FatBoyNL Posted December 14, 2023 Posted December 14, 2023 (edited) Hi guys, When I open AIDA64 and go to: Computer - Sensor settings, two different CPU readings are shown incorrectly: Current Values: CPU Power Values: CPU Both CPU readings are clearly not showing actual/current values. Every new reading seems to be automatically added to the one before that (for about 5-10 seconds), and then that counting process starts all over from zero (I guess). What I'm seeing is a sequence like this for "Current Values - CPU" (in incremental steps repeating itself after every few seconds): 6.00A - 38.00A - 66.00A - 98.00A - 130.00A - 164.00A - up to about 250.00A, and then same type of additional counting starts all over again starting with a value close 0A and then counting upwards. It's almost the same issue for "Power Values - CPU", but those readings seem to be more random than the example above: Values are fluctuating but going upwards from around 2.00 W up 250+W (while only typing this): so I'm just assuming both values can't be correct. Does anyone know a solution, fix or workaround for this issue? Currently running AIDA64 7.00.6705 beta, but the issue was already present in 6.92 and later beta versions. Thanks in advance, FatBoyNL Recording 2023-12-14 154149.mp4 Edited December 14, 2023 by FatBoyNL Added recording & fixed some typos Quote
FatBoyNL Posted December 20, 2023 Author Posted December 20, 2023 Update: I filed a bug report last week, but didn't get any response yet. Or even a confirmation e-mail. Latest beta shows 'same same but different' results btw Recording 2023-12-20 185007.mp4 Quote
Fiery Posted January 1, 2024 Posted January 1, 2024 On 12/14/2023 at 3:21 PM, FatBoyNL said: Hi guys, When I open AIDA64 and go to: Computer - Sensor settings, two different CPU readings are shown incorrectly: Current Values: CPU Power Values: CPU Both CPU readings are clearly not showing actual/current values. Every new reading seems to be automatically added to the one before that (for about 5-10 seconds), and then that counting process starts all over from zero (I guess). What I'm seeing is a sequence like this for "Current Values - CPU" (in incremental steps repeating itself after every few seconds): 6.00A - 38.00A - 66.00A - 98.00A - 130.00A - 164.00A - up to about 250.00A, and then same type of additional counting starts all over again starting with a value close 0A and then counting upwards. It's almost the same issue for "Power Values - CPU", but those readings seem to be more random than the example above: Values are fluctuating but going upwards from around 2.00 W up 250+W (while only typing this): so I'm just assuming both values can't be correct. Does anyone know a solution, fix or workaround for this issue? Currently running AIDA64 7.00.6705 beta, but the issue was already present in 6.92 and later beta versions. Thanks in advance, FatBoyNL I apologize for the late response. We will remove the bogus CPU current and power readings for Asus AM5 motherboards in the next AIDA64 beta update. 1 Quote
FatBoyNL Posted May 15, 2024 Author Posted May 15, 2024 On 1/1/2024 at 11:23 AM, Fiery said: I apologize for the late response. We will remove the bogus CPU current and power readings for Asus AM5 motherboards in the next AIDA64 beta update. I apologize for this late response as well 😉 Is there any chance that CPU Current and Power readings for AM5 systems will be re-added properly to AIDA64 in the near future? P.S. Please just ignore this post if confirmed that current Intel CPU users are also missing missing out on this mostest important feature 😁 Quote
Fiery Posted May 15, 2024 Posted May 15, 2024 4 hours ago, FatBoyNL said: I apologize for this late response as well 😉 Is there any chance that CPU Current and Power readings for AM5 systems will be re-added properly to AIDA64 in the near future? P.S. Please just ignore this post if confirmed that current Intel CPU users are also missing missing out on this mostest important feature 😁 I think you mean the reading that was specific to previous Asus motherboard generations. We had to remove that on Asus AM5 motherboards because the readings were completely bogus and didn't make any sense. Quote
Squall Leonhart Posted October 19, 2024 Posted October 19, 2024 these bogus readings appear on Intel z690+ too, when EC reading is on. Quote
ShaneC Posted October 24, 2024 Posted October 24, 2024 FWIW, I am seeing similar behavior with the Asus ProArt Z790-Creator WiFi, with an i9 14900K CPU. ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus ProArt Z790-Creator WiFi Motherboard Chipset : Intel Raptor Point-S Z790, Intel Raptor Lake-S DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ProArt Z790-CREATOR WIFI DMI MB Version : Rev 1.xx DMI MB Serial : 240335152700475 DMI SYS Manufacturer: ASUS DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2602 Quote
Fiery Posted October 28, 2024 Posted October 28, 2024 On 10/19/2024 at 1:09 PM, Squall Leonhart said: these bogus readings appear on Intel z690+ too, when EC reading is on. @ShaneC Thank you, we've removed the reading on Asus Intel 600 and 700 chipset series motherboards. Quote
