply would not load at Windows start up) I switched to the Sensor Panel. After combining all four G19 screens into one Sensor Panel window the new panel takes up too much screen to keep it loaded at all times so I need to be able to quickly turn it on/off and was really hoping to do it with a keystroke combination that I can add to a mouse button. This will be a really nice feature for the Sensor Panel. I hope it does not take too long to implement. Thanks; Doc Quote Link to comment Share on other sites More sharing options...
DocCruncher Posted December 22, 2014 Author Share Posted December 22, 2014 Was wondering if this can be accomplished in another way without HotKeys. Right clicking on the Sensor Panel itself there is a "Hide Sensor Panel" command & right clicking on the AIDA64 icon in the Task Try there is a "Show Sensor Panel" command. Are there any command line switches for these? If so, I can put them in a BAT file and assign a shortcut to them for my mouse. Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 22, 2014 Share Posted December 22, 2014 Was wondering if this can be accomplished in another way without HotKeys. Right clicking on the Sensor Panel itself there is a "Hide Sensor Panel" command & right clicking on the AIDA64 icon in the Task Try there is a "Show Sensor Panel" command. Are there any command line switches for these? If so, I can put them in a BAT file and assign a shortcut to them for my mouse. I'm afraid command-line arguments will not work when AIDA64 is already running Quote Link to comment Share on other sites More sharing options...
DocCruncher Posted December 22, 2014 Author Share Posted December 22, 2014 Good try, I guess. Thanks for the feedback. Hope this gets resolved in a future version. Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 15, 2016 Share Posted September 15, 2016 We've implemented the requested Hot Keys feature in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta You can configure it in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Hot Keys. Quote Link to comment Share on other sites More sharing options...
