Fiery Posted April 2, 2017 Posted April 2, 2017 On 2017. 03. 28. at 9:44 AM, jay228 said: I have installed these programs. but I have not found how to use them in AIDA . Tell me how ? Once you enable Fraps or RTSS to measure the FPS, a new item for either of them would appear in the list of sensor items in AIDA64. Just enable the new item, and you're good to go. Quote
jay228 Posted April 3, 2017 Posted April 3, 2017 On 02.04.2017 at 11:44 AM, Fiery said: Once you enable Fraps or RTSS to measure the FPS, a new item for either of them would appear in the list of sensor items in AIDA64. Just enable the new item, and you're good to go. thank you turned. there is still a question. but if it uses two parallel graphics application (one behind ,minimized) . fps what the app displays? Quote
Fiery Posted April 3, 2017 Posted April 3, 2017 2 hours ago, jay228 said: thank you turned. there is still a question. but if it uses two parallel graphics application (one behind ,minimized) . fps what the app displays? It displays the FPS provided by Fraps or RTSS, simple as that. You need to make sure those software measure the value you want to be displayed via AIDA64 Quote
jay228 Posted February 27, 2019 Posted February 27, 2019 Hi. I want create simple info program. It is required to output data from another program. can you suggest that at least it is necessary to study in order to implement it ? Quote
Fiery Posted February 28, 2019 Posted February 28, 2019 19 hours ago, jay228 said: Hi. I want create simple info program. It is required to output data from another program. can you suggest that at least it is necessary to study in order to implement it ? I'm not sure what you're trying to achieve. Can you please tell us more about your project? Consider opening a separate topic for your issue. Quote
jay228 Posted March 3, 2019 Posted March 3, 2019 Sorry, I'm using a translator. I want to create a speedometer for one game. and ask. What knowledge of programming languages or programs are needed? Quote
Fiery Posted March 11, 2019 Posted March 11, 2019 On 3/3/2019 at 6:19 PM, jay228 said: Sorry, I'm using a translator. I want to create a speedometer for one game. and ask. What knowledge of programming languages or programs are needed? Try to post that question to StackOverflow. This forum is dedicated to supporting our software AIDA64. Quote
Sensor Moderators COSTAJUNIOR Posted April 25, 2019 Sensor Moderators Posted April 25, 2019 It's working perfectly here. Quote
