The Mac Posted March 18, 2013 Posted March 18, 2013 any chnance to get a monitoring item for this? there must be some quick way to check a DirectX function for it...
Fiery Posted March 19, 2013 Posted March 19, 2013 When you say "render mode", what exactly are you looking for? Screen resolution and bit depth perhaps? Thanks, Fiery
The Mac Posted March 20, 2013 Author Posted March 20, 2013 no like dx9, dx10, dx10.1, dx11, dx11.1, ogl, etc just the dx version in use of the current 3d app. a lot of games have multiple modes, it would be nice to see if you are in the expected mode.
Fiery Posted March 21, 2013 Posted March 21, 2013 Do you know a software that can display that info? I'm not entirely sure it can be detected, at least for Direct3D...
Squall Leonhart Posted March 26, 2013 Posted March 26, 2013 the RT OSD server can detect the currently used directx version.
The Mac Posted May 11, 2013 Author Posted May 11, 2013 Any luck with this? Radeon Pro can display it, and i think Afterburner can as well.
Fiery Posted May 14, 2013 Posted May 14, 2013 We've checked it, and it would require D3D hooking, which is also required for full-screen OSD and FPS measurement BTW. We currently have no plans to deal with D3D hooking I'm afraid
Please sign in to comment
Sign In Now
