17 hours ago, Magnus Back said:
When I enable Corsair HXi/RMi sensor support it freezes the sensor panel after a few seconds.
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Sensor Profiling Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
  • 3 weeks later...
  • 1 year later...
Why AIDA shows 2 different temp.sensors from PSU Corsair RM850i? iCUE shows only one.
usbpsudump.txt
And AIDA shows FAN speed of this PSU in RPM, can you do it in %? I can`t set right corrections, cos max. = 1500rpm, but 50% = 900rpm.
