B550 Taichi/Adia64 Temp Sensor etc. not working
New build
clean install windows 10 pro 22H2 19045.2486
Chipset Driver 4.11.15.342 Installed
Aida64 extreme (paid ver) 6.85.6300 BD 12/12/2022
Aida installed/tested before any other after market software except drivers
Driver Order of install
  • chipset/
  • LAN/
  • WLAN/
  • bluetooth/
  • Audio/
  • No other ASRock software installed.
  • no other monitoring software installed
ISSUES
  • CPU temp sensor reports static 0c
  • Motherboard temp sensor reports static 1c
  • No SOC temp sensor available
  • CPU VDDNB & CPU VDD intermittently reports 0.00 voltage
Non Issues
  • CPU diode seems to be working properly
  • DIMM temps were revealed after a Stability entry was initialized "DIMM thermal sensor support"
What I have tried.
  • I have attempted to initialize all other available Stability entries with no success.
  • Uninstalled Aida64 and reinstalled as admin
  • Reinstalled Chipset drivers
  • Set Aida64 exe to run as administrator
  • multiple restarts OS and Aida app after each change.
System Specs
Mobo: ASRock B550 Taichi P2.20 (bios)
CPU: AMD Ryzen 9 3900X
Mem: G.Skill Trident Royal-Z 3600 C16 (4x8)
GPU: EVGA GeForce RTX 2080 Ti XC Hydro Copper 11GB
OS Drive: WD Black SN850 2TB PCIe 4.0 M.2
PSU: Corsair HX850W PSU
14 hours ago, owcraftsman said:
New build
  • chipset/
  • LAN/
  • WLAN/
  • bluetooth/
  • Audio/
ISSUES
Non Issues
What I have tried.
System Specs
------[ Versions ]------
Program Version : AIDA64 Extreme v6.85.6300
BenchDLL Version: 4.6.875.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19045.2486 (64-bit)
GetProductInfo  : 0x00000030
Motherboard ID      : <DMI>
Motherboard Model   : ASRock B550 Taichi
Motherboard Chipset : AMD B550, AMD K17.7 FCH, AMD K17.7 IMC
DMI MB Manufacturer : ASRock
DMI MB Product      : B550 Taichi
DMI MB Version      :
DMI MB Serial       : HQ0200930101697
DMI SYS Manufacturer: To Be Filled By O.E.M.
DMI SYS Product     : B550 Taichi
DMI SYS Version     : To Be Filled By O.E.M.
DMI SYS Serial      : To Be Filled By O.E.M.
DMI BIOS Version    : P2.20
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h     (    0000h /     0000h)
ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h)
ITE SuperIO Device ID      = 0000h     (    0000h /     0000h)
ITE SuperIO Version        = 00h       (      00h /       00h)
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0290h (0290h / 0A20h)
Winbond SuperIO Device ID         = D42Ah (D42Ah / C732h)
Winbond Sensor ID A3/5C/reg$58    = A3 / 5C / C1
Fintek SuperIO Port           = 00h
Fintek SuperIO Device ID      = 0000h (0000h / 0000h)
SMSC SuperIO Port           = 00h
SMSC SuperIO Device ID      = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #0 ]------
0000  C7 32 1C 00  00 00 00 03  FF 00 E4 87  01 00 01 F8
0010  3F E6 2F 00  00 00 FF FF  FF FF FE FF  FF FF FF FF
0020  FF FF 00 00  FF FF 01 40  FF FF FF FF  FF FF FF FF
0030  C3 01 00 04  00 00 B0 00  00 44 0E 03  1E 00 00 00
0040  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0050  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0080  DC EB F5 FE  05 0C 12 19  20 27 2F 39  45 55 73 A7
0090  FF 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  B0 F0 A0 90  70 70 60 70  70 70 80 A0  C0 00 E0 48
00B0  40 00 00 17  00 00 00 00  00 00 00 00  00 00 00 00
00C0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #1 ]------
0000  1D 80 1C 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0040  02 D7 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  4C 99 99 99  99 99 99 00  00 00 79 00  00 A4 00 E9
0070  04 00 00 00  00 00 00 00  00 00 00 00  7E 00 00 7F
0080  80 0A 08 20  00 05 0A 05  2F 02 02 0A  00 00 7A FF
0090  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  08 46 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00B0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00C0  B4 A7 AE B0  B2 B6 A5 20  20 20 20 20  20 20 20 20
00D0  B5 A8 AF B1  B3 B7 A6 20  03 03 03 03  03 03 03 03
00E0  06 40 06 40  06 40 06 40  06 40 06 40  06 40 06 40
00F0  80 80 80 80  80 80 80 80  00 03 40 05  20 00 09 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #2 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0030  00 00 00 00  00 00 00 00  02 00 00 00  00 00 00 B0
0040  02 02 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0080  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00E0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  00 00 00 02  80 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #3 ]------
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 01 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #4 ]------
0010  A3 96 40 00  33 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #5 ]------
0060  41 01 07 07  05 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #6 ]------
0000  C7 31 00 00  14 05 05 00  01 00 00 00  12 05 1C 00
0010  C7 31 FF FF  12 05 1E 00  00 00 00 00  00 00 00 00
0020  BD 03 00 28  8B 00 00 00  00 00 00 00  00 00 00 00
0030  00 01 00 00  00 00 00 00  46 10 00 00  00 00 00 00
0040  50 00 46 10  00 00 00 00  00 00 00 00  00 00 00 00
0050  A7 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 01 00 00  50 00 02 00  00 00 00 00  00 00 00 01
00B0  50 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  12 05 1C 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #7 ]------
0010  40 00 00 00  00 00 80 00  00 00 00 C0  00 00 00 00
0020  00 00 00 00  00 00 00 00  80 20 09 01  01 00 00 00
0040  07 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  08 08 00 00  00 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #8 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #9 ]------
0000  80 80 80 80  80 80 80 00  00 00 00 00  00 00 00 00
0010  00 00 00 02  00 00 00 01  00 00 00 02  00 00 00 01
0020  00 00 00 01  00 00 00 01  00 00 00 01  00 00 00 00
00D0  03 03 03 03  03 03 03 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #10 ]------
0000  80 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 00 00  00 00 00 00  80 80 80 80  80 80 80 80
0040  00 00 00 00  00 00 00 00  03 E8 07 D0  1E 1E 1E 22
0050  3C 44 44 44  03 02 02 3C  02 00 00 00  00 00 00 00
0080  01 00 00 00  0A 00 00 00  02 00 00 00  A0 00 00 00
0090  04 00 00 00  00 0A 00 00  08 00 00 00  00 A0 00 00
00A0  10 00 00 00  00 00 0A 00  20 00 00 00  00 00 A0 00
00B0  40 00 00 00  00 00 00 0A  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #11 ]------
0000  28 37 46 50  50 50 50 00  4C 00 66 00  B2 00 FF 00
0010  FF 00 FF 00  FF 00 00 00  28 32 41 50  50 50 50 00
0020  99 00 B2 00  CC 00 FF 00  FF 00 FF 00  FF 00 00 00
0030  28 32 41 50  50 50 50 00  99 00 B2 00  CC 00 FF 00
0040  FF 00 FF 00  FF 00 00 00  28 32 41 50  50 50 50 00
0050  99 00 B2 00  CC 00 FF 00  FF 00 FF 00  FF 00 00 00
0060  28 32 41 50  50 50 50 00  99 00 B2 00  CC 00 FF 00
0070  FF 00 FF 00  FF 00 00 00  28 32 41 50  50 50 50 00
0080  99 00 B2 00  CC 00 FF 00  FF 00 FF 00  FF 00 00 00
0090  28 32 41 50  50 50 50 00  99 00 B2 00  CC 00 FF 00
00A0  FF 00 FF 00  FF 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #12 ]------
0080  00 4C 00 99  00 99 00 99  00 99 00 99  00 99 00 00
00A0  1D 1D 1D 1D  1D 1D 1D 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  60 00 00 00  FF 80 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #13 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #14 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #15 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #16 ]------
   0100  0102  0104  0106  0108
T:   29    29     0     0     0
T:   29    29     0     0     0
T:   29    29     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    29     0     0     0
T:   29    29     0     0     0
T:   29    29     0     0     0
T:   29    29     0     0     0
T:   29    29     0     0     0
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #0 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #1 ]------
0000  1D 80 1D 00  00 00 00 00  00 00 00 00  00 00 00 00
0040  02 D8 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  4C 99 99 99  99 99 99 00  00 00 B4 00  00 BE 00 2E
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #2 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #3 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #4 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #5 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #6 ]------
0020  C4 03 00 28  8B 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #7 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #8 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #9 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #10 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #11 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #12 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #13 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #14 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #15 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #16 ]------
T:   29    29     0     0     0
T:   29    29     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
T:   29    30     0     0     0
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------
0000  03 4D 03 4D  00 FF FF FF  FF FF FF FF  FF FF FF FF
0010  03 4D 03 4D  03 4D 03 4D  40 FF FF FF  FF FF FF FF
0020  FF FF FF FF  FF FF FF 1D  03 4D FF DA  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 50 4B FF  FF FF FF FF
0040  03 00 00 FF  FF 00 3F FF  2D FF FF 10  08 55 00 A3
0050  15 FF FF FF  FF FF FF FF  C1 FF FF FF  FF 00 00 01
0060  0C 0C FF FF  FF 01 00 FF  FF FF FF FF  FF FF FF FF
0070  00 0A 00 1D  80 1A 80 08  00 08 00 08  00 08 00 FF
0080  FF FF FF FF  FF 05 05 05  00 00 00 00  00 00 00 00
0090  0A 00 00 00  00 FD FD FD  0A 95 EF 80  FF 40 46 C4
00A0  0E FF 00 00  FF 00 00 FF  00 00 80 66  06 06 00 00
00B0  00 00 00 00  00 00 28 00  04 10 00 34  28 FF 04 00
00C0  FF FF FF FF  FF FF FF FF  FF 19 07 05  FF FF FF FF
00D0  05 05 05 05  00 00 00 00  00 00 00 00  FD FD FD FD
00E0  55 80 00 00  00 FF FF FF  FF FF 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 FF  1C 51 28 25  33 FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------
0000  01 00 00 0A  0A 01 01 3C  00 4D FF 00  00 FF FF FF
0010  FF 19 23 2D  37 FF FF 8C  AA C8 E6 32  00 01 01 00
0020  FF 19 23 2D  37 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 7F 01 FF  00 FF FF FF  FF FF FF 00
0040  FF FF FF FF  FF 00 00 FF  FF FF FF FF  FF FF 00 FF
0050  1A 80 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF 11 00  00 4D FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------
0000  02 32 02 0A  0A 01 01 3C  00 4D 00 00  00 FF FF FF
0010  FF 28 32 3C  46 FF FF 8C  AA C8 E6 3C  00 02 02 00
0020  FF 28 32 3C  46 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 7F 01 FF  00 01 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------
0000  03 00 00 0A  0A 01 01 3C  00 4D FF 00  00 FF FF FF
0010  FF 19 23 2D  37 FF FF 8C  AA C8 E6 3C  00 03 03 00
0030  FF 00 FF FF  00 64 01 FF  00 FF FF FF  FF FF FF 00
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF 00 00 FF  FF FF FF FF
0020  FF FF FF 96  64 96 64 E1  96 00 FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF 20 03 14  FF 00 FF FF  FF FF 00 00  00 00 00 FF
0050  01 FB FF FF  00 00 00 FF  FF 0E 13 31  09 00 FF FF
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  CE 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  44 D2 D7 CE  E8 89 A9 D7  00 72 80 4F  87 72 72 76
0090  1D 1A 08 C4  0C 1F 14 28  80 1D 1A 08  08 08 03 08
00A0  08 1D FF FF  FF FF 00 00  00 00 00 00  00 00 00 00
00B0  FF 1F FF 1F  FF 1F FF 1F  FF 1F FF 1F  00 00 00 00
00C0  00 00 00 00  00 00 00 00  00 00 00 00  FF 1F 00 00
00D0  00 00 00 00  00 00 FF FF  FF FF FF FF  FF FF FF FF
00E0  4D 4D 4D 4D  4D 4D 4D FF  FF FF FF FF  FF FF FF FF
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------
0000  FF FF 00 FF  FF FF 00 FF  21 FF FF FF  FF 00 00 FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  D7 00 00 FF  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 FF FF  FF FF FF FF  FF FF FF FF
0070  00 00 00 00  00 FF 01 FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------
0000  00 00 00 00  00 00 00 FF  FF FF FF FF  FF FF FF FF
0010  00 00 00 00  00 00 00 FF  1F FF FF FF  FF FF FF FF
0020  FF 01 02 00  00 FF FF FF  FF FF FF FF  FF FF FF 1F
0030  FF 1F FF 1F  FF 1F FF 1F  FF 1F FF 1F  FF 1F FF 1F
0040  FF 1F FF 1F  02 02 02 02  02 02 FF 1F  FF 1F 00 02
0050  7F 7F 7F 7F  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  08 00 C4 80  0C 80 1F 00  14 80 1A 80  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------
0000  FF 00 02 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 F8  80 F8 80 F8  80 F8 80 00
0020  28 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 0E  0A 00 00 00
   0027 0150 0250 007D 007E 0490 0491 0492 0493 0494 0495 062B 062C 062D 071C 0720
T:   29   26  255    8    0   29   26    8  196   12   31  255  255  255  128   40
   0020 0021 0022 0023 0024 0025 0026 0480 0481 0482 0483 0484 0485 0486 0487 0488 0489 048A 048B 048C 048D 048E 048F
V:  FF   FF   FF   FF   FF   FF   FF   44   D2   D7   CE   E8   89   A9   D7   00   72   80   4F   87   72   72   76
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/K17.7/K18/K19.2/K19.4/K19.5/K21 PM2 at 0CD0 ]------
0000  05 04 01 00  00 00 00 00  00 00 00 00  00 00 00 00
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0050  00 00 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF 00 00  00 00 00 00
0090  00 00 00 00  00 FF FF FF  FF FF FF FF  FF FF FF FF
00B0  00 FF 00 00  FF 00 00 FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF 00 FF 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  01 00 00 02
00F0  19 0A 02 05  C8 20 80 00  04 06 00 00  08 08 00 02
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/K17.7/K18/K19.2/K19.4/K19.5/K21 PM at 0CD6 ]------
0000  77 0B 07 E3  02 04 01 00  14 05 1C 02  06 21 43 55
0010  74 00 50 01  16 00 20 00  42 86 64 A8  40 00 3C 00
0020  20 01 9C 01  A0 00 E0 00  55 00 10 00  80 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 08 01 00
0040  FF FF FF 00  00 00 00 88  21 2B 35 59  00 00 3F 49
0050  00 00 3E 3F  90 00 00 14  01 FF 15 44  00 06 00 00
0060  00 08 04 08  08 08 10 08  20 08 B2 00  FF FF BA 00
0070  01 0B 00 00  17 01 06 19  FF FF 00 00  FF FF E0 80
0080  00 00 26 00  00 00 00 00  00 00 00 00  9E 00 80 00
0090  02 05 02 0B  01 00 10 00  00 10 00 01  00 00 00 00
00A0  00 00 00 00  00 00 00 00  F8 CE FF 00  00 00 00 00
00B0  00 20 84 02  00 00 80 05  88 00 28 00  02 00 52 C0
00C0  00 08 00 00  28 00 00 00  0C 40 28 00  DB B6 6D DB
00D0  00 F4 40 BF  00 00 00 00  00 00 11 00  00 00 00 00
00E0  D8 0C 00 00  00 00 01 00  04 00 00 01  15 14 08 7F
00F0  9C 73 00 00  00 00 00 00  3F 00 F0 FE  00 00 00 00
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
Thank you!  We will fix the issue about motherboard and CPU temperature reporting in the next AIDA64 beta update.
I cannot see SoC temperature measured by your motherboard.
CPU VDD and CPU VDDNB voltages drop to zero when the CPU goes into power-saving (sleep) mode.
Wish you hadn't said that. The motherboard most certainly does report SOC voltage, currents and temperature and I count 12 other things that CPUID HWMonitor gets and Aida64 does not. I've been using and paying for Aida64 Extreme for 15 plus years so I'm no fan boy of the other guy but it appears you are dropping the ball here. Do I need to move on or can we figure this out?
You were talking about SoC temperature, that's what I was responding to.
I had a GPU go bad and had to replace it so this is the first chance I had to try the beta.
Seems to work although it seems like there is way more available not realized with Aida64. Can I add my key to the beta? I assume that is why some sensors show [Trial Version].
