tistou77 Posted March 25, 2024 Posted March 25, 2024 Hello I noticed that in the monitoring, there were "3 x 8 pins" but the RTX 2080ti only has 2 What would you need to check ? Thanks Quote
Fiery Posted March 26, 2024 Posted March 26, 2024 On 3/25/2024 at 3:08 PM, tistou77 said: Hello I noticed that in the monitoring, there were "3 x 8 pins" but the RTX 2080ti only has 2 What would you need to check ? Thanks Somehow your video driver thinks your video card has three 8-pin connectors. I'm not sure why, but my first guess is that there's a small glitch about this in your video BIOS. We can remove the 3rd entry if you could send us a necessary dump: in AIDA64 please press Ctrl+Alt+D --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
tistou77 Posted March 26, 2024 Author Posted March 26, 2024 OK, file attached Displayed in Current and Power values (it's good for Voltage values) Thanks PS : I looked with another software to find out if it came from the video driver, and there are only 2 information for "8pins" nvidiagpureg.txt Quote
Surjeet Posted March 26, 2024 Posted March 26, 2024 @Fiery Hi Sir. Even, I am facing the same issue using mine RTX 3080 LHR. Please find below the screenshot and the logs required. nvidiagpureg.txt Quote
Fiery Posted April 12, 2024 Posted April 12, 2024 On 3/26/2024 at 4:53 PM, tistou77 said: OK, file attached Displayed in Current and Power values (it's good for Voltage values) Thanks PS : I looked with another software to find out if it came from the video driver, and there are only 2 information for "8pins" nvidiagpureg.txt 6.81 kB · 3 downloads @Surjeet Thank you for the dumps, for both of you. The issue will be fixed in the next AIDA64 beta update. 2 Quote
Surjeet Posted November 16, 2024 Posted November 16, 2024 Hi @Fiery, @tistou77, THIS ISSUE IS FIXED for me. Now I can only see 2 GPU Pin I am using current beta: 7.40.7108 (Beta) Thank you. Quote
