Liux Posted November 7, 2023 Posted November 7, 2023 I am using Asus Rog Crosshair X670E Hero and I have connected a Alphacool Eisfluegel Aurora Flow Indicator "HighFlow" with RPM-Signal using the 3pin cable directly to the motherboard header. Please advise. Quote
Fiery Posted November 8, 2023 Posted November 8, 2023 11 hours ago, Liux said: I am using Asus Rog Crosshair X670E Hero and I have connected a Alphacool Eisfluegel Aurora Flow Indicator "HighFlow" with RPM-Signal using the 3pin cable directly to the motherboard header. Please advise. Try to enable both the following options on the page AIDA64 / main menu / File / Preferences / Stability: Embedded Controller (EC) support Embedded Controller (EC) bank switching Quote
Liux Posted November 8, 2023 Author Posted November 8, 2023 Please see attached picture, those option are enable. Quote
Liux Posted November 10, 2023 Author Posted November 10, 2023 Do you have any other suggestion, because that does not solve the problem. Thanks. Quote
Shephard Posted November 12, 2023 Posted November 12, 2023 can you explain clearly which connector you connected the sensor to, because I see your sensors are all working Quote
