Side Bars Not Showing in System Stability in latest versions
  • Solution
2 hours ago, CaneMan said:
Side Bars Not Showing in System Stability in latest versions Ver.7.206802
Yes, we had to remove the trackbars there to support both light and dark mode properly.  There's still a hidden trackbar there, just try to move the mouse while you have the left mouse button pressed ;)  An Easter Egg of sorts to provide the same functionality than with the visible trackbar before.
What is doing that supposed to do?
You can alter the scale of each graph by that way easier and more dynamically than going to the System Stability Test Preferences and changing the graph minimum/maximum values there.
