Swatgod Posted February 22, 2024 Posted February 22, 2024 After working to improve my original version, i have decided to properly release it here. Features: Select Resolution of the window displayed. Select URL to load panel from. Select the screen to display the app on. Experimental support for shutting off the selected display when primary display is turned off (explained in readme). Settings Menu: Display in use: If you have any questions, feedback or would like to request other features, feel free to contact me. Aida64 Viewer.zip 1 Quote
Loyd Posted March 12, 2024 Posted March 12, 2024 How do I pick which url I can use or can I pick? This is working pretty good Quote
Swatgod Posted March 12, 2024 Author Posted March 12, 2024 Full use of the application is described in the readme. But you right click the window to open a menu with the above options that can be changed. Quote
Loyd Posted March 12, 2024 Posted March 12, 2024 I guess my real question how do I know what URL to put in the selections box? Quote
Swatgod Posted March 12, 2024 Author Posted March 12, 2024 Just now, Loyd said: I guess my real question how do I know what URL to put in the selections box? that is the url set in the remote sensor in the preferences of aida64. you set a url and port and when enabled will tell you if it has been initialized properly, once initialized properly, that means it is available at the selecting url/port. Quote
Swatgod Posted March 12, 2024 Author Posted March 12, 2024 2 minutes ago, Loyd said: I guess my real question how do I know what URL to put in the selections box? if you simply use the remote sensor default settings, than the default url used in the app should work. but if changed, just make sure they match. Quote
Loyd Posted March 12, 2024 Posted March 12, 2024 Just now, Swatgod said: if you simply use the remote sensor default settings, than the default url used in the app should work. but if changed, just make sure they match. Quote
Loyd Posted March 12, 2024 Posted March 12, 2024 yes i understand that, and before you made this nice panel and the changes were made in code I know that. but what if I don't what to use the default and want a different panel than what is in the url. how to I change the panel in the url or find out what url to change to for a different panel Quote
Loyd Posted March 12, 2024 Posted March 12, 2024 i just figured it out the key is aida64 remote sensor like you said, I read it again!! i really like this program, works slick and it is possible to have more than 1 running at the same time. Good Job Quote
Swatgod Posted March 12, 2024 Author Posted March 12, 2024 1 minute ago, Loyd said: yes i understand that, and before you made this nice panel and the changes were made in code I know that. but what if I don't what to use the default and want a different panel than what is in the url. how to I change the panel in the url or find out what url to change to for a different panel in the remote sensor settings you can update the url and the port to use there, which will change the url for your panel. than in my app just right click the screen to load the settings to change the url. if you also mean how to change the panel itself, you can see lcd stuff on the lcd display here in preferences: https://aida64.co.uk/user-manual/file-menu/preferences/hardware-monitoring/lcd. it works the same way as the normal sensor panel editor. Quote
yoshi15 Posted June 26, 2024 Posted June 26, 2024 How do you make it look like that though? Is it the screen itself? When i open it it's a big white box and when i add things it's just plain text info. Forgive my naivete, i'm new to this Quote
Swatgod Posted June 26, 2024 Author Posted June 26, 2024 15 hours ago, yoshi15 said: How do you make it look like that though? Is it the screen itself? When i open it it's a big white box and when i add things it's just plain text info. Forgive my naivete, i'm new to this So what my app displays comes from what you add to the sensor panel, which can be accessed in the aida64 preferences under LCD. You create a template, or download one and import it, and once your template is in place, just make sure its enabled. If you would like my specific template, i have it posted in the big thread, or if you can't find it than i can also post it here as well if needed. Quote
Jon Evans Posted July 5, 2024 Posted July 5, 2024 Hi I have a 480x1920 monitor I currently have plugged into the host device. In the process of moving that to another location and using another PC. Your app is working great. One little niggle I have.. the scroll bars are visible. Any way of hiding these? Quote
Swatgod Posted July 5, 2024 Author Posted July 5, 2024 4 minutes ago, Jon Evans said: Hi I have a 480x1920 monitor I currently have plugged into the host device. In the process of moving that to another location and using another PC. Your app is working great. One little niggle I have.. the scroll bars are visible. Any way of hiding these? if the template is a tiny bit bigger than the monitor resolution, it could cause that to happen when set to the exact monitor resolution. could try to increase the resolution a little bit in each axis and it likely should correct it or at the very least, push the bars off the screen so they are no longer visible. let me know if that does not work. Quote
Jon Evans Posted July 6, 2024 Posted July 6, 2024 10 hours ago, Swatgod said: if the template is a tiny bit bigger than the monitor resolution, it could cause that to happen when set to the exact monitor resolution. could try to increase the resolution a little bit in each axis and it likely should correct it or at the very least, push the bars off the screen so they are no longer visible. let me know if that does not work. Thanks for the reply. Tried making the resolution higher on both axis. Didnt make a difference unfortunately Currently using Chrome in Kiosk mode which works. Would prefer your lighter option though Quote
Swatgod Posted July 6, 2024 Author Posted July 6, 2024 7 hours ago, Jon Evans said: Thanks for the reply. Tried making the resolution higher on both axis. Didnt make a difference unfortunately Currently using Chrome in Kiosk mode which works. Would prefer your lighter option though i will take a look at it and see if i can reproduce the issue on my end, thank you for trying my suggestion. Quote
icy20 Posted February 3, 2025 Posted February 3, 2025 Can I ask something? All the items on the top of the panel displaying all the network stuff do not appear on page1 so we can change the adapter etc. Do you know what is up with that? Quote
Swatgod Posted February 3, 2025 Author Posted February 3, 2025 29 minutes ago, icy20 said: Can I ask something? All the items on the top of the panel displaying all the network stuff do not appear on page1 so we can change the adapter etc. Do you know what is up with that? not sure i follow what it is you are asking about in terms of the app? Quote
icy20 Posted February 3, 2025 Posted February 3, 2025 11 minutes ago, Swatgod said: not sure i follow what it is you are asking about in terms of the app? I dont think it is an app thing. let me show you. Those items. I cannot find them on the LCD item list. So i cannot change the adapter so they work. Also I tried to make an edited copy of the radeon red png with a NVidia logo and for some reason the rslcd bugs out and shows still radeon logo and with duplicate items one on top of each other... Quote
Swatgod Posted February 3, 2025 Author Posted February 3, 2025 1 hour ago, icy20 said: I dont think it is an app thing. let me show you. Those items. I cannot find them on the LCD item list. So i cannot change the adapter so they work. Also I tried to make an edited copy of the radeon red png with a NVidia logo and for some reason the rslcd bugs out and shows still radeon logo and with duplicate items one on top of each other... the top center is hard drive info, networking is bottom center. but as i just now checked, everything shown, is on page 1 and editable just fine, assuming this was my template and not another you found as it looks heavily modified. Quote
Ironjav Posted February 5, 2025 Posted February 5, 2025 Buenas tardes.... Acabo de adquirir un display LCD 1280x400 y el problema es que no encuentro plantillas para esa resolución por ningún lado.... Si alguien tuviera sería tan amable de compartir. Gracias de antemano!!!!! Quote
Swatgod Posted February 5, 2025 Author Posted February 5, 2025 2 minutes ago, Ironjav said: Buenas tardes.... Acabo de adquirir un display LCD 1280x400 y el problema es que no encuentro plantillas para esa resolución por ningún lado.... Si alguien tuviera sería tan amable de compartir. Gracias de antemano!!!!! Sorry but you are in the wrong area for looking for templates, there is a dedicated section of the forum for that. This is just for help related to my application :). Quote
samlevy0515 Posted September 10, 2025 Posted September 10, 2025 I have a question. Sorry if this is a silly question—I'm new to all this. But how do you get it to look that way? Quote
abramesd Posted February 24 Posted February 24 Hello, Thank you for sharing your application. It is working for me and was really easy to get up and running. I am also having an issue with both scroll bars showing. I was able to make them go away by setting the "Viewer resolution" to 1100 X 600. The LCD setting is set to 1024 X 600, and the Monitor is set to 1024 X 600. The 1100 X 600 setting in the app creates a black area to the right of the panel but that gets pushed off the monitor so I can live with that. I am not looking for a fix just wanted to share what I found in case it helps you. David Quote
1 PC Tip a day Posted Tuesday at 10:01 AM Posted Tuesday at 10:01 AM Hi @Swatgod. Thanks for your work. I've recently launched this Watcher: Check it out; maybe you can draw some ideas for your Viewer app too! Quote
