Hi,
New motherboard, new technical issues :D FUN! I sent an email, but then remembered we get good support via this forum.
CPU temp stuck at 111c! lol, but the CPU package and cores look good. Issue is the CPU fan seems to run based on the CPU temp, it's stuck at 100 percent.
Here's the right click, Sensor Debug, ISA Sensor Dump.
Thank you for helping!
------[ AIDA64 v2.85.2447 Beta ]------
------[ Microsoft Windows 8 Professional with Media Center 6.2.9200.16581 (64-bit) ]------
Motherboard ID      : 63-0100-000001-00101111-122211-Chipset$699122_BIOS DATE: 03/07/13 17:15:14 VER: 04.06.05
Motherboard Model   : EVGA Z77 FTW (E699)
Motherboard Chipset : Intel Panther Point Z77, Intel Ivy Bridge
DMI MB Manufacturer : EVGA INTERNATIONAL CO.,LTD
DMI MB Product      : 151-IB-E699
DMI MB Version      : 1.0
DMI MB Serial       : To be filled by O.E.M.
DMI SYS Manufacturer: EVGA INTERNATIONAL CO.,LTD
DMI SYS Product     : E699 0.0
DMI SYS Version     : 1.0
DMI SYS Serial      : To Be Filled By O.E.M.
DMI BIOS Version    : 4.6.5
ITE 87xx Port           = 00h
ITE 87xx Device ID      = 0000h
ITE 87xx Version        = 00h
Winbond SuperIO Port              = 00h
Winbond SuperIO HWMonitor Port/60 = 0000h
Winbond SuperIO HWMonitor Port/64 = 0000h
Winbond SuperIO Device ID         = 1005h
Fintek SuperIO Port           = 4Eh
Fintek SuperIO HWMonitor Port = 0290h
Fintek SuperIO Device ID      = 1005h
LPC47 SuperIO Device ID      = FFFFh
------[ LM78 ISA Sensor Device at 0290 ]------
0000  FF C3 00 01  01 FF FF 00  00 00 00 00  6F 4C 00 30
0010  00 00 00 00  00 00 06 FF  FF FF FF FF  FF FF FF FF
0020  CD 5E 8C 77  68 69 A3 D0  D0 FF FF FF  FF FA 3F FF
0030  7A D7 FF FF  FF FF C9 C8  75 85 FF FF  FF FF FF 00
0040  44 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF 03 04  10 19 34 FF
0060  00 22 22 00  FF FF 02 00  00 00 FF 0E  40 24 FF 00
0070  FF FF 6F FF  1E FF 22 FF  29 00 28 28  28 00 00 00
0080  FF FF 64 55  64 55 55 46  FF FF FF FF  FF FF A8 FF
0090  00 06 04 00  14 FF 3D FF  44 02 00 15  15 05 99 1A
00A0  02 E3 00 FA  02 DD 3C 32  28 1E FA D3  AD 94 7A 0D
00B0  0F FF 00 3F  03 FF 3C 32  28 1E FF D9  B2 99 80 0E
00C0  0F FF 00 FF  03 FF 3C 32  28 1E FF D9  B2 99 80 0F
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00E0  00 00 00 00  00 00 00 00  00 FF FF FF  00 00 01 00
00F0  00 00 00 00  00 00 33 FF  02 B9 FF 00  FF 00 FF FF
   0070  0072  0074  0076  0078  0079  007A  007B  007C  007D  007E  007F
T:   255   111    30    34    41     0    40    40    40     0     0     0
Reg$20 CPU Core:  r = 205,  r*0.016 = 3.28
Reg$21  CPU Aux:  r =  94,  r*0.016 = 1.50
Reg$22   +3.3 V:  r = 140,  r*0.016 = 2.24
Reg$23     +5 V:  r = 119,  r*0.016 = 1.90
Reg$24    +12 V:  r = 104,  r*0.016 = 1.66
Reg$25    -12 V:  r = 105,  r*0.016 = 1.68
Reg$26     -5 V:  r = 163,  r*0.016 = 2.61
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA>
_TZ_.TZ01._TMP             : <TYPE>0</TYPE><LEN>4</LEN><DATA>3030</DATA>
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
We've checked other E699 logs, and it seems only yours have such issues about CPU temperature readout.  We've also checked our code about E699, to make sure AIDA64 reads the proper register, but it looks fine.  Do you have the same high CPU temperature readings in the BIOS Setup and in EVGA E-LEET?  If yes, then it seems to be either a BIOS issue or a temperature diode malfunction.
Hi Fiery,
In the BIOS I see proper CPU temp, 40c+ fluctuating.
In EVGA E-LEET I see the same 111c temp, stuck, non-fluctuating.
Do you recommend I RMA the mobo?
Thank you.
No, I don't think you should be so drastic ;)  First try to contact EVGA and ask them about the E-LEET CPU temperature reading discrepancy vs. BIOS Setup readings.  If they supply you with a fixed EVGA E-LEET, then the CPU reading may come from the same wrong place in E-LEET and AIDA64, and the BIOS Setup provides the best values.  In such case we'll also fix AIDA64 ;)
They suggested I RMA the board as they thought there was a stuck temperature sensor, but I think it's their BIOS...
I just got the board this past Saturday so will return it to my local store for a replacement.
If the same thing happens I'll have some ammunition to ask for a BIOS fix from EVGA.
I  was hoping the situation would be reversed, you offer some info I could go back to EVGA with :), but it looks like the path of least resistance is a board swap since I'm in my 30 day return period.
Thanks Fiery!
Once in a while my cpu temperature gets stuck too, however shutting down the pc for a few moments completeley unstucks it.
I did some research and found a few posts from people with the same problem and in most cases switching the board or updating bios didnt help, but switching the cpu did...which would indicate that the specific cpu temp sensor which controls fan speed is located directly inside the cpu, not on the motherboard.
LOL, I stand corrected! Just for curiosity sake I powered off and reset CMOS "again"....
CPU sensor UNSTUCK!
I shall now endeavor to bang my head on the desk repeatedly while reciting a DOS manual from 1990.
You probably wouldn´t even need to clear the cmos...if this happens again, try powering the computer off AND power off the psu...wait a minute or so and the sensor should be unstuck.
