Slipknot79 Posted July 17, 2022 Posted July 17, 2022 Yea, the DIMM temperature sensor has worked for a while, but from one day to the other, it has stopped working. Of course its actived in stability-section: But theres no value: Any idea what could be wrong and how to solve it? Quote
Fiery Posted July 17, 2022 Posted July 17, 2022 6 hours ago, Slipknot79 said: Yea, the DIMM temperature sensor has worked for while, but from one day to the other, it has stopped working. Of course its actived in stability-section: But theres no value: Any idea what could be wrong and how to solve it? Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
Slipknot79 Posted July 17, 2022 Author Posted July 17, 2022 ------[ Versions ]------ Program Version : AIDA64 Extreme v6.70.6000 BenchDLL Version: 4.5.868.8-x64 Windows Version : Microsoft Windows 11 Pro 10.0.22000.795 (64-bit) GetProductInfo : 0x00000030 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus ROG Strix Z390-H Gaming Motherboard Chipset : Intel Cannon Point Z390, Intel Coffee Lake-S DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ROG STRIX Z390-H GAMING DMI MB Version : Rev X.0x DMI MB Serial : 181039221702282 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 3006 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : ACPI SMBus Port : EFA0 Can Have SPD: Yes Scan Type : Full *** SMBus Semaphore Disabled = 0 Dump took 0.4 sec Quote
Mr. Fox Posted November 15, 2022 Posted November 15, 2022 I have this same problem now and DIMM thermal sensor support is enabled. Until a recent update, launching HWiNFO64 would somehow allow AIDA64 to display DIMM temperatures. Closing HWiNFO64 would cause the sensors to disappear again in AIDA64, but now that does not work. I care because I show that in my Sensor Panel and now it is broken. The problem is present on both of my desktops exactly the same. Both are DDR5 systems. One is ASUS and the other EVGA. The issue only affects AIDA64. It does not affect HWiNFO64, but the temperature sensor readings randomly disappear and reappear in HWiNFO64. It affects Extreme and Engineer, but the problem was noted first in Engineer version. I stopped using it for that reason, then the problem surfaced in AIDA64 Extreme after an update. On 11/17/2020 at 2:23 AM, Fiery said: Make sure to disable (uncheck) the option called SMBus access through ACPI (Asus motherboards) in AIDA64 / main menu / File / Preferences / Stability, and on the same page enable (check) the option called DIMM thermal sensor support. Let me know if it helps. This did not work for me on my ASUS Z690-E motherboard. It did on my EVGA Z690 Dark. DIMM temperature and DIMM voltage are both missing on the ASUS motherboard. ------[ Versions ]------ Program Version : AIDA64 Extreme v6.80.6210 Beta BenchDLL Version: 4.6.873.8-x64 Windows Version : Microsoft Windows 11 Enterprise 10.0.22000.856 (64-bit) GetProductInfo : 0x00000004 ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-122418-Chipset$0AAAA000_BIOS DATE: 09/30/22 14:16:17 VER: 05.0001 Motherboard Model : Asus ROG Strix Z690-E Gaming WiFi Motherboard Chipset : Intel Alder Point-S Z690, Intel Alder Lake-S DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ROG STRIX Z690-E GAMING WIFI DMI MB Version : Rev 1.xx DMI MB Serial : 211296007000340 DMI SYS Manufacturer: ASUS DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2103 ------[ PCI Devices ]------ B00-D00-F00 [8086-4660] [1043-8694] [CC0600]: Intel Alder Lake-S 8+8 - Host Controller ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : EFA0 Can Have SPD: Yes DDR5 : Yes Scan Type : Full *** SMBus Semaphore Disabled = 0 Dump took 62.0 sec I have tried unchecking other sensors as well, to no avail. The sensors used to be present and displayed in my Sensor Panel, but now DIMM voltage and DIMM temperature are both missing. Quote
Fiery Posted November 20, 2022 Posted November 20, 2022 On 8/6/2022 at 9:24 PM, Slipknot79 said: Any solution on this? Oo Make sure to disable (uncheck) the option called SMBus access through ACPI (Asus motherboards) in AIDA64 / main menu / File / Preferences / Stability, and on the same page enable (check) the option called DIMM thermal sensor support. Let me know if it helps. 1 Quote
Slipknot79 Posted November 20, 2022 Author Posted November 20, 2022 Yes, thank you. Your solution is working. Needed SMBus access through ACPI (Asus motherboards) setting to be unchecked. Quote
