GigaGamesGuy Posted October 26, 2023 Posted October 26, 2023 Hello, I'm just wondering, I've read a lot but haven't really found an answer. It's about I have a TV as a monitor, 3840x2160 resolution at 100% scaling, I have an old 10 inch tablet with a resolution of 1280x800 at 100% scaling. If I scale everything to 100% everything is ok, but on the TV I need a scaling of 150%. Unfortunately, Aida64 then goes crazy and moves everything on the tablet. If I restart Aida while it's running, it's ok, only after restarting the PC everything is moved, if I go back to 100% scaling, everything is fine. Is it possible to get a sensor panel that is made for 1280x800 so that it looks right with TV 150% scaling. This is translated here with Google, you can also answer in German. LG Thomas and i search a panel, have contact him and wait. Quote
Shephard Posted October 26, 2023 Posted October 26, 2023 This is not the first time I've tried to explain that when scaling your main monitor, you'll have to resize your fonts on the sensor panel manually. Quote
rinaldop Posted October 27, 2023 Posted October 27, 2023 9 hours ago, Shephard said: This is not the first time I've tried to explain that when scaling your main monitor, you'll have to resize your fonts on the sensor panel manually. Unless I don't understand the problem I never had to do that with fonts. You should be able to adjust the scaling on your main display without it affecting the secondary display. What I do is put my 4K main display to 100% scale and then I start Aida64. I then drag the sensor panel to the secondary display. After that I scale my primary display to 200% but the secondary display is not affected. This trick works great also. It's a Windows compatibility setting that you apply on the EXE itself... Locate AIDA64.EXE (C:\Program Files (x86)\FinalWire\AIDA64 Extreme) 1) Right Click 2) Properties 3) Compatibility Tab 4) 'Change High DPI settings' 5) Check 'Override High DPI Scaling' 6) Scaling performed by: 'System' (from the drop down) 7) Ok/Apply 8) Restart Windows Once you've done this, make sure that your SensorPanel properties are set to match the new panel before importing and you have a better chance of being successful. Quote
Shephard Posted October 27, 2023 Posted October 27, 2023 6 hours ago, rinaldop said: Unless I don't understand the problem I never had to do that with fonts. You should be able to adjust the scaling on your main display without it affecting the secondary display. What I do is put my 4K main display to 100% scale and then I start Aida64. I then drag the sensor panel to the secondary display. After that I scale my primary display to 200% but the secondary display is not affected. This trick works great also. It's a Windows compatibility setting that you apply on the EXE itself... Locate AIDA64.EXE (C:\Program Files (x86)\FinalWire\AIDA64 Extreme) 1) Right Click 2) Properties 3) Compatibility Tab 4) 'Change High DPI settings' 5) Check 'Override High DPI Scaling' 6) Scaling performed by: 'System' (from the drop down) 7) Ok/Apply 8) Restart Windows Once you've done this, make sure that your SensorPanel properties are set to match the new panel before importing and you have a better chance of being successful. in fact, I don’t understand how you do this trick, I have a 65" main monitor, naturally with this screen size I have 200% scaling and no matter how many different sensor options I downloaded, I always had to change the font sizes, because initially they they do it on monitors with a normal 100% scale.. but maybe you’re right, I won’t check your option.. Quote
rinaldop Posted October 29, 2023 Posted October 29, 2023 On 10/27/2023 at 4:18 AM, Shephard said: in fact, I don’t understand how you do this trick, I have a 65" main monitor, naturally with this screen size I have 200% scaling and no matter how many different sensor options I downloaded, I always had to change the font sizes, because initially they they do it on monitors with a normal 100% scale.. but maybe you’re right, I won’t check your option.. I think you meant you will check out my option Let me know if it works for you. But I am confused, are you not displaying the sensor panel on a secondary display? Why do you care how it looks on your 65" main monitor? Quote
Shephard Posted October 29, 2023 Posted October 29, 2023 2 hours ago, rinaldop said: I think you meant you will check out my option Let me know if it works for you. But I am confused, are you not displaying the sensor panel on a secondary display? Why do you care how it looks on your 65" main monitor? I think we shouldn’t continue the discussion about how I work with my monitors in this post, I’ll just say once again that all downloaded panels need to be completed when scaling Quote
rinaldop Posted October 29, 2023 Posted October 29, 2023 30 minutes ago, Shephard said: I think we shouldn’t continue the discussion about how I work with my monitors in this post, I’ll just say once again that all downloaded panels need to be completed when scaling Please don't say that because I think you are giving bad advice and confusing other players. You do NOT need to scale every font, that is a lot of wasted time. If it works for you great, but to other people reading this topic it is NOT needed. Quote
Shephard Posted October 29, 2023 Posted October 29, 2023 1 hour ago, rinaldop said: Пожалуйста, не говорите так, потому что я думаю, что вы даете плохие советы и сбиваете с толку других игроков. Вам НЕ нужно масштабировать каждый шрифт, это пустая трата времени. Если у вас это отлично работает, но другим людям, читающим эту тему, это НЕ нужно. Well, I told you that there is no need to discuss how I do it, why do you stubbornly continue to raise this issue? Or am I writing something unclear? я могу написать вам на своём родном языке, возможно ваш переводчик донесёт вам суть , не нужно в чужой теме обсуждать работу моих мониторов, если вы дали совет, автор поста сам определит какой вариант ему подходит, ваш или мой или чей то ещё, кто возможно предложит третье решение.. Quote
rinaldop Posted October 29, 2023 Posted October 29, 2023 1 hour ago, Shephard said: Well, I told you that there is no need to discuss how I do it, why do you stubbornly continue to raise this issue? Or am I writing something unclear? Because after you said there is no need to discuss how you do it you then said this 3 hours ago, Shephard said: II’ll just say once again that all downloaded panels need to be completed when scaling Which discusses how you do it. If you are done then I am done. edit: I mean no ill will, I am just trying to help and to let people know a way that works for me that I learned here: 1 Quote
GigaGamesGuy Posted October 30, 2023 Author Posted October 30, 2023 On 10/27/2023 at 4:23 AM, rinaldop said: Unless I don't understand the problem I never had to do that with fonts. You should be able to adjust the scaling on your main display without it affecting the secondary display. What I do is put my 4K main display to 100% scale and then I start Aida64. I then drag the sensor panel to the secondary display. After that I scale my primary display to 200% but the secondary display is not affected. This trick works great also. It's a Windows compatibility setting that you apply on the EXE itself... Locate AIDA64.EXE (C:\Program Files (x86)\FinalWire\AIDA64 Extreme) 1) Right Click 2) Properties 3) Compatibility Tab 4) 'Change High DPI settings' 5) Check 'Override High DPI Scaling' 6) Scaling performed by: 'System' (from the drop down) 7) Ok/Apply 8) Restart Windows Once you've done this, make sure that your SensorPanel properties are set to match the new panel before importing and you have a better chance of being successful. Hello, thats was great, i have edit it to compabilty mode new start withh 100% skaling, have start aida and my panel works fine after changing it to 125 % or 150 % 200% for me too big on my 48" oled tv thanks for the description, i think it must be sticke on the top for all newbees that has the same problem. Quote
rinaldop Posted October 30, 2023 Posted October 30, 2023 You are welcome! Yes, you are right, it should be a sticky because this question comes up a lot and there is no official fix from Aida64 but there is an easy way to fix it another way. 1 Quote
FelipeMendonca Posted February 21, 2024 Posted February 21, 2024 On 10/26/2023 at 12:57 PM, GigaGamesGuy said: Hello, I'm just wondering, I've read a lot but haven't really found an answer. It's about I have a TV as a monitor, 3840x2160 resolution at 100% scaling, I have an old 10 inch tablet with a resolution of 1280x800 at 100% scaling. If I scale everything to 100% everything is ok, but on the TV I need a scaling of 150%. Unfortunately, Aida64 then goes crazy and moves everything on the tablet. If I restart Aida while it's running, it's ok, only after restarting the PC everything is moved, if I go back to 100% scaling, everything is fine. Is it possible to get a sensor panel that is made for 1280x800 so that it looks right with TV 150% scaling. This is translated here with Google, you can also answer in German. LG Thomas and i search a panel, have contact him and wait. Quote
maciekish Posted June 16, 2024 Posted June 16, 2024 I made a quick & dirty fix for this to be able to import and use downloaded sensorpanels without modification. Beware its quick & dirty, only works on current version of Windows 11 until they change the layout of the Display Settings. It simply opens Display Settings, sends keystrokes to change the scaling to 100%, launches AIDA64 and changes the scaling back to 150%. You need to change the DPI settings to "Use the DPI that's set for my main display when: I open this program" for this trick to work. https://gist.github.com/maciekish/caed495adfb54146a52b502e46d8041e Quote
rinaldop Posted June 29, 2024 Posted June 29, 2024 On 6/16/2024 at 5:13 PM, maciekish said: I made a quick & dirty fix for this to be able to import and use downloaded sensorpanels without modification. Beware its quick & dirty, only works on current version of Windows 11 until they change the layout of the Display Settings. It simply opens Display Settings, sends keystrokes to change the scaling to 100%, launches AIDA64 and changes the scaling back to 150%. You need to change the DPI settings to "Use the DPI that's set for my main display when: I open this program" for this trick to work. https://gist.github.com/maciekish/caed495adfb54146a52b502e46d8041e Do you just run this as a batch file or how? Quote
