Garfunkel Posted March 29, 2013 Posted March 29, 2013 "Battery Charge Rate" is displayed in negative value. I think it must be "Battery Discharge Rate" (or something much better) when it is on Negative Value (with sign changed to positive) and remains "Battery Charge Rate" when in positive value... Wish I explained it clearly Quote
Fiery Posted March 29, 2013 Posted March 29, 2013 Yes, that's grammatically true. However, AIDA64 uses a fixed label, so based on the current battery status (discharging / charging / neutral) it's not possible to change the sensor reading label. Instead, AIDA64 uses a negative value to indicate discharging, a positive value to indicate charging, and zero value to indicate the neutral state. It's not a perfect solution, but it works Regards, Fiery Quote
Garfunkel Posted March 30, 2013 Author Posted March 30, 2013 AIDA64 uses a fixed label, so based on the current battery status (discharging / charging / neutral) it's not possible to change the sensor reading label. Instead, AIDA64 uses a negative value to indicate discharging, a positive value to indicate charging, and zero value to indicate the neutral state. It's not a perfect solution, but it works Regards, Fiery I got a new idea Why not make a new field that has inverted sign for Battery charge rate value and name it "Battery Discharge rate" Battery charge rate is displayed when Battery Charge rate is positive and battery discharge rate is displayed when Battery charge rate is negative or just hide it and show the battery discharge rate based on "Power management" page in sensor page they have near value sorry for my English Quote
Fiery Posted March 30, 2013 Posted March 30, 2013 Alternating values for the same reading is not really the best idea, since that would make it tough to configure an item on the OSD Panel, Logitech LCD or SensorPanel. Quote
Garfunkel Posted March 30, 2013 Author Posted March 30, 2013 ohhh I gorret... Thanks for support... also I noticed that this value automatically disappears on some mobile PC Quote
