Fiery Posted June 5, 2013 Posted June 5, 2013 1) What version of AIDA64 do you have installed? 2) What version of Windows do you have installed? 32-bit or 64-bit? 3) What processor do you have in your PC? Thanks,Fiery Quote
Djuri Posted June 6, 2013 Author Posted June 6, 2013 1) 3.00.2500 2) Windows 7 x64 3) Intel i5-3570k Quote
Fiery Posted June 7, 2013 Posted June 7, 2013 Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild2505xh8pw4vstmzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Thanks, Fiery Quote
Djuri Posted June 8, 2013 Author Posted June 8, 2013 Thanks for help. Now CPUID is starting, but there are lags. Move of the window with CPUID or switch between it and the main AIDA's window takes few seconds, much slower then on my laptop. After fool reinstalling of the AIDA on the first start of the CPU has happened the same error. Second time and later it is starting with lags. Quote
Fiery Posted June 8, 2013 Posted June 8, 2013 Thank you. Then the issue may be related to your motherboard. Please let us know what motherboard do you have, so we can try to reproduce it on a motherboard like that. Quote
Djuri Posted June 9, 2013 Author Posted June 9, 2013 Asus P8Z68-V LX , BIOS was 4003, today I have upgraded it to the last (4102). Also I've tried to disable overclocking, but it doesn't help .Thanks. Quote
Fiery Posted June 11, 2013 Posted June 11, 2013 Asus P8Z68-V LX , BIOS was 4003, today I have upgraded it to the last (4102). Also I've tried to disable overclocking, but it doesn't help .Thanks. Do you have Asus AI Suite installed? Quote
Squall Leonhart Posted June 11, 2013 Posted June 11, 2013 Is it running when you attempt to open Aida64? Quote
Djuri Posted June 11, 2013 Author Posted June 11, 2013 It's starting automatic with Windows because I use fan control.I'll try to disable it. Quote
Djuri Posted June 11, 2013 Author Posted June 11, 2013 I have disabled all Asus services but there is no effect: CPUID is still running with lags. Quote
Fiery Posted June 13, 2013 Posted June 13, 2013 I have disabled all Asus services but there is no effect: CPUID is still running with lags. Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic. Thanks, Fiery Quote
Djuri Posted June 17, 2013 Author Posted June 17, 2013 ------[ Versions ]------Program Version : AIDA64 v3.00.2514 BetaBenchDLL Version: 4.0.568-x64------[ CPU Info ]------CPU Type : QuadCore Intel Core i5-3570K, 3400 MHz (34 x 100)CPU Alias : Ivy Bridge-DTCPU Platform : LGA1155CPU Stepping : E1/L1/N0/P0Instruction Set : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AES, AVXCPUID Manufacturer : GenuineIntelCPUID CPU Name : Intel® Core i5-3570K CPU @ 3.40GHzCPUID Revision : 000306A9hIA Brand ID : 00h (Unknown)Platform ID : 34h (LGA1155)HTT / CMP Units : 0 / 4Tjmax Temperature : 105 CelsiusMax. NUMA Node : 0------[ Logical CPU #0 ]------allcpu: Package 0 / Core 0 / Thread 0: ValidCPUID 00000000: 0000000D-756E6547-6C65746E-49656E69 [GenuineIntel]CPUID 00000001: 000306A9-00100800-7F9AE3BF-BFEBFBFFCPUID 00000002: 76035A01-00F0B0FF-00000000-00CA0000CPUID 00000003: 00000000-00000000-00000000-00000000CPUID 00000004: 1C004121-01C0003F-0000003F-00000000CPUID 00000004: 1C004122-01C0003F-0000003F-00000000CPUID 00000004: 1C004143-01C0003F-000001FF-00000000CPUID 00000004: 1C03C163-02C0003F-00001FFF-00000006CPUID 00000005: 00000040-00000040-00000003-00001120CPUID 00000006: 00000077-00000002-00000009-00000000CPUID 00000007: 00000000-00000281-00000000-00000000CPUID 00000008: 00000000-00000000-00000000-00000000CPUID 00000009: 00000000-00000000-00000000-00000000CPUID 0000000A: 07300803-00000000-00000000-00000603CPUID 0000000B: 00000001-00000001-00000100-00000000CPUID 0000000B: 00000004-00000004-00000201-00000000CPUID 0000000C: 00000000-00000000-00000000-00000000CPUID 0000000D: 00000007-00000340-00000340-00000000CPUID 0000000D: 00000100-00000240-00000000-00000000CPUID 80000000: 80000008-00000000-00000000-00000000CPUID 80000001: 00000000-00000000-00000001-28100000CPUID 80000002: 20202020-49202020-6C65746E-20295228 [ Intel® ]CPUID 80000003: 65726F43-294D5428-2D356920-30373533 [Core i5-3570]CPUID 80000004: 5043204B-20402055-30342E33-007A4847 [K CPU @ 3.40GHz]CPUID 80000005: 00000000-00000000-00000000-00000000CPUID 80000006: 00000000-00000000-01006040-00000000CPUID 80000007: 00000000-00000000-00000000-00000100CPUID 80000008: 00003024-00000000-00000000-00000000L1 Data Cache: 32 KB, 8-way Associative, 64-byte LineL1 Instr. Cache: 32 KB, 8-way Associative, 64-byte LineL2 Unified Cache: 256 KB, 8-way Associative, 64-byte LineL3 Unified Cache: 6144 KB, 12-way Associative, 64-byte Line------[ Logical CPU #1 ]------allcpu: Package 0 / Core 1 / Thread 0: ValidCPUID 00000000: 0000000D-756E6547-6C65746E-49656E69 [GenuineIntel]CPUID 00000001: 000306A9-02100800-7F9AE3BF-BFEBFBFFCPUID 00000002: 76035A01-00F0B0FF-00000000-00CA0000CPUID 00000003: 00000000-00000000-00000000-00000000CPUID 00000004: 1C004121-01C0003F-0000003F-00000000CPUID 00000004: 1C004122-01C0003F-0000003F-00000000CPUID 00000004: 1C004143-01C0003F-000001FF-00000000CPUID 00000004: 1C03C163-02C0003F-00001FFF-00000006CPUID 00000005: 00000040-00000040-00000003-00001120CPUID 00000006: 00000077-00000002-00000009-00000000CPUID 00000007: 00000000-00000281-00000000-00000000CPUID 00000008: 00000000-00000000-00000000-00000000CPUID 00000009: 00000000-00000000-00000000-00000000CPUID 0000000A: 07300803-00000000-00000000-00000603CPUID 0000000B: 00000001-00000001-00000100-00000002CPUID 0000000B: 00000004-00000004-00000201-00000002CPUID 0000000C: 00000000-00000000-00000000-00000000CPUID 0000000D: 00000007-00000340-00000340-00000000CPUID 0000000D: 00000100-00000240-00000000-00000000CPUID 80000000: 80000008-00000000-00000000-00000000CPUID 80000001: 00000000-00000000-00000001-28100000CPUID 80000002: 20202020-49202020-6C65746E-20295228 [ Intel® ]CPUID 80000003: 65726F43-294D5428-2D356920-30373533 [Core i5-3570]CPUID 80000004: 5043204B-20402055-30342E33-007A4847 [K CPU @ 3.40GHz]CPUID 80000005: 00000000-00000000-00000000-00000000CPUID 80000006: 00000000-00000000-01006040-00000000CPUID 80000007: 00000000-00000000-00000000-00000100CPUID 80000008: 00003024-00000000-00000000-00000000L1 Data Cache: 32 KB, 8-way Associative, 64-byte LineL1 Instr. Cache: 32 KB, 8-way Associative, 64-byte LineL2 Unified Cache: 256 KB, 8-way Associative, 64-byte LineL3 Unified Cache: 6144 KB, 12-way Associative, 64-byte Line------[ Logical CPU #2 ]------allcpu: Package 0 / Core 2 / Thread 0: ValidCPUID 00000000: 0000000D-756E6547-6C65746E-49656E69 [GenuineIntel]CPUID 00000001: 000306A9-04100800-7F9AE3BF-BFEBFBFFCPUID 00000002: 76035A01-00F0B0FF-00000000-00CA0000CPUID 00000003: 00000000-00000000-00000000-00000000CPUID 00000004: 1C004121-01C0003F-0000003F-00000000CPUID 00000004: 1C004122-01C0003F-0000003F-00000000CPUID 00000004: 1C004143-01C0003F-000001FF-00000000CPUID 00000004: 1C03C163-02C0003F-00001FFF-00000006CPUID 00000005: 00000040-00000040-00000003-00001120CPUID 00000006: 00000077-00000002-00000009-00000000CPUID 00000007: 00000000-00000281-00000000-00000000CPUID 00000008: 00000000-00000000-00000000-00000000CPUID 00000009: 00000000-00000000-00000000-00000000CPUID 0000000A: 07300803-00000000-00000000-00000603CPUID 0000000B: 00000001-00000001-00000100-00000004CPUID 0000000B: 00000004-00000004-00000201-00000004CPUID 0000000C: 00000000-00000000-00000000-00000000CPUID 0000000D: 00000007-00000340-00000340-00000000CPUID 0000000D: 00000100-00000240-00000000-00000000CPUID 80000000: 80000008-00000000-00000000-00000000CPUID 80000001: 00000000-00000000-00000001-28100000CPUID 80000002: 20202020-49202020-6C65746E-20295228 [ Intel® ]CPUID 80000003: 65726F43-294D5428-2D356920-30373533 [Core i5-3570]CPUID 80000004: 5043204B-20402055-30342E33-007A4847 [K CPU @ 3.40GHz]CPUID 80000005: 00000000-00000000-00000000-00000000CPUID 80000006: 00000000-00000000-01006040-00000000CPUID 80000007: 00000000-00000000-00000000-00000100CPUID 80000008: 00003024-00000000-00000000-00000000L1 Data Cache: 32 KB, 8-way Associative, 64-byte LineL1 Instr. Cache: 32 KB, 8-way Associative, 64-byte LineL2 Unified Cache: 256 KB, 8-way Associative, 64-byte LineL3 Unified Cache: 6144 KB, 12-way Associative, 64-byte Line------[ Logical CPU #3 ]------allcpu: Package 0 / Core 3 / Thread 0: ValidCPUID 00000000: 0000000D-756E6547-6C65746E-49656E69 [GenuineIntel]CPUID 00000001: 000306A9-06100800-7F9AE3BF-BFEBFBFFCPUID 00000002: 76035A01-00F0B0FF-00000000-00CA0000CPUID 00000003: 00000000-00000000-00000000-00000000CPUID 00000004: 1C004121-01C0003F-0000003F-00000000CPUID 00000004: 1C004122-01C0003F-0000003F-00000000CPUID 00000004: 1C004143-01C0003F-000001FF-00000000CPUID 00000004: 1C03C163-02C0003F-00001FFF-00000006CPUID 00000005: 00000040-00000040-00000003-00001120CPUID 00000006: 00000077-00000002-00000009-00000000CPUID 00000007: 00000000-00000281-00000000-00000000CPUID 00000008: 00000000-00000000-00000000-00000000CPUID 00000009: 00000000-00000000-00000000-00000000CPUID 0000000A: 07300803-00000000-00000000-00000603CPUID 0000000B: 00000001-00000001-00000100-00000006CPUID 0000000B: 00000004-00000004-00000201-00000006CPUID 0000000C: 00000000-00000000-00000000-00000000CPUID 0000000D: 00000007-00000340-00000340-00000000CPUID 0000000D: 00000100-00000240-00000000-00000000CPUID 80000000: 80000008-00000000-00000000-00000000CPUID 80000001: 00000000-00000000-00000001-28100000CPUID 80000002: 20202020-49202020-6C65746E-20295228 [ Intel® ]CPUID 80000003: 65726F43-294D5428-2D356920-30373533 [Core i5-3570]CPUID 80000004: 5043204B-20402055-30342E33-007A4847 [K CPU @ 3.40GHz]CPUID 80000005: 00000000-00000000-00000000-00000000CPUID 80000006: 00000000-00000000-01006040-00000000CPUID 80000007: 00000000-00000000-00000000-00000100CPUID 80000008: 00003024-00000000-00000000-00000000L1 Data Cache: 32 KB, 8-way Associative, 64-byte LineL1 Instr. Cache: 32 KB, 8-way Associative, 64-byte LineL2 Unified Cache: 256 KB, 8-way Associative, 64-byte LineL3 Unified Cache: 6144 KB, 12-way Associative, 64-byte Line------[ All CPUs ]------CPU 0: APICID 0 / Package 0 / Core 0 / Thread 0: ValidCPU 1: APICID 2 / Package 0 / Core 1 / Thread 0: ValidCPU 2: APICID 4 / Package 0 / Core 2 / Thread 0: ValidCPU 3: APICID 6 / Package 0 / Core 3 / Thread 0: Valid------[ MSR Registers ]------MSR 00000017: 0004-0000-0000-0000 [PlatID = 1]MSR 0000001B: 0000-0000-FEE0-0900MSR 00000035: 0000-0000-0004-0004MSR 0000008B: 0000-0012-0000-0000MSR 000000CE: 0008-1010-F001-2200MSR 000000E7: 0000-0000-00BC-DACEMSR 000000E8: 0000-0000-00DE-44E9MSR 00000194: 0000-0000-000F-0000MSR 00000198: 0000-22BF-0000-2800MSR 00000199: 0000-0000-0000-FF00MSR 0000019A: 0000-0000-0000-0000MSR 0000019B: 0000-0000-0000-0010MSR 0000019C: 0000-0000-8838-0000MSR 0000019D: 0000-0000-0000-0000MSR 000001A0: 0000-0000-0085-0089MSR 000001A2: 0000-0000-0069-1400MSR 000001A4: 0000-0000-0000-0000MSR 000001AA: 0000-0000-0040-0000MSR 000001AC: < FAILED >MSR 000001AD: 0000-0000-3B3B-3B3BMSR 000001B0: 0000-0000-0000-0000MSR 000001B1: 0000-0000-8838-0000MSR 000001B2: 0000-0000-0000-0000MSR 000001FC: 0000-0000-0014-005FMSR 00000300: < FAILED >MSR 00000480: 00DA-0400-0000-0010MSR 00000481: 0000-007F-0000-0016MSR 00000482: FFF9-FFFE-0401-E172MSR 00000483: 007F-FFFF-0003-6DFFMSR 00000484: 0000-FFFF-0000-11FFMSR 00000485: 0000-0000-1004-01E5MSR 00000486: 0000-0000-8000-0021MSR 00000487: 0000-0000-FFFF-FFFFMSR 00000488: 0000-0000-0000-2000MSR 00000489: 0000-0000-0017-27FFMSR 0000048A: 0000-0000-0000-002AMSR 0000048B: 0000-08FF-0000-0000MSR 0000048C: 0000-0F01-0611-4141MSR 0000048D: 0000-007F-0000-0016MSR 0000048E: FFF9-FFFE-0400-6172MSR 0000048F: 007F-FFFF-0003-6DFBMSR 00000490: 0000-FFFF-0000-11FBMSR 00000601: 1814-1494-8000-1FFFMSR 00000602: 1814-1494-8000-0190MSR 00000603: 0000-0000-802C-2C2CMSR 00000604: 0000-0000-8068-6868MSR 00000606: 0000-0000-000A-1003MSR 0000060A: 0000-0000-0000-883BMSR 0000060B: 0000-0000-0000-8850MSR 0000060C: 0000-0000-0000-8857MSR 0000060D: 0000-06CB-7725-201CMSR 00000610: 8000-87F8-0014-87F8MSR 00000611: 0000-0000-B6B7-4E2FMSR 00000613: < FAILED >MSR 00000614: 0000-0000-01E0-0268MSR 00000618: < FAILED >MSR 00000619: < FAILED >MSR 0000061B: < FAILED >MSR 0000061C: < FAILED >MSR 00000638: 0000-0000-0000-0000MSR 00000639: 0000-0000-D8D9-B219MSR 0000063A: 0000-0000-0000-0000MSR 0000063B: < FAILED >MSR 00000640: 0000-0000-0000-0000MSR 00000641: 0000-0000-0001-2940MSR 00000642: 0000-0000-0000-0008MSR 00000648: 0000-0000-0000-0022MSR 00000649: 01E0-0000-0000-0000MSR 0000064A: 01E0-0000-0000-0000MSR 0000064B: 0000-0000-8000-0000MSR 0000064C: 0000-0000-0000-0000PerformanceFrequency = 3331230CPU Clock M.Method = 8 (APIC SNB)PM Timer Address = 1032 (0408h)APIC Clock = 100.32 MHzAPIC Clock = 100.32 MHzAPIC Clock = 100.32 MHzAPIC Clock = 100.33 MHzAPIC Clock = 100.33 MHz Quote
Fiery Posted June 25, 2013 Posted June 25, 2013 Thank you. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild2522cfs6y7mpqjzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
