jalong Posted October 30, 2012 Posted October 30, 2012 Recently installed Win 8 pro upgrade along with AIDA64 v2.60. Also tried AIDA64 v.2.70.2200. AIDA detects network transfers on all enabled adaptors in the NETWORK/WINDOWS NETWORK section of the main window but neither the OSD or LCD panel are updated with the information. MB = Asus P8Z77-V Deluxe Thanks! Quote
jalong Posted October 30, 2012 Author Posted October 30, 2012 I see that it works for you. Here's what it shows me. Note the "0.0 KB/s" on both network interfaces. Quote
Fiery Posted October 30, 2012 Posted October 30, 2012 Are you sure you have only 2 network interfaces? In several systems, even with just one physical NIC in use, there are multiple network interfaces due to e.g. not utilized network ports, not utilized Bluetooth LAN interface, unconnected WLAN controller, etc. If it's possible, please create a TXT report of the Network / Windows Network page of AIDA64, and copy-paste it into this topic, so we can check how many network controllers does your computer have. Thanks, Fiery Quote
jalong Posted October 30, 2012 Author Posted October 30, 2012 I have multiple network interfaces. I was referring to the two shown in the screenshot in my previous post above, NIC1 and NIC2. See attachment. Quote
Fiery Posted October 30, 2012 Posted October 30, 2012 NIC1 and NIC2 may not be the adapters that are connected and driving a network traffic. Try to add NIC3, NIC4 and NIC5 as well to your OSD, to see which one belongs to which adapter exactly. Quote
