Verdi Posted February 26, 2013 Report Share Posted February 26, 2013 Hi, I've purchased the 3 years license. After upgrading my rig and reinstalling my system because of the newest SSD generation I start using Aida64 again. I can remember that earlier versions remembered the last window and so I could start "Computer -> Sensor" with a single click. Now that I've updated I cannot find this feature any more, I need 3 clicks until the "sensor type" temps appear which is really exhausting for my taste. Sensor window is the most used feature for me. For example CPUID HWMonitor needs just a single click. Is there a solution or did I just missed something? 2.) Besides: The boot time of Aida64 is taking longer and longer after new versions. It would be great to have a fast and slim version. Quote Link to comment Share on other sites More sharing options...
stasio Posted February 27, 2013 Report Share Posted February 27, 2013 Click (right) AIDA64 icon in taskbar. Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 27, 2013 Report Share Posted February 27, 2013 1) I think what you need to use is the "Remember last page" option in AIDA64 / main menu / File / Preferences / Layout. 2) The long start time of AIDA64 is related to your chipset and CPU actually. The X79 chipset and the Sandy Bridge-E processor has a lot of PCI devices, and enumerating and identifying all of them takes more time than on a mainstream desktop or notebook system (with e.g. Z77 chipset and Sandy Bridge-DT processor) where there're much less PCI devices. The other component that may slow down the AIDA64 startup is a high number of storage devices, especially when they're in RAID arrays. If you notice AIDA64 taking a lot of time at scanning RAID arrays or SMART details at its startup, then try to update the Intel RSTe drivers to the latest WHQL release, and update AIDA64 to the latest beta release as well: http://www.aida64.com/downloads/aida64extremebuild2327vtb1dhc3yjzip If the scan is still slow, and you have a USB storage device (e.g. a flash drive, external HDD/SSD, card reader) connected, then try to disconnect that device, and see if it makes AIDA64 start up quicker. If you can identify a particular USB device that makes AIDA64 startup slow, let us know the USB hardware ID of the device, and we'll add it to the "blacklisted" USB devices list to exclude it from RAID and SMART scannings. Regards, Fiery Quote Link to comment Share on other sites More sharing options...
Verdi Posted February 27, 2013 Author Report Share Posted February 27, 2013 Thank you so much, Fiery, for the fast reply, that does the trick. There are 4 "remember this, remember that" boxes, this one was unchecked. Now Aida is working like before. Start time is 4 seconds, which is no issue for me. I like the sensor page better than other tools, the overview is fine. The problem with IRST driver is, that unfortunately I own the Corsair 1200AXi which needs the buggy Link Software which gives you BSODs if using the newest IRST driver. So beware of this PSU. I uninstalled IRST completely and strangely - as a spin-off - my new SSD runs at the advertised speeds. Whereas with IRST my SSD was running substantially slower. The right-click on the taskbar icon is a nice shortcut as well. Best regards, Verdi Quote Link to comment Share on other sites More sharing options...
aifor Posted August 4, 2013 Report Share Posted August 4, 2013 I am using the latest stable version and this was the source of my slow loading (it would stall on SMART device scan) and after I remove the drive, AIDA64 starts almost instantly. Unfortunately, after I plug the drive back in, I cannot access it in order to save files from programs like Excel. I have attached a screenshot of the HW Id from Device Manager and it seems to be pretty generic. Is there other information that would help you? If the scan is still slow, and you have a USB storage device (e.g. a flash drive, external HDD/SSD, card reader) connected, then try to disconnect that device, and see if it makes AIDA64 start up quicker. If you can identify a particular USB device that makes AIDA64 startup slow, let us know the USB hardware ID of the device, and we'll add it to the "blacklisted" USB devices list to exclude it from RAID and SMART scannings. Quote Link to comment Share on other sites More sharing options...
Fiery Posted August 5, 2013 Report Share Posted August 5, 2013 We'll add your storage device to the filter list to make sure AIDA64 can get through the SMART scanning. But in order to do that, we need to have the USB device ID for your device. In the Device Properties window please select "Parent" as Property, and send us a new screen shot. It should show the USB device ID in a format of e.g. "USB\VID_xxxx&PID_yyyy". Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
aifor Posted August 31, 2013 Report Share Posted August 31, 2013 Sorry for the delay in responding. Here is the revised screeen shot and please let me know if you need anything else. Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 4, 2013 Report Share Posted September 4, 2013 Thank you, we've added your flash drive to the filter list. Make sure to upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild2590hs6vgtb9xyzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Quote Link to comment Share on other sites More sharing options...
aifor Posted September 11, 2013 Report Share Posted September 11, 2013 That did it. Thanks! Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 11, 2013 Report Share Posted September 11, 2013 Thank you for the feedback Quote Link to comment Share on other sites More sharing options...
P.J Posted September 16, 2013 Report Share Posted September 16, 2013 I would like to see the sensor panel more beautiful and with the native windows style Quote Link to comment Share on other sites More sharing options...
Fiery Posted September 16, 2013 Report Share Posted September 16, 2013 I would like to see the sensor panel more beautiful and with the native windows style There's no style for the SensorPanel. It's fully dynamic, and highly customizable. You can use any design, any graphical elements you want. Quote Link to comment Share on other sites More sharing options...
